Question about Toro Garden
Display on toro tmc 424 flashes, unit does not function
2 Suggested Answers
  • 47762 Answers
SOURCE: Irritol rain sensor sends a signal to the receiver and the red light comes on after a heavy rain but the Toro TMC-212 still comes on and waters. We have tried both Open and Closed system settings.
check the way the system is wired up as there appears that that is where the problem is located
Posted on Jun 08, 2015
Tascam 424 noise
I need more info but I do repair them still in chicago area so that you have a fully functional unit.
Look up skywave tape deck repair if you want to. I have been doing Teac work for over 40 years.
Mar 30, 2014 | Tascam Audio Players & Recorders
The tmc function of the satnav unit in my 2012 Ford Galaxy has stopped working.
this may be a function you have to pay for seperately & the service dept. may not know
Mar 03, 2014 | Ford Cars & Trucks
Flashing temperature control for freezer setting
There is no problem for that, as long as the temperature control is functioning well and it display the temperature degrees number. You vary it, hi or low and the unit still cold or freezing.
Sometimes the liquid crystal display of the electronic control module become loosen 'cause it to display in a flash manner. Unless it display "ER" it means there's something wrong with your unit. But so far it operate normally.
Thanks for asking.
Jul 04, 2011 | Refrigerators
The tomtom device prompts me to connect the traffic receiver.How do I do that
This is for the RDS-TMC antenna.
Plug the end fitting on the antenna into the bottom of the Tom Tom. Plug your normal power cable into the antenna.
If it's working, when you turn it on, you should see a new display, narrow, vertical, on the far-right side of the screen.
Oct 30, 2009 | Tomtom Tom Tom RDS-TMC Traffic Receiver...
Sony DAV DZ230 Child Lock
hello You can deactivate the buttons on the unit
(except for "/1) for preventing misoperation,
such as child mischief (child lock function).
When the child lock function is activated, the
buttons on the unit are locked and “ ” lights
up in the front panel display. (You can operate
the system by using the remote.)
Note
•When you operate the buttons on the unit while the
child lock function is on, “CHILD LOCK” appears in
1 Press SYSTEM MENU.
2 Press
X/x repeatedly until “CHILD
LOCK” appears in the front panel
display, then press or
c.
3 Press
X/x to select a setting.
The default setting is underlined.
• “OFF”: Child lock function off.
• “ON”: Child lock function on.
4 Press .
The setting is made.
5 Press SYSTEM MENU.
The system menu turns off.
Tip
• You can activate the child lock function by pressing
x for more than 5 seconds (“ ” lights up in the
front panel display).
To cancel, press x for more than 5 seconds so that
“ ” disappears from the front panel display.
Deactivating the Buttons
on the Unit good luck
shaun
Sep 12, 2009 | Audio Players & Recorders
Unable to get it connected
Is this the RDS-TMC?
Try resetting the navigator (using a paperclip in the reset hole in the bottom of the device). Then plug it in again and see if anything's changed. Remember that the antenna must be connected to power for it to work.
Are you seeing the vertical display on the right-hand side of the screen?
If the thing is constantly searching but never showing traffic updates, it's possible that you don't live in an area that has active RDS-TMC broadcasts.
Nov 01, 2008 | Tomtom Tom Tom RDS-TMC Traffic Receiver...
Vacuum or Blower?
* Blowers perform the single, simple function of blowing material. * Blower/vacuum combinations combine the blower function with a vacuum feature. Leaves or debris can be directed into an attached bag, which makes this type of unit great for vacuuming leaves from shrubs. An additional mulching feature is available on some leaf blower/vacuums. Mulched lawn debris can be used in compost piles or bagged for disposal. Most convert easily from blowing to vacuuming mode.
Aug 27, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
