Question about Garden
How does one remove the motor shroud from model#MM875 type 3 mower?
5 Suggested Answers
  • 183 Answers
SOURCE: We have a Black and
You can get another end for it at any hardware store...Good Luck!!!
Posted on Aug 06, 2008
  • 121 Answers
SOURCE: Black & Decker MM875 blade
You can pick up a blade at almost any hardware store.
Posted on Sep 27, 2008
SOURCE: how do I split the shroud on my c2002 type 3 air
If you look on the bottom of the shroud cover, you'll see 4 angled brackets that hold the cover onto the tank. Behind one of those brackets you'll see a little phillips head screw. Remove that screw. Now you're entire shroud will come off by sliding the whole unit backwards and then up. You can't just lift the unit up because the angled brackets will continue to hold the unit into place no matter how hard you pull. It has to slide back first and then you'll see that you can lift it off of the tank. Hope this helps!
Posted on Dec 26, 2011
SOURCE: Shaft turns while trying to remove blade on B&D MM875 elec. mower
Here's the scoop on the MM875: it has a plastic piece called a "blade insulator" (part # 241381-01) that "locks" the shaft to the blade, so that you can remove the nut by stopping or blocking the blade. If it has been damaged or stripped out, then stopping the blade won't do anything. However, the metal spacer directly under the nut IS still locked to the shaft (because of its shape), so you can use a pipe wrench or something to hold that in place and unscrew the nut. You might even be able to get someone in a home improvement store to do this for you. But you will still need to replace the insulator, which is only a few dollars.
Posted on Aug 26, 2012
My 22 hp craftsman riding lawn mower gets really hot after10 to 20 minutes and backfires and loses power
You may have a mouse problem. Check the shroud (motor cover) to see if there is shredded paper or other material under shroud. If the mouse shreddings get in the fins on flywheel it will cause the engine to overheat. Remove shroud and clean underneath.
Sep 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Jul 22, 2010 | Black & Decker 19" Electric Lawnhog...
Extension cord rating for black and decker mm875 electric lawn mower
This unit has a 19 amp motor so you should not use anything less than 12 gauge grounded outdoor cable and no more than 50 feet in length
Sep 19, 2009 | Black & Decker 19" Electric Lawnhog...
Switch diagram needed
Funny, I came here because I just opened up the switch case on my MM875. Hold the switch so the terminals are on top. Call the black switch (the part you push in to power up the mower) north. The north post gets white (metal connector). The west post gets red (plastic connector). The east post gets the black that comes from the mower's motor (plastic connector). The south post gets the black that comes from the outlet (metal connector)
(Black Plastic Switch)
White (Metal)
Red (Plastic) Black (Plastic--from motor))
Black (Metal--from outlet)
May 22, 2009 | Black & Decker 19" Electric Lawnhog...
Sep 26, 2008 | Black & Decker 19" Electric Lawnhog...
MM875 electric lawnmower
check motor if armature are not broken & see if the rectifier not burnt. rectifier works from ac & convert it to dc to run the motor.
if you need diagram for parts see toolpartsdirect.com
Aug 27, 2007 | Black & Decker 19" Electric Lawnhog...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
