Question about Emerson MW8102SS 1100 Watts Microwave Oven
Microwave model mwg9111sl. I have a problem with the door latch/switch and power on/off/timer going crazy
  • billp412 Jul 25, 2009
    Well at least now I know where to start on fixing the switch or just testing the switch for my microwave. This unit is fairly new and didn't want to buy another.
  • 215 Answers
Hi, Welcome to FixYa
There are three basic types of self-cleaning oven door locks:
1. Manual lock
2. The electromechanical door lock is operated either by pressing a button on the oven's control panel or by physically moving the latch. In either case, the action will activate solinoid.
3 The electric door lock is activated by the user setting the cleaning controls on the control panel of the range. This activates an electric motor, which in turn activates the locking mechanism.
treble-shooting
1. To check the function of the door latch, refer to your range's operating manual to determine the type of latch and the location of the latch's operating switch or sensor. Check that the latch is operating freely throughout its range.
2. Before repairs or further testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution
Set the latch to the "clean" position and test for circuit continuity at the terminals of the switch with your ohmmeter function. If there is no continuity, the switch is faulty
if these steps are not working for you might have to take it to repair
Please goto this site and refer your problem. If it is not listed send an email to them
http://www.repairclinic.com/0088_6_1.asp
also refer the link http://forum.doityourself.com/archive/index.php/t-268144.html
Thanks
If you are satisfied with the answer please ACCEPT and give a POSITIVE feedback
Posted on Jul 25, 2009
How do I set the clock on Emerson microwave model mwg9111sl
Hello!
Here is the link to the manual for Emerson MWG9111SL - setting the clock.
I hope it will help!
Microwave Cooking Emerson MWG9111SL 8 23
Jun 19, 2017 | Emerson Microwave Ovens
GE Microwave PVM1790DR1BB light works but no fan and the turntable does not turn
I have this exact model with the same issue. I am a technician by trade on office equipment. I took the cover off where the door latches go in and there are 3 relay switches behind there. I adjusted the switches so the door latch would make better contact with them.
May 05, 2013 | Microwave Ovens
The microwave will not come on ,however the timer starts running . If you hold the latch in slightly it will run correctly but you have to keep it pressed in. I have the sharp carousel model 1200watt
Your door is misaligned dont use it by holding it Ionce you tighten the door correctly then adjust the door switch where the door latches and make click sound Thanks Please rate me
Aug 27, 2011 | Sharp R-510HW Microwave Oven
Throws breaker everytime I plug it in Emerson Electric Microwave model MWG9111SL
That would be a bad monitor interlock (middle door switch) or its mount is bad.
See this help file on door switches.
Jul 08, 2011 | Emerson Microwave Ovens
When I set the timer and close the door, the door latches fine. When I push the start button the timer starts to countdown but the microwave doesn't start. If I push the door release in about 1/8 " ,...
If your model number is in the Sharp R-1500 series, then that's a problem with the bottom door switch or its mount.
See these files:
http://207.234.249.73/mwd/safety.txt
http://207.234.249.73/mwd/disassembly.txt
http://207.234.249.73/mwd/doorsw.txt
Jan 14, 2011 | Sharp R-1511 Microwave Oven
When set the timer, etc and then shut the door the
yes it is switch problem there must be three or four switches replace all together
Jun 23, 2010 | Sharp R-426H Convection Microwave Oven
Emerson MWG9111SL microwave reset switch
my microwave stoped woring and i dont know where the reset button is can someone help
May 19, 2010 | Microwave Ovens
1200 watt panasonic, power on but will not perform
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
best regards .
please don't forget to rate !
Apr 04, 2010 | Panasonic NN-S262SF Microwave Oven
Timer changing but microwave is not turning on?
Hello :
It's a bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 30, 2010 | Magic Chef MCD1311ST Microwave Oven
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Emerson MW8102SS 1100 Watts Microwave Oven Logo
46 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
