Question about Dishwashers
I have a brada ep9242aww dishwasher, the door seems ajar 1/4 inch and it wont start when you press power it beeps and turns off again
5 Suggested Answers
fgainer
  • 54 Answers
SOURCE: Power on Press Start.Lights flash. Close door . Fails to Start
Possible causes
1. Main switch is OFF.
2. Door not properly closed.
3. Fuse has blown.
4. Power supply plug not plugged in.
5. Water tap not opened.
Please check these and let me know if any have worked.
And please remember to rate me.
Posted on Feb 02, 2009
lindsay836
  • 677 Answers
SOURCE: My door ajar lights wont turn off.
I do not think it has anything to do with the door. I think you should put a scan tool on it and see what you pull for codes.
Please let me know.
Posted on Feb 08, 2010
tbreeze47
  • 3083 Answers
SOURCE: brada dishwasher ef2401 wont start wash cycle
If it's under warranty, get someone to look at it. Probably a bad switch or sensor in the unit, could be something simple, and they're not hard to open up, but the soap dispenser mechanism has to be reassembled (it often falls apart upon taking the door apart). Last resort is the appliance serviceman. New house? New dishwasher? Warranty? That's your best option.
Posted on Mar 14, 2010
GodBlessU
  • 3513 Answers
SOURCE: I have F&P DD603 with
Hi
When you pull out the drawer, pay attention to the bottom near the bottom front panel, you will see a little tab. this tab is at both sides of the drawer, press these tabs in and pull the drawer further a bit, you can see the tub move out a little further. Now lift the tube up and out ot the rails. Push the rail inside the dishwasher, then you will be able to put the drawer down on the floor. Don't try to pull the tube out so much since hoses are under the tube has a limited length.
This dishwasher has a diagnostics mode which can be entered but you need the service manual which is attached to the back wall inside the cavity ( you can see it if you pull the drawer all the way out but you cant reach it without removing the drawer from its roller guides.) You can enter the diagnostics mode by pushing keylock,and holding it in. Then push and hold start/pause in that order. If you push start pause first it just counts through a delay start.
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 31, 2010
Snowmaster BD60DE keeps on beeping while doors are shut
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1 Cause of Beeping Noise in Frigidaire Refrigerator eHow
Feb 19, 2017 | Refrigerators
Where can I find replacement wheels for a brada portable dishwasher model EP9242AWW?
1. Google: "Brada Dishwasher Parts" and select one of several options
2. Amazon is also advertising appliance repair parts.
Pete
Sep 28, 2015 | Dishwashers
How do I fix a buzzing sound in my fridge?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Apr 09, 2015 | Refrigerators
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
Brada portable dishwasher EP9242AWW
The pump is blocked or not working
Apr 13, 2014 | Frigidaire Dishwashers
I have a Kenmore elite dishwasher about 5 years old and it will not start. The clean button keeps blinking green. Tried resetting power and still it will not start.
Makeing sure you have power is my first step.
Ensure the door isn't ajar is another possible fix...(check that door switch.)
Pressing the start / resume button again after these steps are done is all Ive got left.
I hope this helps.
Jul 17, 2011 | Kenmore Dishwashers
F 4 is comming up on the time delay button of my dishwasher and the wash wont start whats the problem
This means that the Dishwashers has detected a condition it needs to check. Press "Cancel" to clear the display and to stop the beeping sound, then try turning the Dishwashers off and on again. If you still see the "F," turn off the power to your Dishwashers and wait five minutes before turning it on again. If you hear the beep or see the "F" when you try to washing again, please call your authorized provider for service.
Hope this help?.
Please rate thumb.
thanks for visit.
Dec 15, 2010 | Whirlpool Dishwashers
Brada dishwasher ef2401 wont start wash cycle
Mar 13, 2010 | GE 24 in. Profile PDW7800 Built-in...
POWER ON-PROGRAM WONT WORK
1. No power to the dishwasherMake sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Aug 10, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Dose not finnish washing and starts bleeping and start light keep flahing. water is hot by have not dryed
Neighbor had a similar problem with a GE dishwasher except it wouldn't start and kept beeping when door was closed. So the door was left closed, and while it was beeping, turned off the circuit breaker that fed power to it. Waited about 30 seconds, turned circuit breaker back on, bleeping had stopped, dishwasher was reset. Normal and heated dry were already selected, (since I had tried pressing those two before all this to force a reset), then pressed start and it ran again. Hope this might help you.
Jul 25, 2008 | Whirlpool Dishwashers
Dishwashers Logo
27 people viewed this question
Top Dishwashers Experts
Owen Barnes
