Question about The Computers & Internet
Suddenly, I when I click on the Windows 10 window in the lower left screen, it won't open the options?
  • The Master
  • 8,203 Answers
All the time or just at startup. If all the time then there is an issue with the OS. If it works after a little bit, the OS was still loading and busy and not yet ready for your command.
Which is it?
Did you try a system restore ?
Posted on Apr 30, 2017
Testimonial: "Thanks, and I fixed it by "cntl/alt/delete" and was able to restart"
How do you get Windows 10 free update from Windows 8 to operate the screen saver?
How to customize Screensaver in Windows 10
RECOMMENDED: Click here to fix Windows errors and optimize system performance
There were times when computer monitors used to suffer from image burn-in issues caused by showing the same image for a long period of time and people used to install a screen saver to avoid the issue. The computer screens today no longer face the burn-in issues, but people still use the screen saver on their computer systems for fun's sake. Windows 10 comes with a six built-in screensavers. Let us see how you can customize screensavers in Windows 10.
Read: Are Screensavers necessary and still needed.
Screensaver Settings in Windows 10 You can get to your screen saver settings directly by typing 'Screen Saver' in the taskbar search box in the lower left corner of your system. Click on 'Change Screen Saver' and it will take you the Screen Saver settings right away where you can adjust the settings according to your own preferences.
Alternatively, right-click on your Windows 10 desktop, and select Personalize to open Personalization settings. Next click on Lock screen in the left pane.
Scroll down the Lock Screen settings and click on Screen Saver Settings. The following window will open. Here you can adjust the settings according to your preferences.
By default, Windows 10 offers the following six screensavers - 3D Text, Blank, Bubbles, Mystify, Photos and Ribbons - nothing new here. Select the screensaver from the drop-down menu and change its defaults Settings, if any are available.
For instance, the 3D Text screensaver lets you customize the text as well as a few other options.
The Photos screensaver lets you display your favorite photos as a screen saver.
Once you are done, click on save and exit.
Create Screen Saver Settings Shortcut
If you access the screensaver settings frequently, you can create its desktop shortcut as follows: However, it is easy to change the settings but if you change your screen saver often, it would be better to create a Screen Saver Settings shortcut on your desktop.
To create the shortcut, you have to right-click on your desktop and click on New > Shortcut.
Type control desk.cpl,,@screensaver in the location space in the wizard.
Click Next and give a name to your shortcut. Click Next and you are done. Give it a suitable icon of your choice.
Use this shortcut to change or adjust your screen saver settings whenever you want, quickly.
You can also create a shortcut to launch or change Screensaver state for a specific screensaver.
Nov 29, 2015 | Microsoft CompuRegister POS-1000 POS...
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Rotate screen back to normal
Feb 23, 2013 | Gateway Computers & Internet
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Feb 15, 2013 | Samsung N120-12GW Netbook
Acer tablet troubleshooting
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
b>
Jan 14, 2013 | Computers & Internet
Seagate freeagent keeps dropping disconnecting
Seagate manufactures both internal and external hard drives, and their sleep modes can be managed in different ways. The hard drive is one of the top energy consumers among computer-hardware components, and Windows operating systems support options to reduce power consumption. Internal hard drives are typically turned off and stop spinning ("sleep" mode) after a certain period of system inactivity. However, the system usually takes longer to come back when the hard drive's sleep mode is activated. Furthermore, turning off hard drives may result in failure of some constantly running applications.
Windows includes options to turn off sleep modes for internal hard drives, and external hard drives can be managed using a utility program.
Log in to an administrator account and click the "Start" button in the lower left corner of the screen. Click "Control Panel" and then "Systems and Maintenance." b> Click on "Power Options." Open "Change plan settings" under your current power plan. Note "Radio button" is selected for the current plan. Click "Change advanced power settings." Expand the entry "hard drive" by clicking on the "+" sign. Click on "+" to expand the entry "Turn off hard disk after." Select "Never" for this option and click "OK." b> In Windows XP Log in to an administrator account and click the "Start" button in the lower left corner of the screen. Click "Control Panel" and switch to the "Category" view on the left panel. Then click on "Performance and Maintenance." Click on "Performance and Maintenance" and open "Power Options." The select the tab "Power Schemes." Using drop-down list, set the option "Never" for "Turn off hard drives." Click "OK." b> Using "NoSleepHD" for External Hard Drives b> Click on the "NoSleepHD program" link in Resources. Click "I Agree" and save the program (as a zip file) on your computer. Open a folder where you have saved the file using Windows Explorer. Right-click on the zip file and select "Extract All." Then click "Extract" to get the program file "NoSleepHD v1.0.exe." Double-click on the program (.exe) file to execute NoSleepHD. Click "Select External Hard Drive" in the Program menu and choose your Seagate external hard drive. Choose "10 minutes" under the option "Write File every" and click "Start NoSleep Mode." The program will write an empty string every 10 minutes to the Seagate hard drive and prevent it from going into sleep mode. Hope this helps.
b>
Dec 29, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Windows sleep mode problems
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity
Dec 21, 2012 | Computers & Internet
Change screen orientation
b>
Dec 14, 2012 | Dell Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Your Computer in sleep mode
First, save all of your work. Information in computer memory is not saved while your computer is on standby.
From the Start menu, select Settings, then Control Panel, then Power Management.
Click Standby Beside When I Push the Power Button.
Push the Power button.
Automatically Putting Your Computer on Standby
Save all work before leaving your computer.
From the Start menu, select Settings, then Control Panel.
Double-click Power Management.
Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks.
Click OK. Your computer will go on standby according to the schedule you have entered.
Putting Your Computer in Hibernation
Double-click Power Settings.
Click on the Advanced tab.
At the When I Push the Power Button On My Computer screen, click Hibernate.
Click the Power button.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
New screens at Max. size
Hello there.
In Windows sometimes it 'forgets' its window placement but luckily we can set it back to maximised windows by default.
To do this please do the following.
* Double-click "My Computer"
* Maximise window by clicking the icon on the top right.
* Left click "Tools" menu.
* Left click "Folder Options"
* Left click "View" tab.
* Left click "Apply to All Folders" in the "folder view" section
* Finally left click "OK"
This will save your window placement to be maximised by default, for any new windows opened.
Hope this helps.
Apr 16, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
37 people viewed this question
Top The Computers & Internet Experts
tim brauer
tim brauer
Dilum Senarath
Dilum Senarath
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
