Question about Garden
International harvester tractor T-9 serial number TCB 56303 i am trying to get a carburetor rebuild kit for it. 4 cylinder tank tracks
  • 2,992 Answers
Hello Ken Rogers,
Take a look at the THREE basic shapes shown in the attached eBay listings... (to determine your carb NOMENCLATURE).
Then look closely at the RELATED LINKS on
the bottom of the page...
No direct eBay hits (but look at the TYPES)
0results for carburetor International harvester t9
Posted on May 01, 2017
    Top Expert:
  • Garden Master
  • 12,744 Answers
Can check with auto parts in your area ot a tractor supply company store [they carry a limited supply of parts ] but easier to find on line
International Harvester Carburetor Kit IH Carburetor eBay these are a couple
Posted on Apr 30, 2017
Only runs with choke on Cub Cadet 19 hp kohler
Carburetor probably needs cleaning and carburetor rebuild kit installed. You need a local that can determine which kit you will need based on the engine model and spec number.
Aug 19, 2014 | Garden
My son's weedeater Model# MX550 doesn"t have a manual and he needs one to be able to rebuild or clean the carburator, as he left gasoline in it over last winter.
This is as easy as 1, 2, 3.
1. The weedeater manual for this machine will not tell him how to clean and rebuild a carburetor.
2. There are good videos on youtube for clean and rebuild of two cycle carburetors.
3. Using the brand and model number you will be able to get a carburetor rebuild kit for less than ten dollars I think from a local small engine repair and repair parts shop.
I hope this is helpful for you.
Sep 01, 2011 | Poulan Garden
I have a Deere twin cylinder 23 hp Tecumseh tractor which is hard to start between uses. Per user manual, I choke it full and throttle it full. When I turn on the ignition it turns over and over and...
Hi knobbe69
Time to "mess" with your carburetor...sounds like that is where the problem lies...
I will include my instructions on the carburetor rebuilding....
Check to make sure you are getting fire/spark at the plug, if so then do the following:
Check/Clean/Replace your fuel filter if you have one, normally they will be located in the fuel tank.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Apr 16, 2011 | Tecumseh Ov691ea 22 Hp 22hp Lawn Rider...
My Troy-bilt edger C5 4-cylinder will not start. I've replaced the gasoline and spark plug. This unit was bought on 04/01/2004 and has run good up until this year. Thank you, Ron Smith
Check your fuel filter in the fuel tank to make sure it is clean if it is then"
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Aug 20, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I need a diagram to rebuild the carb for my 67 250 inline 6
When you buy a carb. rebuild kit it will come with the diagram chart and spec to rebuild it.
Jun 10, 2010 | Cars & Trucks
Carburation Getting gas to the carburator but will not stay running without choke on
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
May 31, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Need a rebuild kit for the hydraulic cylinder that lifts the snowblower - does such a kit exist and what is the part number?
there are rebuild kits for some but not all, check your local jd dealer, my family ownd a jd dealer until last year jd stuff aint cheap. personally id type hydraulic cylinders into google and buy a replacement
Nov 06, 2009 | John Deere 420,1020,2010,2020,2510,2520...
I was given a Case tractor. It needed a fuel
Is your fuel pump working? are you getting fuel to the carb?
1. check for spark
2. check for compression in all cylinders
3. check carb (if it's been a long time since it was last started, you will need to just take the carb apart and clean it or get a carb rebuild kit. rebuild kit is easiest route and once you do that, you are done fussing with it.
4. Diagnose the problem.
a. try starting fluid directly into the carb. If it fires up then quits you have a fuel delivery problem. Once you figure out that, you can trace the problem back from the motor to the tank.
5. If you don't have any spark, try new plugs, then try new wires, then start going over your electrical system
Oct 04, 2009 | NRS Garden
Checking fluids
look for a tank reservoir with a dipstick. Locate the pump or cylinder and follow the line back to the tank.
Dec 22, 2008 | Ertl International Harvester Farmall Super...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
