Question about Sewing Machines
How to thread a Universal model #302L - Sewing Machines
The bobbin, my other machine has a top loading bobbin so I don't know how to feed this one up onto the plate
Difficult to help without the make & model.
This video may be helpful (the way bobbins thread and load are pretty universal):
How to Thread the Bobbin on Singer Sewing Machine
Nov 11, 2017 | Sewing Machines
I need help in good tension for rolled hem in empisal 606D overlocker
Your owner's manual should have instructions for rolled hem settings. My Bernina manual has a the following settings:
Medium weight fabric
80/12 Universal needle
3 cones serger thread
Upper looper 3-5
Lower looper 7-9
Left needle (no thread)
Right needle 3-5
Stitch length 1-1.5
Cutting width 2-3
Differential feed N
Can use woolly thread in the upper looper, but the tension may need to be loosened since the woolly nylon thread will stretch.
Make It Handmade Threading Your Serger or Overlocker
Dec 19, 2015 | Sewing Machines
Skipping stitches
You don't mention changing needles to match the thread. There is NO SUCH thing as a universal needle. If you need lighter thread, you need a lighter needle. Start there...
Mar 19, 2013 | Sewing Machines
I have a brother ls-2125 sewing machine. the upper thread is not catching the bobbin thread properly. help please
  1. Tension
    • Your sewing machine tension controls the rate at which the thread is fed through either the upper section of your machine or through the bobbin case. If your upper or bobbin threads aren't threading properly, sometimes adjusting the tension will correct this problem.
    • Your sewing machine works by passing the upper thread through the needle of the sewing machine at precisely the same time the bobbin brings its thread to its uppermost position. If either the needle or the bobbin thread reach these positions too soon or too late, the threads won't interact and create the knots that make the seam. You can throw off your timing by sewing too many layers of fabric or hitting a pin with your needle. See you sewing machine repair facility to correct any timing issues.
    • Thread can get snagged or caught in the upper section of your machine or on lint pieces in the lower bobbin section. If your threads aren't catching properly, you may be able to fix it by unthreading and rethreading both your upper thread and bobbin threads.
Oct 15, 2011 | Brother LS-2125 Mechanical Sewing Machine
I have a bernina 210 model sewing machine. I'm
#1 Use only Mettler or Gutermann thread. Coats thread is very rough and will pucker the fabric. #2 Make sure that the tensions are balanced. #3 Use the regular zig zag foot. #4 Use a new needle, universal, size 80/12. A blunted point will pucker the fabric.
Jun 02, 2011 | Bernina Activa 140
My Kenmore stopped making stitches. I changed the needle recently to a Singer Universal regular point needles 100/16, but I dont believe that is different than what was in there before. I have a Model...
Why are you using #16 needle, that is very heavy duty? Did your machine pick up the bobbin thread correctly? Try a different needle, #11, (inserted facing away from you) is usually good. Make sure that you have decent thread and that it is the same weight top and bottom. Now rethread, with the presser foot up and when you have that done, with the presser foot stiil up, pull top & bottom thread, it should feed smoothly, now with the presser foot down, pull the thread, it should barely move. This usually seats the thread in the tension discs. Put your top tension at 3 and see if that makes a difference.
Jan 19, 2011 | Kenmore Sewing Machines
I seem to be threading the spool correctly, yet the needle doesn't pick up the thread.
You haven't stated the exact model, but the principle for picking up the spool thread is pretty universal.
After loading the spool into the bobbin case and correctly threading the spool, pull the thread up through the sliding cover plate to lie on the machine bed and mostly close the cover.
Lift the presser foot, thread the needle and then advance the balance wheel slowly so that the needle goes down and then returns up. If the machine is correctly threaded, correctly adjusted , has an unbent needle and the needle is appropriate to the thread size, then it should pick up the bobbin thread. Just pull on the loose end of the needle thread and the loop with the bobbin thread should come up through the needle hole. Pull both threads to the right from where they have just emerged, allowing the loose end of the bobbin thread to disappear beneath the cover plate before re-emerging through the needle hole. Close the cover fully, lower the foot onto the work and start sewing.
If the above fails, then check that the spool is loaded the correct way around into the bobbin. It makes no difference to many models, but does to some. If you don't have the instruction book then just try both ways. It also helps to ensure that the machine is correctly maintained with no build ups of lint and correctly oiled with sewing machine oil. This is a light oil grade but has additives to ensure that it sticks where it's needed, "3-in-1" brand oil can be used but may need to be applied more frequently and the machine will need cleaning more often.
If the pick up still doesn't work, then your machine needs to go for repair as it either has a damaged bobbin or a screw has come loose in the mechanism causing the machine to lose timing. For older Singer models, all of the timing and servicing information is available free on the web. Just enter your model number followed by "manual" or "service".
Good luck, please add a comment if any of my answer has puzzled you, but otherwise I'd appreciate it if you would take a moment to rate my reply.
Sep 17, 2010 | Singer Sewing Machines
Does the singer model 3820 take a special bobbin? I cannot get it to feed the thread up to the needle.
It takes a singer or universal bobbin with a flat top - not one of the plastic ones that has a curve to the top.
Jul 11, 2010 | Singer 3820 Mechanical Sewing Machine
I need a manuel for an Elna 411 serger
I could not find a manual for this model, but did find a fairly universal guide at Singer -
A very good book for sergers from threading to maintenance is Nancy Zieman's Serge With Confidence.
Raise the antenna to it's highest position.
Raise the presser foot and set the tensions (if not auto tension) to zero.
Thread in the order indicated in the download or on the front of the serger/inside serger door.
Mar 19, 2010 | Elna Sewing Machines
How do you thread a kenmore sewing machine I can't figure out how to thread the bobbin for kenmore machine 1385.15343600.  I am a beginner, so I will need pretty detailed instructions. Thanks! Jenny
Put the bobbin on the short metal stick on top of the machine. Unthread the machine. Put the spool of thread on the tall, left side stick on top of the machine. Take the thread and wrap it counter clockwise around the circular, short, metal thing on the left side of the top of the machine, only 180 degrees. Thread the thread through the hole in the bobbin (which should be on top). Press the bobbin to the right, into the little white thing. Pull the turning wheel on the right side of the machine out. While holding the end of the thread, softly press the presser foot so that the thread goes around the bobbin a few times. After that, cut the end down to the bobbin. Now, press the presser foot down and wind the bobbin until it stops on it's own.
Mar 05, 2009 | Kenmore 15343
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
