Question about The Kitchen Appliances - Others
My pressure cooker went in to E4 mode what's the problem, I can't cook for that reason .I did all the cleaning, still not working. Worried?
SOURCE: E4 on the Woldgang Puck Electric Pressure Cooker
I fixed mine by elevating it 4 inches (E4) and dropping it on the counter. Something needed a little impact adjustment!
Posted on Dec 31, 2009
SOURCE: e4 code on model epc460 pressure cooker
I have a programmable pressure cooker with no instruction manual. The model number is EPC460. It was made in China and just says Perfect Programmable Pressure Cooker. Can you help me find a user manual for this. I can't find anything online or by googling it.
Thank you
Posted on Oct 27, 2010
tunde007
  • 2382 Answers
SOURCE: E4 error on pressure cooker,
Hi, the problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. You will probably have to change the switch.
Another way to get rid of the code temporarily is to open the machine. Let it cool off by washing the lid and pulling the pan inster out of the base and let that cool as well. Then unplug the machine and basically start all over. The error will go away after some time.
Posted on Jan 04, 2011
ZJLimited
  • 17970 Answers
SOURCE: cook's essential pressure cooker has
Make sure the inner container is dry... plug he unit off then on again.
Eventually, the "E4" display would appear. I determined the steam vent valve (loose piece) was not seated on the vent hole in the cover so the pressure never built up. I removed the loose piece which consists of a metal cylinder and a black plastic cover with a handle.
Posted on Apr 23, 2011
danwat1234
  • 18 Answers
SOURCE: My Wolfgang Puck pressure cooker shows 'E4' in the display.
There doesn't seem to be any legit way of fixing this. I tinkered with the pressure sensors and valves, kicked the pressure cooker a few times, still the E4 error presented itself.
I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this.
The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook.
Pics of process:
http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
Posted on Sep 19, 2012
E4 message on toastmaster pressure cookerwhat am I doing wrong have used p cooker before and it worked fine
Instruction manual below states:
The LED display shows E4 error.
Unplug the power cord from the wall outlet. Wait approximately 15 minutes. Plug the power cord back into the wall outlet. Press "CANCEL" button on the pressure cooker. Select cooking process to begin cooking. If problem persists, contact customer service at (800) 365-6133 ext. 120/107/105 for a replacement thermofuse.
http://www.qvc.com/footers/cd/pdf/K44020_OwnersManual.pdf
Feb 22, 2018 | Home
My Deni electric pressure cooker is showing E4? Cannot cook?
An E4 Error for your Deni means that there is a signal switch error. Turn off the pressure cooker, un-plug, and wait for it to cool. Then, try again. If it continues to give you the E4 error I would recommend contacting the manufacturer - but, unfortunately, Deni has gone out of out business.
Here is the manual for your pressure coker, if you don't already have it:
http://www.hippressurecooking.com/category/manuals/deni/
Mar 18, 2016 | Kitchen Appliances - Others
Cooks essentials manuals
Well, it depends on the model, I looked the digital pressure cooker manual (found here http://www.hippressurecooking.com/category/manuals/cooks-essentials/) E4 is a Signal Switch Malfunction. The recommend turning off and un-plugging the pressure cooker and letting it cool of completely before trying to use it again.
Aug 12, 2014 | Cook's Essentials CooksEssentials 3 Quart...
When I try to set the time on my electric wolfgang puck pressure cooker, I get an "E4" and a beep. What is the problem?
I actually have one I use all the time at home. We LOVE it but this seems to a common issue.
the problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time.
I have come across this error when I am cooking rice and then trying to pressure cook something else immediately after. I have found that If I release the pressure valve and manually let the steam release, then my chances of getting the getting the E4 errror are less, but it recommends not to do that. :( Another way I have gotten rid of the code was to open the machine. Let it cool off by washing the lid and pulling the pan inster out of the base and let that cool as well. Then I will unplug the machine and basically start all over. The error will go away after some time either way, it's just unfortunate that it can't go from meal to meal when you have several different dishes you need to make. Don't THROW away your machine with an E4 error, just give it time to reset
Apr 07, 2011 | Vacuums
Displays E2 and E4 (5 qt Wolfgang Puck pressure cooker - silver) what section is problem mechanical or electronic?
I think E2 means open circuit in thermocouple in center of bottom. E4 means no contact on pressure sensing switch at edge of bottom. Mine had E4 error. Took out switch and used fine sandpaper to clean contact points. Now it works fine.
Remove 3 screws in bottom. Remove bottom cover by turning it ~1/4" to clear tabs. Remove switch at edge of bottom with two blue wires going to it. Clean contacts and replace.
Jul 10, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Displays e4 wont work
Removed the 3 screws on the bottom. There is a relay near the circuit board. Kind of looks like an old morse code relay. Just tapped out "E 4" in morse code. Plugged it in and it works fine.
May 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Pics of process:
May 10, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
Mar 18, 2009 | Wolfgang Puck Electric Pressure Cooker...
E4 code on model epc460 pressure cooker
Thank you
Jan 21, 2009 | Cook's Essentials Cooks Essentials Arome...
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Bilral
Level 1 Expert
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
