Question about Gateway GM5048 (6304) PC Desktop
I need to get a copy of the recovery disc for the Gateway GM5048
My desktop constantly restarts itself to the point that I have not been able to see the windows screen. I am ready to do the system recovery but I can't locate the recovery discs that came with the computer. Can someone help me? Thanks
  • daleggs1 Jul 25, 2009
    I tried a couple of weeks to get the recovery disc from Gateway but was told that they don't carry it.
  • 38 Answers
Gateway sells the cds. If you tell them your model no they will send you a recovery disc (with a tiny fee of course).
Here's their number 866-539-3901
You can also live chat here http://www.gateway.com/about/contactus/index.php
Also, check this site out might turn out to be helpful.
http://support.gateway.com/s/software/MICROSOF/vista/7515418/7515418su539.shtml
Posted on Jul 25, 2009
  • 112 Answers
Try hitting f8 or f1 ( depends on your system) while its booting and see if you can get to the boot option screen. just keep tapping the f8 or f1 key while its starting. If you can, then choose the command prompt and type
At the command prompt type
c:\windows\system32\restore\rstrui.exe
Press Enter
Follow the instructions on the screen to use System Restore
Try to restore system to earlier time. you may have a virus. there is one that does that.
Gateway dx4380g-uw308 keeps restarting?
Windows 8 has a neat utility that is called "Refresh Your PC". This process does not change any of your files (documents, pics, vids, music, etc.). If you upgraded your PC from Windows 8 to Windows 8.1 and your PC has a Windows 8 recovery partition, refreshing your PC will restore Windows 8. You'll need to upgrade to Windows 8.1 after the refresh has finished.
To refresh your PC
  1. Swipe in from the right edge of the screen, tap Settings, and then tap Change PC settings.
    (If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, click Settings, and then click Change PC settings.)
  2. Tap or click Update and recovery, and then tap or click Recovery.
  3. Under Refresh your PC without affecting your files, tap or click Get started.
  4. Follow the instructions on the screen.
Aug 20, 2014 | Gateway DX4380G-UW308 Small Form Factor...
NEED RECOVERY DISC
You maybe be able to get a Recovery CD for your model computer from the Gateway WEB site.
May 15, 2012 | Gateway GM5048 (6304) PC Desktop
I bought GM5048 from a friend. In good working order. Now I have everything hooked up & it keeps telling me Media test failure,-xe-MOF exiting boot agent-- O-bootable device-insert boot disc press any...
1. You didn't specify if you are installing Windows XP or which operating system.
I assume that you want to install Windows XP. I am not sure as to the age of this unit and if it is compatible with the above mentioned OS.
2. If you have a valid key then any Windows XP Operating disk will boot your PC unit provided you have allow the device in the bios to boot from it.
3. You will need to select the CD/dvd device to be enabled for the pc to see the boot disk. Usually selecting F12 or F1 will allow you into the BIOS setup for this.
You will need to ask your friend for the user manual to follow the bios setup procedure. I don't think there is a user manual for this model online anymore.
Oct 05, 2010 | Gateway GM5048 (6304) PC Desktop
Gateway recovery disc
why not goto ubuntu linux it's free to download and easy to use
Apr 20, 2009 | Gateway 300 S PC Desktop
Video card removal
Okay first things first make sure you have unlocked the card from the case. Most Gateways have a card lock on it. Once it is unlocked just pull the card out, sometimes they are hard to pull out but you can get a small screw driver and pry up at the case side and slowly work it out.
Hope this helps.
Feb 28, 2009 | Gateway GM5048 (6304) PC Desktop
Constantly reboots itself
The Gateway GT5220 has an AMD Athlon 64 processor. It has been documented that Windows XP SP3 doesn't play well with some AMD CPUs. I'm pretty sure this is one of them. I would suggest attempting a system recovery using a restore point on a date BEFORE you installed SP3. If that doesn't work, you might consider recovery using the original Gateway Restore CD. It will likely wipe the system, but that might be the only choice.
I would NOT start with the total reload option. We have a couple others before you get there, so try the restore point and then let me know the results. We'll go from there...
Regards,
Char1ieJ
Nov 04, 2008 | Gateway GT5220 PC Desktop
System recovery for Gateway GM5048
No that should have nothing to do with it......
What I can recommend is manually installing the drivers rather then going through the entire recovery process again. All of the drivers that you would need you can find here :
http://support.gateway.com/support/drivers/search.asp?st=pn&param=6153
If you need help with anything more specfic feel free to leave a comment here and I can give you some more help!!
If you found this helpful , please leave a rating...thanks!
Oct 01, 2008 | Gateway GM5048 (6304) PC Desktop
Modem Problem
reinstall the sound driver
http://support.gateway.com/support/drivers/search.asp?ref=step&st=browse&platform=10021&model=11245&os=10406&type=10096
and the modem driver
http://support.gateway.com/support/drivers/search.asp?ref=step&st=browse&platform=10021&model=11245&os=10406&type=10080
Jun 11, 2008 | Gateway GM5048 (6304) PC Desktop
Gateway GM5048 (6304) PC Desktop Logo
161 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
