Question about Electrical Supplies
Champion 2000 watt inverter
Runs good no power but the output light is on
  • 242 Answers
SOURCE: power inverter
Most likely a fuse. Check for a fuse on the inverter itself or one inline with the plug. Usually you can screw off the tip of the plug and replace the fuse inside.
Posted on Oct 24, 2008
  • 4 Answers
SOURCE: 2nd season with 400 watt vehicle 1024 inverter. The
Restating the question - 400 watt inverter is turned on and running with the vehicle turned off.
After starting vehicle the red light of the inverter is on with no power output from the inverter.
If you turn the inverter off then on inverter operates normally.
Solution - this is normal operation - my inverter does the same thing. When you start the vehicle
it draws a lot of current from the vehicle battery which causes a drop in battery voltage. Most inverters have a low voltage input safety and will fault the device.'
If the problem is turn on inverter then the red light starts flashing... I am thinking you
have the same problem as the one I replaced - it broke... I am sure some capicator
or other component in the circuit failed... My solution was to purchase a new one...
Posted on Mar 03, 2009
  • 4 Answers
SOURCE: Low voltage output from inverter
I am thinking this a high impediance device problem and this is normal operation - the user manual of my inverter warns about use with high impediance devices - if not I am interested also...
  • 76 Answers
SOURCE: Freedom 20 stops passing good AC input after about 15 sec.
This unit does have an idle mode where it will not output without a load. What I am unsure of is if this exists only for invert mode or for both invert and pass through. Try reprogramming the remote to eliminate the idle feature and then see what happens.
Posted on Aug 12, 2009
  • 3 Answers
SOURCE: roadpro rppi-1500w inverter fault light no AC output?
you have a burned resistor near the corner
Posted on May 29, 2010
I have a high gear 2000 watt inverter-the panel shows 13.2 volts but it has no output. what could be the solution?
Make sure your connections are good between the inverter and 12 volt supply. To small wires will not work, chances are it has to be connected directly to the battery with good sized wires.
Sep 29, 2014 | Electronics - Others
This gen won't start , good fuel, carb good get's air & fuel spark plug new. any ideas
if it has air fuel and spark then check the compression. if it has all 4 of those then it will be a timing issue but I am willing to bet you are missing 1 of the 4.
Sep 28, 2013 | Champion Fulfillment Champion 2000 Watt...
I have a champion 10000 watt gen welder won't bur
Make sure the switch for remote power or control at machine is on the right setting. It will arc but very faint if this switch is not on the right setting.
Mar 17, 2012 | Hobart Welding Tools
The output(w) is indicating o.oo and it's indicator light is red .I only have a couple of floor model fans plugged. Should it be showing something and should the light be green?
inverters run on a square voltage unlike normal 110 runs on a round voltage, the only 2 things that won't run on the inverter is fans and electric blankets
Jul 22, 2011 | Cobra 2500w Power Inverter
Output voltage unable to get above 90 V AC on battery tried on running car and only got 90 Volt AC also.
With the car voltage at 13.8V and you have less then a 400 Watt load the inverter is probably bad. The output voltage is not adjustable by the user.
Good Luck,
Feb 27, 2010 | Vector 400 Watt Power Inverter #VEC024
I just bought a RoadPro 2500 and i want to buy like a dorm fridge how many watts or volts size would work??
If you are referring to the RoadPro RPPI-250
  • 2000 Watts Continuous Power
  • 2500 Watts Power Output @ 10 Minutes
  • 5000 Watts Peak Power Output.
  • A small fridge will use about 500 -700 watts, with startup wattage at around 2000watts.
  • So, a dorm fridge will work fine.
  • the RoadPro converts DC to AC voltage, so a regular 120 volt dorm fridge will work.
  • Jul 05, 2009 | RoadPro RPPI-2500W Inverter
    Jan 23, 2009 | Electronics - Others
    2000 watt inverter blows 60 amp fuse under load
    I have a background in electronics so i hope i can help. Now after reading this i have the feeling this item does not put out 2000 watts cause if that were the case it should draw somewhere near 147amps. This is because to find out amps you need to take the 2000 watts and divide it by 13.6 volts (assuming what the vehicle runs at) that gives you amps. watts/volts=amps.
    Jan 13, 2009 | Atd Tools 2000-Watt Power Inverter # 5955
    Electrical Supplies Logo
    Top Electrical Supplies Experts
    Craig Butler
    Craig Butler
    Gene Haynes
    Are you an Electrical Supply Expert? Answer questions, earn points and help others
