Question about Coffee Makers & Espresso Machines
Jura Impressa E8 keeps saying Clean Machine even after running the clean cycle. Does anyone have any suggestions?
SOURCE: Jura Capress Impressa E8
Open the drawer and take out the box for the grounds. Run a rinse cycle and it should now go back into place.
Posted on Jan 11, 2009
SOURCE: Jura Capresso C3000 keeps saying clean unit
We have the S8 here at our office. Ran the cleaning cycle and "Clean Now" message was still on and beeping afterwards. Read the Feb 28 comment and carefully cleaned everything that had grounds stuck to it. Ran the cycle again and it worked. Thanks all.
Posted on Dec 15, 2009
CoffeeLoverZ
  • 33 Answers
SOURCE: impressa E8: even though I did clean machine, it asks me again...
Make sure your water tank to fill, when you start the clean process, and the tray is empty and wiped down. Then add a 500ml container under the spout rather than let the water go into the tray.
Also if you have not serviced the machine for about 5,000 cups this can occur.
Posted on Feb 13, 2010
SOURCE: Does anyone know how to take apart Jura Impressa
I hope this Jura F90 dismantling guide may offer some clues for your E-series machine. Before you start remind yourself of the risks. In case of a mess up, below I've listed a firm selling spares in Europe. In the UK it is assumed that it you can afford the BMW of coffee machines, you can afford to fix and service it too. However I haven't tried any of the servicing firms so they, and yours could be really, really helpful and cheap. You will need about 4 different torx; hexagonal and possibly unique screwdriver bits to remove all screws. A plastic pry tool (used for mobile phones) will help where plastic lugs hold on the side and top panel. Empty beans; water store and remove the waste tray. On the Jura F90 use pliers to undo two oval headed screws at the back at the top. You'll be able to remove the top panel after using a pry tool to disconnect two lugs at the front edge. You don't want to dismantle the coffee grinder and its hopper. Retain the hopper's rubber seals or glue them in place before you lose them as I did. Four screws hold the central back panel. Slide out a white key underneath the machine (can't recall how crucial this was). The side panels are removed by using a pry tool to release lugs all down the edge where these panels meet the front. Work slowly to manoeuvre the side panels off. If you simply want to clean the brewing unit externally then just remove the panel on the water side. Find the water inlet just where the water tank sits. A screw here allows you to remove a plastic piece - but take a photo of how it slots in. This gives access to the lower end of the brewing unit. If the plastic piece is still it the way, you can ease off the water pipe from the water inlet and put it aside. A number of different brands are made by one firm and branded. Thus the guts of these machines are similar. The brewing unit in the Jura F90 is almost identical in many machines. The screws and attachment places are different. The water inlet and valve are different. Cleaning the parts you can now see may fix a Malfunction 8 without removing and dismantling the brewing unit. The machine is partly operable in this state - cover the exposed electrical connections and remind yourself of the danger here. Thus you can switch off the power when the brewing unit's white wheel is at the top and then at the bottom. In this way you will get access to places causing any jam. You might just need to clear the inner chamber and path for two plungers with two large O-rings. You can see the water inlet nozzle with its o-ring which can perish and cause coffee or water to go to waste. Silicone grease only where the O-rings slide. Leave the other plastic parts ungreased. As I said you might get away with not disassembling the brewing unit. You can however buy a maintenance kit or a new brewing unit from the shop below. You will want to avoid removing the nylon water pipes - unless they're actually leaking. These pipes are held in place with a wire clip (remove with a flat head screwdriver). Ease the nylon pipe with its brass collar out of its socket. The pipe goes into an O-ring in the pipe's socket - this might fall out. Removing a brewing unit is like removing a car engine. The link at the shop below has a pdf (Anleitung_Jura_E.pdf) There is no need to force anything. On the Jura F90 the brewing unit is removed by undoing two obscure screws from the coffee grinder side. I had difficulty removing these and I wish I had taken time to find the right tool instead of wearing down the screwhead. On the electronic side there's an optosensor (encoder) unit held in place with a steel clip. You might remove this to access one of the two screws. At the bottom of the brewing unit, the water inlet valve is fixed to the machine with a single screw. Next, on the water tank side, you'll see two lines of screws that hold the assembly in place. The middle screws of the screws allow you to separate the unit from the gears. The top two holes don't have screws. Coffee machine spare part supplies are not as common in the UK as they are in mainland Europe. You'll find this web useful because of the pictures: www.kaffeemaschinendoctor.de is a German web shop for machine spares AND there's a pictorial of how to dismantle the Jura F90 as a pdf. Google will almost translate it). Juradoctor.de also carry lots of spares but don't seem to ship to my country.
