Question about GE Refrigerators
Can you post instruction for replacing wr49x10091
Repelacing danper for ge pss26sgpass
2 Suggested Answers
SOURCE: How to remove front panel from ge ice maker model PSS26SGPASS
If you are talking about the ice/water dispenser palnel, on my PSF26NGPABB Arctica it just pulled off. there is double sided tape all the way around it and I used a thin, sharp knife to cut it as I pulled the panel off.
Posted on Dec 28, 2010
I need help on how to remove upper cover WR31X10008 in my refrigerator GE Model PSS26SGPASS. I need a service manual with step by step instructions.
I have manuals on my website but need a model number for your GE to provide a manual. You are welcome to search site yourself.
Appliance 911 Sea Breeze
Aug 10, 2015 | GE Refrigerators
Side by side GE turbo-cool Gss25XSRBSS, the freezer seems to be fine, the fridge is not cooling. Fans seem to be running smoothly, no weird noises. Turbo cool turns on. It hasn't been running for
if you go here you can see the damper,fan assy. that's in the top of your machine in the fresh food side
http://www.repairclinic.com/PartDetail/Damper/WR49X10091/1055112
this is a damper with another fan in it,when the t-stat calls for cold air the damper door opens to let the cold air in from the freezer and the fan in it blows the cold air around inside the fridge,if the freezer is fine and the fridge side is warm most likely this is your problem,part number WR49X10091 and it's around 130 dollars.unplug the machine,remove the light cover on the ceiling,remove the 1/4 inch screws and drop the light assy.remove thhe filter cover on the right side so you can remove the damper assy.pop off the cover on the piece that runs up the back center,remove the screws to the damper,read the instructions and put it back together again.should take you around 45 to 60 minutes.hope this helps and good luck.
Sep 27, 2012 | GE Refrigerators
Frig too warm on top, too cold on bottom
inside the fridge section you have a fan damper assy.if you go here you can see it
part number WR49X10091,the cold air comes through the damper and the fan in it blows the cold around into the fridge section,warm air rises so this is why it's warm on top and colder on the bottom.i just installed this part for a customer,unplug the machine or shut it down,remove the 4 screws that hold the top light assy. on drop it down,unplug the wire harness,pop off the cover to the water filter,remove the top two shelves then pop off the middle cover on the back wall,this allows you to remove the two screws that are behind it,remove all screws and remove the damper fan assy.look at the instructions,the one i worked on i had to remove the gasket that's on the freezer wall side and replace it with the fat gasket in the box and then put it back together again,it took me around 35 minutes to do the job.hope this helps you out
Aug 30, 2012 | Refrigerators
I'm having problems with my Adora fridge. First, the contents in the crispers started freezing. The storage tank behind the drawers seems to be frozen. Now the water won't dispense. Ice is being made...
Your model has a WR60X10132 or 10055112 Damper and Fan that regulates temperatures between the freezer and fresh food compartment. The part has been recently updated. Refrigerator air inlet cover/damper kit with fan motor. Damper and fan assembly has been updated to prevent freezing in the refrigerator.
(The manufacturer has replaced part number wr60x10132 with this item, part number WR49X10091.) (Manufacturer part number WR49X10091 is RepairClinic item number 1055112.)
BRB with photos and locations. Sea Breeeze
Jan 23, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Refrigerator inot getting cold
You probably have a bad damper assembly . Your model has a built in motor , which opens for lower settings . Pt # WR49X10091 . This part comes with an upgrade and instructions .
Sep 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Jul 10, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Refrigerator and freezer are both warm
sounds like the thermostat is faulty.
Feb 12, 2009 | GE Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
