Question about Garden
How do i check/change the hydrostatic oil in my ranch king 16.5
  • 153 Answers
SOURCE: ranch kind 16.5 horsepower riding lawnmower
A dead battery would be top of the list by far, followed by solenoid, keyswitch, wiring, starter in that order.
Posted on May 29, 2009
iambanshee74
  • 3489 Answers
SOURCE: I have a 2008 F-450 King Ranch, Diesel. How much
the oil filter is located in the centre of the engine in a canister and about 15 quarts.
Posted on Nov 04, 2009
sscullys
  • 984 Answers
SOURCE: how do I change out the dome lite on my 2005 150
For a 2005 MY F-150 :
The rear ( if SCab or SuperCrew ) there is a little notch in the lens that is used to push in a tab and lower that side, slide out from the back.
The front, non rail system is open the rear sunlgasses compartment, and grab each corner. Pull down, there is 4 or 6 spring clips that hold the overhead console to the roof. Once down, you will see the gray bulb holders. Twist out the bulb holder, and the bulb plugs into the holder. They are 2 element over sized 194 type bulbs ( think it is a 39 or 67 ??? not sure on that ).
Rail system is slightly different
Posted on Jan 05, 2010
  • 146 Answers
SOURCE: i am trying to find info for a ranch king pro rear
Looks like Ranch King Pro is made by MTD. The part is probably the same, but to be safe, take your old cable off and take it to a lawn equipment service shop to match it up. Shouldn't cost more than $10 - $20.
Posted on Jun 04, 2010
  • 731 Answers
SOURCE: 2 or 4 cycle oil for a Ranch King 6.0 lawn mower?
If you mean oil for the crankcase use need 4 cycle oil Ususally 30 weight and don't over fill Most small engine do not even take a quart only about 20 oz.
If you mean to mix with gas ( I doubt this) but then you need 2 cycle oil depending on the mixture usually about 3 oz to a gallon of gas (3.2 oz / gal = 40:1 ratio, 2.5 oz/ =50:1)
Posted on May 24, 2011
Testimonial: "Thank you for your assistance. Now, the blade will not turn. I can just barely turn it manually. What can I do?"
When I start my ride able Ranch King Mower I get white smoke. I just had the oil changed & they did a Compression test - 100 psi and it is good. They did a leak down test 100 in -90 hold and it is
I only use 10w30 in my shop, and also have you checked to see if they over filled the crankcase with oil. The dipstick must pe pushed or screwed all the way in to check the oil..
Nov 24, 2014 | Garden
How do I find an inline fuse for a mtd ranch king 38inch 14hp riding mower
it should be under the cover right between your legs when you are sitting on the mower
Nov 15, 2014 | Garden
I want a drive belt diagram for a ranch king pro riding mower?
It's easier to find the correct information with a model number.
I have found a owners manual listed under MTD 130-390A
owners manual for a 2002 ranch king riding lawn mower.
Hopefully this is the same as yours.
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1GGGE_enUS385US385&ion=1&espv=2&ie=UTF-8#q=ranch%20king%20riding%20mower%20manual
Pages go right and left or click on download.
Aug 28, 2014 | Garden
Wheels for ranch king push mower 6.0 22 inch cut
Try EBAY,type in Ranch king wheels and see what pops up !
May 20, 2014 | Mtd Garden
I am trying to find info for a ranch king pro rear tine tiller, the engagement cable is broken and i can't seem to find any cable to replace it with or anything about a ranch king pro tiller, the engine is...
Jun 04, 2010 | Garden
I have a 2008 F-450 King Ranch, Diesel. How much oil does it take and where is the oil filter located?
Nov 02, 2009 | 2008 Ford F 450 Super Duty
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
