Question about Invacare Health & Beauty
How can one maintain a manual Invacare wheelchair wheelchair feels unstable
  • 175 Answers
SOURCE: I have a invacare The joystick mk5 will not lite up batt. are new
Some chairs, like the M91 are a real bear to replace the batteries and connectors can get knocked loose in the process. First, using a voltmeter you need to see if the controller is getting power. On the DC setting, use voltmeter at the three-pin female connection at the joystick that is the charging port. The two pins that are opposite each other are the "hot" pins, and your meter should read about 25 volts, +- 2 volts. If its 0, there is a connection that isn't made from the batteries through to the controller, or the controller or joystick is shot. If you do have power to the joystick, then it's probable that the joystick is shot. A new one from Invacare is pricey, around $1,000.00 I have found a new site that can repair most makes. I have not used them, so cannot vouch for their work, but give them a call and see what you think.
http://www.flightsystems.com/cart_controls/wheelchair_powered_scooter_market_cart_controls.htm
If you don't have power, start at the terminals from the battery, and follow each wire back to the power control box, unplug and replug firmly as you work your way back. Check all fuses on the way. Then check all of the other connectors inside the chair, unplug, and reconnect again. Unplug and reconnect the wires leading into the power control box, and then restart chair. If no lights still, then the power control module is probably the culprit, but the address above fixes those too. The joystick and the power control module work together to make the chair operate safely. Good luck
Posted on Jul 08, 2009
  • 175 Answers
SOURCE: I have a invacare wheelchair pronto91 wont move 2
The three light flash indicates a short circuit between the left motor(as you are sitting in the chair)and the battery. Check all the wiring from the control box to the motor and make sure it is not damaged in any way. If it is okay, you have most likely fried the left side motor. A new motor-gearbox assembly for this chair runs in the neighborhood of $1,400.00, or you can take the motor off and take it in for a full rebuild for about $250 or so. Unplug the joystick and remove the seat and cowl. Jack up the left side with both motors in gear. Remove the center nut cover and take off the nut holding on the wheel taking care to retain the key that slides into the groove on the axle. Disconnect the wiring plug to the motor and remove the six bolts holding the motor to the frame. Separate the gearbox from the motor and take the motor to a rewind shop for repairs. Reinstall and it should be good to go.
Posted on Jan 08, 2010
jyackle5
  • 8197 Answers
SOURCE: i am in need of
You can get the manual on the link below for your chair.
NOTE: The following procedures refer to the Pronto. R2 and the Pronto. R2-250 Series
http://www.rentascooter.com/downloads/_manuals/invacare/Invacare%20Pronto%20R2%20Owner's%20Manual.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Aug 13, 2010
Testimonial: "such a quick response is very appreciated an directions to the correct web site. thank you very much for a job well done."
  • 692 Answers
SOURCE: acs typh. invacare electric wheelchair, red light
Press the power button on then press the horn button twice before ten seconds. this should unlock the joystick
Posted on Aug 17, 2010
  • 347 Answers
SOURCE: Where is the reset button
Hello,you are my reason for being here,especially anyone with a wheelchair,i have a scooter myself & know what its like not to have your wheels.Please rate me as in thumbs up 1 to 4 for my answer.
Visit:WWW.ALLDATASHEET.COM Type in the right boxes-troubleshooting_2007 SHOPRIDER.pdf.It is 36 pages long 1 to 4 covers batteries,5 covers chargers,6 to 18 covers scooters & 19 to 36 covers wheelchairs & im sure you will be happy to see the part that you need to know about.Save it as a PDF File to your Adobe Reader + as i done print +save it to a polythene sleeve folder for future.Have a nice day i was so happy to have helped you,Colin.
Posted on Oct 08, 2010
Key flashing red on Invacare acs wheelchair controller
hi count the number of times it flashes and check youre owners manual for a fault code....try this site manual-Invacare www.invacare.com.au ...cheers
May 07, 2016 | Invacare Health & Beauty
How do I troubleshoot m51 pronto scooter. When I plug it in there is no lite and of course it does not run
  1. Pronto M51 Troubleshooting‎
    Adfixya.com/Pronto+M51+Troubleshooting‎1000's Solutions
  2. Troubleshooting Tips
  3. Free Diagrams
  4. Free User Guides
Service Indicator Light Diagnostics - Invacare Pronto M51 ...
www.manualslib.com > ... > Pronto M51 > Maintenance manual
Invacare Pronto M51 Base Manual Online: Service Indicator Light Diagnostics. ... Invacare power wheelchair owner's operator and maintenance manual.
Dec 25, 2015 | Health & Beauty
When I turn my wheelchair on a service indicator light at bottom of joystick blinks 9 times. How do I fix this?
If: Battery indicator flashes the charge level is low
immediately after recharging.
Then it is a. Weak Batteries.
b. Charger malfunction.
c. Electrical malfunction
Solution a.Replace batteries.
b. Replace charger. Contact Dealer/Invacare.
c. Contact Dealer/Invacare.
I got the above from the manual. The link is:
http://www.invacare.com/doc_files/1125085.pdf
Regards
Chellakumar
Jun 13, 2014 | Invacare Pronto M51 Power Wheelchair
Pronto M51 feels forced when driving it.
The squealing noise is probably a bearing either in one of the four smaller tires called casters. The problem will not likely cause a break down right away but should be checked by someone mechanically inclined or trained in power wheelchairs. I don't know what you mean by the chair being "forced". Need more info.
May have something to do with batteries.
If the chair is driving slower and batteries are new their is a recall for that joystick from Invacare. Invacare is replacing joysticks for free.
Dec 15, 2013 | Invacare Pronto M51 Power Wheelchair
How do I find an electronics manual for the codes for the electronic on my daugters m51 wheelchair.
The complete service manual and diagnostic codes for this chair can be found at the following link:
http://www.invacare.com/doc_files/1125075.pdf
Hope this helps.
Jan 29, 2011 | Invacare Pronto M51 Power Wheelchair
Manual for Pronto M51 wheelchair
Hi. We can supply, but try your local Invacare dealer. If you have luck, send us an email,
scooterworks@xnet.co.nz
May 18, 2010 | Invacare Supply Group Invacare Pronto M51...
PRONTO M51 FEELS LIKE I AM DRIVING OVER ROUGH ROAD AFTER REPLACING THE BATTERIES. WHY?
If you chair was down for a long time before getting new batteries the tires could have developed flat spots on them. Also could have brush problems in the motors that make the motors run jerky from sitting too long.
May 02, 2010 | Invacare Supply Group Invacare Pronto M51...
Health & Beauty Logo
23 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