Posted on May 09, 2010
  • 18 Answers
SOURCE: Impressa S9 keeps beeping "clean now". Have run
There could be several reasons for this problem but I can only think of the following:
1.) The internal sensor may have gone "bad". The sensors are sensitive and prone to failure. But before you give up, see #2 & 3 below.
2.) A few things to check:
- Make sure you are using the recommended white cleaning tablets*. If the tablets aren't used then there may still be oil build-up in the brewing chamber.
- When indicated during the cleaning cycle, be sure to remove the tray and bean container for at least 20 seconds and then replace, even if they are already empty.
*Cleaning tablets can be ordered from www.capresso.com.
3.) If you don't have cleaning tablets on-hand then you can try running a regular brewing cycle using white vinegar** instead of water. Follow with at least 2 cycles of clear water (to rinse) before brewing your first cup of java.
***This method is probably not recommended by your manufacturer. I have used it on my machines without incurring any problems but I can't guarantee that it's safe for your machine.
Additional resources:
The entire pdf instruction manual for your machine can be downloaded from the following website: http://www.capresso.com/pdf/s9_instructions.pdf
Good Luck!
Posted on Jun 24, 2010
It has error 8 on it what do u think?
Jura Capresso Impressa E8 Espresso/Coffee Maker Error 8 ...
www.fixya.com > ... > Jura Capresso Impressa E8 Espresso/Coffee Maker
Jura Capresso Impressa E8 Espresso/Coffee Maker, error 8 related issues. Get free ... We have just done a full disassembly, cleaning, and relube of our Jura Z5 ...
Bosch Benvenuto B30 Espresso/Coffee Maker Error 8 ...
www.fixya.com > ... > Bosch Benvenuto B30 Espresso/Coffee Maker
Jan 14, 2016 | Coffee Makers & Espresso Machines
Jura Capresso E8 keeps getting error code 8 over and over. I will clean, remove grounds etc, it will make a few espressos, then back to the error code. I can hear it struggling.
One of the problems that I see with these units is the Grinder setting. Sometimes the grinder is set too fine for Dark and Oily beans. This setting will ( can) clog up the brew screen after less than 10 cups are brewed. Also, running the cleaning tablets through to create a clean starting point may help you. Try turning the grinder to a slightly coarser setting and try that.
Sep 21, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Stuck in cleaning mode?
Open the preground coffee lid, drop a cleaning tablet in it, let it do it's tablet cleaning cycle. After cycle empty water out of tray and clean.
May 16, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
Cleaning instructions for jura E8
I am not sure if you are referring to the standard clean that the E8 requests. If that is the case the instruction are to press the rinse button for 5 seconds, until it asks you to remove the tray, then follow the instruction on the screen (they are normally, rinse, rinse, add tablet (should be Jura one) - add to powder shoot, then the process runs through.
If you are talking about de-scale then you should us the Jura de-scale tablets, but vinegar and biccarb can also do the trick.
Feb 05, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Impressa E8: even though I did clean machine, it asks me again...
Mar 23, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Feb 28, 2009 | Jura Capresso Impressa S8 Coffee Maker,...
My dispay on my jura E8 says error 5.
Simple fix - got the machine serviced, needed a new thermoblock apparently, could also have been one of the couple of sensors they replaced. Total cost including box, bits and carriage - £180 plus change.
Expensive but now I have it back, it all seems worth it!
Nov 30, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Rinse error
I'm not exactly sure what was going on as I tried again to push the rinse button possibly a little harder this time and now it is working fine.
Sep 26, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Clean machine/machine ready light won't go away
Have experienced the same problem for the last nine months. Was finally able to solve it today by following this guide: http://www.wholelattelove.com/articles/jura_capresso_cleaning_guide.cfm
Having cleaned the shower screen I ran the regular cleaning cycle and now the display indiucates "Ready" as it should do.
Sep 07, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Coffee Makers & Espresso Machines Logo
57 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
