Hi sir my problem in indoor light flashing - Heating & Cooling
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
I have two flashes on the timer light of my indoor unit of Fujitsu Inverter ASU9RLS
Serial signal (reverse) error, at operation start up. operation led - off, timer led - 2 flashes, coil dry led - off, check wire between indoor and outdoor
Jul 10, 2015 | Fujitsu ASU9RLS2 Single Zone Wall Ductless...
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
Fujitsu heat pump flashing code?
Test the fuses for the outside unit.
Aug 29, 2017 | Heating & Cooling
The unit either encountered a brown out or a surge which burned up the board for the condenser. It had black marks on the board and the indoor unit was flashing. Replaced the board and the unit is still...
After replacing the burned condenser board, check also the entire condensing unit if still ok ( compressor and fan motor). If the light inside the indoor unit is still flashing, the timer is still not giving signal for the compressor to start. Adjust temperature and wait for 3-5 minutes. It light continue flashing, there is something wrong with the indoor unit control.
Sep 02, 2011 | Sanyo Split System Air Conditioner
Hi. When I use my Olympus SP 570 UZ in an Indoor Party Hall, I get Orange Tinge or Orange Coloured Photographs. Please Help me to avoid this,
This is called "white balance"-- the indoor lights have a bit of a yellowish tint, while sunlight has more of a blue tint.
Try changing the white balance to Auto-- if you get bad results on Auto, try using the Indoor or Incandescent settings. You may have the white balance set on the "outdoor" or "flash" setting.
Mar 06, 2011 | Olympus SP-570UZ Digital Camera
Its not working and flashing P6. Its a Mr Slim
dear sir/madam i think.... mr Slim A control R407c & R410a systems.
P6 = indoor coil frost protection in cooling or indoor coil overheat protection in heating.
Cooling
One of the 2 indoor coil sensors reads minus 15 deg C for 3 mins.
Heating
One of the indoor coil sensors reads over 70 deg C.
If you are sure the refrigerant charge is correct & system operation is correct then it could be a coil temperature sensor reading wrong temperature.
If you have one of those little monitor things which plug into the outdoor circuit board you can monitor the indoor coil temperature.
On later type remote controllers you can get all operating data like temp sensor data but you will need a service manual to do this.
Or you can measure the ohms resistance of the temp sensors & compare with the chart in the service manual. if you can do it by yourself do if not then contatct ot mitsubishi maintenance personnnel for furhter action, thank you hope answer the question please vote!
Sep 23, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
My Amana asx 16 seer 4 ton system installed 3 years ago quit working. The alert light is flashing 6 times. What does this mean?
Hi if you are looking at the indoor unit and this is where you see this flashing light, remove the panel. The circuit board is where this led light is. You will also have a 3 to 5 amp fuse plugged into the board. Look for a chart on a panel door. It will be glued there. It will tell you what the problem is according to how many times it flashes. Could be several different safety switches. Make sure there is no door panel switch on the indoor unit, has if there is, the unit will not run after you remove the panel, it kills power to it. You may need to tape it down so you can have power to run it and check it out. Is the indoor unit a gas system or is it a 4 ton heat-pump? If you cant find what I have said, get back to me after checking these things and let me know . Check all breakers. Let me know if this is a package unit or a split, indoor and outdoor unit, or all in one. I will wait to hear back from you on this.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Jun 29, 2010 | Heating & Cooling
Fujitsu asya09lcc wallmount split lights flashing indoors
According to the service manual page 8, the unit has an 'indoor unit control error'. Below is the link to the manual. Hope this helps. http://www.oceanairdist.co.uk/assets/pdf/service/Fujitsu/ASYA09LC.pdf
Mat
Jul 04, 2009 | Fujitsu 24R1 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
