My screen went off the blue light on the side is on but my screen is black like its off.
I have a Vizio XVT3d474sv. My TCON went bad, only one side of the screen was working. I ordered a new TCON for it. I had been checking over other things and was lightly tapping areas to see if somethi
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 03, 2014 | Vizio XVT3D474SV 47 in. 3D LCD TV
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 17, 2014 | RCA MM36100 36" TV
Non-responding screen, blue indicator light?
I also got this blue screen,
I fixed it wiit a registry tool, it is powerful suggest you have a try!
Fix blue screen now.
Download blue screen fix tool.
Feb 28, 2010 | HTC G1 Smartphone
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
Black screen after a couple of seconds
The monitor needs to be replaced. I had an LG LCD that did this luckily it was still under warranty. Contact the maker and have your receipt handy. Otherwise buy a new monitor. Monitors tend to be replacement only
Apr 11, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Vivitek 32 L32PL1A no picture, black screen
chek your power module.check your electrolytic capacitors both in the input & output side of the power module.
Oct 05, 2008 | Vivitek V37835 46 in. LCD Television
Screen goes black
It could be a bad backlight bulb.
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
Tv screen stays black with the blue light and two red lights blinking
I have the same problem, if anyone has a solution PLEASE mail me at
Apr 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Screen went black and can not make calls
You Phone lcd has some problem or your flip doors are been lose so you must get your mobile phone check with someone proffesinal in repairing the mobile phone or if you mobile phone is under warrenty claim it .
Sep 22, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
