Question about The Kitchen Appliances - Others
The depress lever will not stay down when depressed. Have to hold it down to toast.
4 Suggested Answers
  • 3 Answers
SOURCE: Bread won't toast
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down.
My husband took the cover off and found that a magnet is what keeps the lever down when the toaster's on, and allows it to go back up when the toasting is done. It's an electro magnet that works only when the toaster is on. It seems that when I turned the unit upside down and rightside up again, crumbs landed on the magnet's contact plates (which are about 1/4" x 1/2") and would not allow the magnet to engage. Because the magnet wouldn't engage, the lever would not stay down, and the toaster shut off. Brush off the magnets, replace the cover and toast away!
Posted on Jan 09, 2009
dcramer531
  • 1654 Answers
SOURCE: toast will not stay down in toaster when lever is
Most times this is caused by a build up of crumbs in the bottom of the toaster. There is a small electo magnet that holds the lever down, if it gets covered in crumbs it won't work. Take it outside turn it upside down and bang the heck out of it till everything comes out. If this does not work then check and make sure the magnet is still attatched inside. Other than that, this toaster gets terrible reviews from folks with issues just like yours. I can only assume the electronics are failing on these units far to quickly. It can be repaired if yuou send it in to the manufacture but that is really not economical. I hope the upside down banging cures the problem.
Posted on Jul 03, 2011
walesarumi
  • 6993 Answers
SOURCE: Lever won't stay down. If I keep holding it
while the lever is pressed down, there is a metal inside the toasted that locks it and debars it from coming up, so it would stay down.
From the look of this, this metal maybe broken, or fallen off. The unfortunate thing is that there is no such part sold, so you just have to manage or manipulate using the toaster if it happens that the metal is broken.
Turn off the toaster, remove it from the wall, get a Philips screw driver, disassemble the toaster to gain access to the lever and press the lever down and see what making it not lock. If you don't see anything, then metal holding it may have fallen off, or the lever may have work.
What you will have to do now is that whenever you press the lever down, you can use something like a think paper or small stick or copper wire to shock the lever. This would prevent it from coming back up. It would make the lever stay hooked downwards. So when you are through, you can remove whatsoever object that you used in hooking the lever.
I hope the above is clear.
Good luck.
Posted on Jul 20, 2011
How can I fix? 2 slice toaster: cannot maintain lowered position to toast!
These are not repaired just replaced unless it is a commercial unit.
May 23, 2018 | Kitchen Appliances - Others
Repair of model 553 krups toaster over. Lever will not stay down to toast
if there is a open circuit the lever will not stay down. hold the lever down check if the elements glow , most times it costs more to fix then a new one.
May 05, 2018 | Krups Toaster Ovens
Control lever does not remain depressed
Over manual use can damage the unit over time. There could be particles tucked under the latches, contacts, and other attachments. Clean the catch tray and turn the entire toaster over and shake it violently. If you have vacuum with air OUT and you can place the hose up to the slots, blow from both the top and bottom to push out debris.
Feb 27, 2014 | Bodum Bistro Toaster
Craftsman lawn tractor parking brake won't engage
are you holding the lever while lifting your foot of the pedal?
Jun 27, 2012 | Garden
Lever will not stay depressed
Hello. The first thing to try is to set the toasting level to a darker setting. Often this alone will solve the problem. If not, the mechanism which prevents burning or even a fire is simply worn out and it is time to buy a new toaster. J.
Aug 04, 2010 | Tefal Avante Elite Programmable - 2 slices...
The lever won't stay depressed
mcdevito75 here, The lever mechanism could be worn OR the setting for darker / Lighter toast is set to Light, swtch to darker see if that helps.
Jun 22, 2010 | Breville CT40 Retro Classic 4-Slice...
When I depress the carriage control levers they do
my toaster did this once, i suggest that you get a new toaster from a different company, because if you've only had the toaster a month
and its doing this already that's a crappy toaster
Apr 20, 2010 | Cuisinart CPT-180 Metal Classic 4-Slice...
Braun 550 Toaster
Return it to vendor for replacement.
Small electricals such as Toasters, Kettles, Computer parts, Audio & Cameras and the like do not get repaired - they get replaced and the seller is the place to go.
Jan 24, 2008 | Kitchen Appliances - Others
Bread won't toast
Dec 27, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Bilral
Level 1 Expert
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
