Question about Watches
I need to reset chronograph to 0 but have no instructions to do so.Serial number is 98208M-OS20 Thanks.
indays
  • 111 Answers
SOURCE: 10 year old alarm chronograph
good morning ! your anadigi chronograph 388 is veery easy to operate,just change the battery then short the reset button the fix the case back and set the time use the crown and the button to set the time calendar and the alarm !thank you ! god bless !....
Posted on Sep 02, 2008
SOURCE: Chronograph hand not resetting to 12 o'clock
for my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Posted on Jan 16, 2009
escapement
  • 2334 Answers
SOURCE: need instructions to reset sub dials on Nautica Chronograph watch
Pull out crown to the first click and push and hold pushbutton at 2 or at 4.
Posted on Mar 22, 2009
  • 12 Answers
SOURCE: how to reset hour dial on Men's Invicta 9212 chronograph
See page 26.
http://www.invictawatch.com/support_files/instruction_manual/Manual-HiRes.pdf
Posted on Jul 15, 2010
  • 2501 Answers
SOURCE: I need a Manual for
Their web site is not too helpful, as you may have already discovered!
Try going to http://www.ellessetime.com/ sellect the appropriate region and contact their customer service. They should be able to help.
Posted on Sep 04, 2010
Need a user manual for the time magazine free chronograph watch
I have NO ideal what kind of watch it is so I am giving general chronograph instructions. You will have to use as it applies to the watch you were given.
These instructions are provided for users who are not familiar with using a mechanical/analog chronograph. The instructions may be applied to any chronograph that has a seconds counter, 30 minute counter, and hour counter.
Please refer to the instructions of the appropriate model to determine the location of each counter on the dial. Note: some of the features described here may not be available on your particular model. Again, refer to the specifications to see if they apply to your model.
Using the chronographe functions:
How to read the chronographe:
For a chronographe that has a center seconds register, a 30 minute register and an hour register. Example 1: If the hour register is between the 1 and 2, but closer to the 1, and the minute register is at 20, and the seconds register is at 35, then the elapsed time is 1 hour 20 minutes and 35 seconds. Example 2: If the hour register is between the 1 and 2, but closer to the 2, and the minute register is at 20, and the seconds register is at 35, then the elapsed time is 1 hour 50 minutes and 35 seconds.
How to read the tachymetre:
If you are driving and want to determine the speed of the car using your tachymetre, start your chronograph when you pass a mile marker, stop your chronographe when you pass the next mile marker. Look at the center seconds hand and read the number on the Tachymetre scale, this number will indicate the miles per hour that the vehicle is travelling.
How to read the pulsometer:
Some watches have a pulsometer instead of a tachymetre. Use it as follows: Start the chronographe and begin counting the pulse. When you have counted 30 beats, stop the chronographe. The number on the pulsometer scale will indicate the pulse rate per minute.
How to read the telemeter:
Some watches have a telemeter instead of a tachymetre or pulsometer. Here is an example of one use for a telemeter: Start the chronographe when you see lighting. Stop the chronographe when you hear the thunder. Read the center seconds hand on the Telemetric scale and the number will indicate the distance separating the observer from the place where the lighting struck. This can give you a good indication of how far off a storm might be.
The many uses of a chronographe:
A chronograph has many practical uses, from timing a plane flight, a car ride, or simply being curious. There are also some uses for the chronographe that may not be so obvious. For example, you can use the chronographe on your watch as a dual timezone indicator. This is done as follows: If it is currently 6 A.M. in your home location and it is 12 noon in London, start your chronograph at exactly 6 o'clock. The number of hours displayed on your chronographe hour register will then show you the current time in London. Of course, these are just some uses of a chronographe. There are hundreds of uses for chronographes.
Instructions: Astronic Chronograph Chronograph Chronometer Power Reserve Chronometer Astronic Chronometer World Time Chronometer Retro Alarm General Chronograph Common Q & A's
Aug 12, 2010 | Watches
My watch has had the battery changed and when you reset the stopwatch, the second hand and the small hour/minute hands no longer rests on 12. How do I reset these hands
I have the same problem with my Seiko Coutura Chronograph. Ever since battery was changed, the stopwatch resets to 32' 8" instead of 0'0". How to re-zero the hands?
May 08, 2010 | Watches
My analog stopwatch needle at 11 instead of 12o'clock
The procedure for the Classima Chronograph watch is different. You need to pull the dial all the way out, press on both buttons and hold for 5 sec, until the seconds dial makes a full cirlce (signalling that the chronograph is now ready for manual reset, then press the button on 2 o'clock until the seconds dial reaches the 12 o'clock position, then press button at 4 o'clock, to transfer control to the 1/10 dial, press button at 2 o'clock again a number of times until it resets to 0, then press 2 o'clock dial again to transfer control to the little hours dial, and press 4 o'clock button number of times until you reset this one to 0 too. Now just push back the dial crown to original position to close the operation. Viola
Dec 22, 2009 | Watches
Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
Nov 20, 2009 | Baume Et Mercier Baume & Mercier Hampton...
Does not reset to 0
Follow this link:
http://www.pulsarwatches.com/home2.asp#FAQ
Click on appropriate tab and download full instructions.
Rate me, please.
Mar 24, 2009 | Pulsar 100 Meter Alarm Chronograph PF3277
Sep 01, 2008 | Casio DW290 1V Classic Alarm Chronograph...
Reset
you are so screwed. go to '0'.com
Jan 01, 2008 | Baume Et Mercier Hampton Milleis MOAO8242...
Feb 23, 2007 | Kenneth Cole KC1232 Wrist Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
