Nordyne P3RD-036k starts but the cooling cycles on/off and hums. It gets better after a while. Inspection of electrical board appears theres been arcing on what I think is the contactor
  • Heating & Co... Master
  • 1,549 Answers
Not quite understanding. So the short cycling goes away after it runs for awhile??? If that's the case I'm assuming you have some loose wiring. Turn power off and check ALL electrical connections. The contactor would not be right on the board so I'm a bit confused. Good Luck!!
Posted on Apr 30, 2017
Electric Nordyne Furnace/AC/with heat pump makes buzzing noise when turned on, registers do put out heat. Any ideas what is causing the buzzing noise?
is it only in heat? Possibly the heater contactor but I don't believe nordyne uses a contactor. could possibly be the transformer humming? many different strange noises come from units, may want to have it serviced.
Oct 10, 2017 | Heating & Cooling
What year was this model made?
Your unit (B3BV-036K-BB) is a Westinghouse / Nordyne Unit.
Vertical Flow only, 36,000 BTU, 208/230 volts.
You cannot tell the manufacture date from a model number, only from the serial number. Try contacting manufacture with the serial number...
(nordyne.com)
Sep 13, 2014 | Frigidaire Heating & Cooling
Nordyne T3BA-036K trips breaker on outdoor unit immediately will not stay set
Hello, sounds like a short to ground. Check all the wiring to make sure it is not touching any metal. If the wiring appears ok then the compressor windings are shorted to ground and the compressor will need to be replaced.
Jun 04, 2012 | Heating & Cooling
Nordyne Split System Blower Won't Start
It's the fan motor. A relay problem would cause the motor not to run at all.
May 08, 2017 | Heating & Cooling
I had a storm the other day, and now everything works, but the compressor keeps trying to start but doesn't come on. I have 115v to the start, & run terminal at the compressor. any suggestions?...
this could wellbe a capisitor problem .. be certain that if you chose to change it out that you disconnect the posewr to this unit and then using a screw driver touch the terminals across the cap to short them out ,, they can packa heck of a punch . If you have a meter you can test them I remomend you do a search oc testing a capistior on line as it a but cumbersome doing it here..
Jul 25, 2011 | Intertherm P3RC-036K Air Conditioner
Need a product manual for intertherm model p5rd-036k
http://www.nordyne.com/Literature/455a.pdf
and here ya go. check this web site for your manual.
Hope this is what you want.
Dec 26, 2009 | Intertherm P3RA-036K Air Conditioner
No heat fan running
This is a 10 Seer electric heat package unit. There are few possibilities. Does the blower come on when you put the t-stat on Fan on? If it does, then it is probably the blower time delay relay which is nordyne part# 622181. If the blower doesn't come on at all, check that the blower is getting power and if it is, then the blower motor is bad but could possibly be the capacitor as well. Both should be checked.
Mar 31, 2009 | Intertherm P3RA-036K Air Conditioner
Loud humming noise
when was last time furnace was serviced --air filter change burner area cleaned vacuumed the hum can be a few reasons ---fan bearing need service [ oiled ] fan bracket bushings damaged or loose --burner out of adjustment burning improper etc these are a few
Jun 03, 2017 | Heating & Cooling
Fan
The hum is power line hum ( 60 cycle ) . It may be that when the amp gets warm that something in the case wants to vibrate to the 60 cycle hum.
I have amps that hum like that and theyre fine.
Depending on the design of the amp, the cooling fan may not go on till it gets really warm in the amp. Some run all the time like the Ashly I just fixed
Dec 03, 2007 | Crown CE2000 2-Channel Amplifier
Nordyne electric heater
If you have 24 + volts between common and w or w2 when your thermostat is calling for heat, you might have a or a couple of defective heat relays or sequencers.
Nov 26, 2007 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
