Question about Sanyo DP42746 42 in. Plasma Television
Bottom go ogg no nothing but a green light
Same ****!
When I plug in the TV, why does a green light come on at the bottom of the TV?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 04, 2015 | Televison & Video
My mp3 is not playing the songs.when start ,its do nothing.and when i push the button to fw. rw. or play ! just a beep is playing.
if samsung yp-s2, press with a pin in the reset hole to reset the device. chances are you are trying to play formats it does not support. try to stick with mp3 or ogg. some ogg formats beep like that too tho. it does not support drm windows formats
Sep 15, 2011 | Samsung YP-S2 MP3 Player
DS lite green light comes on, top screen flash,then switches off
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
Jun 16, 2009 | Nintendo DS Lite Console
50' plasma, does not turn on,
still nothing, tried twice last night and second time tv worked, this morning nothing
Feb 14, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Resume light coming on but printer won't work
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 03, 2009 | Office Equipment & Supplies
D52W19 No pix, sound good - now green light blinks, no come on
First of all you need to find out which CRT leaked and replace it before any other repairs are done. The clear liquid is conductive and has done damage to the CRT board or boards.
Jun 15, 2008 | RCA D52W19 52" Rear Projection Television
I just replaced my lamp
which light is flashing?? there are two green lights. the timer light and the lamp light.if the lamp light is flashing you have a bad lamp or a bad HV-Starter.Could be a bad DMD-Board as well
Jan 11, 2008 | LG RU-52SZ51D 52" Rear Projection...
Compressing music files
if your mobile supports OGG format. then you can convert MP3-OGG format. OGG format can hold 200 songs on 1GB memory card. use Mp3-OGG convertor.Similiarly you can also AAC format. But compared to OGG AAC files requires bit more space
Dec 19, 2007 | Sony Ericsson K800i Cellular Phone
Sanyo DP42746 42 in. Plasma Television Logo
101 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
