Question about Sewing Machines
Hi, I get an error, the presser foot is too high. I have a Viking Sapphire 855/875. Any help is greatly appreciated.
  • 3 Answers
SOURCE: Presser foot down, but still get error "E1"
I had the same problem. It started after I took the cover off to fix something else. After I screwed the cover back on, I kept getting the E1 message even when the foot was already down. I took the cover off again, and I found that there is a metal tab at the top left of the front cover, that is pushed by a metal tab in the back that moves when you put the presser foot up or down. You can see this metal tab moving in the back if you put the foot up and down with the cover off. Just putting the foot down(I think) before putting the cover back on fixed it so one metal tab is on the correct side of the other metal tab.
Posted on Aug 04, 2008
JeremySew
  • 65 Answers
SOURCE: need presser foot holder
Here are the parts you need:
Brother Sewing Machine Presser Feet & Shanks
Posted on Jan 05, 2009
  • 27 Answers
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Posted on Jan 14, 2009
  • 152 Answers
SOURCE: The feed dog is not grabbing the material or the
The little white button on the lower right front of the machine is the button that drops the feed teeth. If it is pressed in the feed teeth are down, push in a lift upward to be sure it's in the "Up" position. Then look on the left side of the machine, you'll see a dial, (NOT the dial facing you as you sit in front of the machine) make sure the red dot on the dial is lined up with the red dot on the painted part of the machine.
Finally look at the dial on the front of the machine. The one with the little button in the center of it. Put it on the number 3. If your machine doesn't feed fabric after doing what I've outlined then you need to take it in for service.
Posted on Oct 23, 2009
SOURCE: The presser foot lifter of my Singer 9432 has disconnected
Had the same problem.
Open the cover where the light bulb is.
Follow the presser foot rod up into the machine.
You will find a metal keeper with a set screw facing the now open end of the machine.
That set screw has most likely come loose.
Since the presser foot is spring loaded to the down position leave the presser foot raising lever in the down position.
With your flat bladed screwdriver, gently push the metal keeper to it's lowest position. If it does not go easy, loosen the metal keeper set screw a bit. Lefty loosey.
Tighten the set screw on the metal keeper. Righty tighty.
Posted on Jan 03, 2010
Error message foot too high. To correct this, it is necessary to restart the machine. Unless it is impossible to continue sewing.What is the problem?
Try taking your presser foot off and lower the presser foot lever. Does the error code go away? The machine won't sew without the presser foot to hold the fabric down, but without threading the needle, will the machine run without the presser foot? Now try the standard presser foot (usually J ) and if you get the error code then the sensor at the top of the presser foot assembly is out of adjustment. Without knowing more about your machine this is all I can suggest.
Good luck,
Bob
May 30, 2017 | Sewing Machines
Viking sapphire 830. Cleaned bobbin case and cannot get bobbin functioning normally. Bobbin thread in big snarl as it Sew's.
Is it actually bobbin thread that is "barfing?" Check closely. If it is under the fabric, it is most likely an upper thread problem. Remove all the thread from the machine. RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point between high & low numbers--this may need to be tweaked for your particular machine. Verify the bobbin is loaded and threaded correctly.
Understanding Thread Tension Threads
Mar 10, 2017 | Sewing Machines
Viking Husqvarna Sapphire 830. I am not able to get a true 1/4" seam using the clear 1/4" Piecing Foot with Guide. The needle space in this foot only allows for the needle to be in the center location. ...
Unfortunately, in reality, most 1/4" presser feet do not guarantee a perfect scant 1/4". There are multiple ideas for achieving a more accurate scant 1/4" seam.
This is the method I use. Use a quilting ruler and place it under the presser foot and then gently rotate the handwheel until the needle point rests exactly a scant 1/4" from the ruler edge. Then place a strip of painter's tape on the sewing surface adjacent to the edge of the ruler. Then use the painter's tape as your fabric guide.
Scant 1 4 seam allowance
How to sew scant 1 4 inch seam Kreations by Julz
What Is Scant
Nov 29, 2017 | Sewing Machines
Changing a presser foot on classica 100
Look at this page for a visual to help you determine the type of "shank" you have.
http://www.clotilde.com/pages/which_foot.html
Sep 08, 2012 | Husqvarna Viking 1
How do I move the presser foot on a Husqvarna Viking Emerald 116 sewing machine?
Not sure what exactly you need to know. Are you trying to lift the presser foot or change the presser foot to another one? If it is lifting, there will be a lever of some kind behind the machine. On one of my Husqvarna machines it was a big flat "paddle" shaped lever, not sure what shape it is on the Emerald machines. Lift the lever from the bottom upwards and outwards. Most Husqvarna machines have clip on-and-off feet. You just gently pull forwards on the foot (while the presser foot is raised) to remove it, then push the new one on making sure the small bar part of the presser foot goes into the clip on the presser foot ankle.
Jun 16, 2010 | Husqvarna Viking 1
Presser foot control -- Viking Husqvarna #1 sewing machine
There is a presser foot pressure dial on the left end of the machine, make sure it is on 3 or higher.
May 23, 2010 | Husqvarna Viking 1
Pressure foot too high cannot be lowered
sounds like the pressure foot lifter is stuck. Usually the height of the pressure foot is a manual adjustment done by a service technician. Suggest that it be serviced by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Feb 09, 2010 | Husqvarna Viking 1
I have a husgvarna viking 830. I was working on
If the lever to lift the presser foot is now just loose, take the face cover off (Left side aound light) and take a look, presser bar may have over extended and fallen off the lever connection...needs to be taken even higher as the lever is eased back and reset to "normal"
Sep 01, 2009 | Husqvarna Viking 1
Sewing Machines Logo
71 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
