Question about Select Health & Beauty
Please tell me where the free wheel lever is located on the Jazzy Select scooter. I don't have a manual to look it up. Need to know where to find it. I don't even know what it looks like.
  • 175 Answers
SOURCE: have jazzy select series need to know flashing Code #9
Consult your owners manual for the flash code guide. I believe that you probably have a PG Drives Joysitck/Controller, in which case a 9 code would indicate problem with the brake system. Check the free-wheel levers by placing them in the neutral position, and then firmly placing them back in drive. Try to restart. If still flashing, you need to remove the seat and the shroud and examine the connections inside the base of the chair. The brakes are at the end of the motor, and there are thin wires coming from them back to the controller box. Inspect these wires for any damage, and follow them back to make sure any connections on the way are tight, and that the connections for all clip connections are tight.
The brake is electrically operated by a solenoid. If the solenoid has gone bad, then this will also cause a fault code. Contact your dealer for servicing this part. Good Luck.
Posted on Jul 09, 2009
SOURCE: The free-wheel lever will not release.
I had same proble - spray some lubricating oil on the lever, let it sit for awhile, than GENTLY tap it with a hammer. Worked for me
Posted on Oct 02, 2009
  • 692 Answers
SOURCE: jazzy select contol panel all leds flash 9 times,
Bob on each brake at the motor there is a micro switch that the controller gets connection info as to wether or not the chair is in freewheel. I have seen these switches break and therefore the controller thinks the chair is in freewheel. you could also have a bad brake solenoid that is not activating the brake when you try to move. I think the micro might be the problem because you say it flashes 9 times as soon as you turn it on. You can get just the brake assembly from Pride instead of buying the whole motor/gearbox assembly. You didn't say if you bought the chair or Medicare. If Medicare did then they will pay for most of the repair you can contact your provider or a repair service Repair Xpress @1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
Posted on Sep 13, 2010
Ironfist109
  • 3018 Answers
SOURCE: I have a pride gogo
  • What that flash code indicates that there is that the battery voltage is to high to operate the scooter. This can happen for a number of reasons and from out of no where. The manual says you should contact GoGo for this problem. But I know a couple things to try and if they do not work then you need to contact GoGo.
  1. First remove the battery connectors for 5 full minutes and see if that resets it.
  2. You may have a wire that got caught up somewhere so check all wires for breaks in the insulation, cracks etx.
  3. Check the fuse as well.
  4. Push in the main circuit breaker reset button (see diagram)
  • Here is the GoGo Pride Scooter website should you need to contact them and if what I listed does not work then you need to. The things I list are some at home troubleshooting tips GoGo does not offer. They say to contact them immediately. http://www.pridemobility.com/contact.asp
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Jun 16, 2011
SOURCE: Fault codes jazzy 600 power chair
8 lights flashing how can i fix it?
Posted on Sep 20, 2011
What batteries do I need for a jazzy select6 pride
information and batteries for sale.
info
Jazzy Select 6 - Specifications, Owner's Manual, Features & Benefits
www.pridemobility.com > Jazzy Power Chairs > Models
  1. Cached
  2. Similar
In-line motor technology for increased efficiency, torque and range. Built with ease of service in mind. Easy side access batteries. Tool-less front panel access to ...
[PDF]Jazzy Select Series - Pride Mobility
www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_select_series_om.pdf
  1. Cached
  2. Similar
6 www.pridemobility.com. Jazzy Select Series. II. SAFETY. Do not connect an extension cord to the AC/DC converter or the battery charger. Removal of ... Batteries for Sale
Pride Mobility Jazzy Select 6 Ultra Wheelchair and Mobility Batteries at ...
https://www.batteriesplus.com > Batteries > Wheelchair and Mobility > Pride Mobility
  1. Cached
  2. Similar
If you rely on a Pride Mobility Jazzy Select 6 Ultra powered wheelchair or personal mobility scooter to get around, Batteries Plus Bulbs can help you find the ...
Pride Jazzy Select 6 Power Chair from Pride Mobility ' 1800wheelchair ...
www.1800wheelchair.ca > Brand Showcase > Pride Mobility > Pride Powerchairs
  1. Cached
The Jazzy Select 6 Power Wheelchair from Pride Mobility is the ultimate ... Easy side access batteries; Full-length, flip-up armrests; Solid flat-free tires; Foot ...
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca ...
https://www.amazon.ca/Jazzy-Select-Scooter-Battery-Charger/dp/B00CIZ1GW6
  1. Cached
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca: Sports & Outdoors.
Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery
https://www.amazon.com/Mobility-Jazzy-Select-Wheelchair-Battery/dp/B009DKGCC8
  1. Cached
Rating: 5 - ‎1 review Buy Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery - This is an AJC Brand® Replacement on Amazon.com ? FREE SHIPPING on qualified orders.
ALL THE INFO HERE BELOW
Google
Nov 24, 2016 | Pride Health & Beauty
My sonic 3 wheel scooter will not go status light blinks 3 times the 1 time,3 times then 1 time ect, batteries fully charged unit is in gear what is wrong
Pride Mobility Products Corp. - Product Owners Manuals ...
www.pridemobility.com > Resource Center
Pride MobilityProduct Owners Manuals & Specification Sheets ... Jazzy Elite ES PortableSpecifications ... I 02/03. Jet 3 Ultra ... Travel Scooter Throttle Control Lever OperationProduct Insert .... Brochures · Owners Manuals · Basic Operating Instructions · BasicTroubleshooting Instructions · EMI / RFI Information · Warranty Information.
Sep 25, 2015 | Pride Sonic 3 Wheel Portable Scooter
My Go Go Elite Traveller Plus is not working. The freewheel lever is locked, but it is beeping 5 times, and the owner's manual says that # of beeps means it is not locked! Can anyone tell me w
Hi you need to check the switch located on the brake , this can stick fooling the controller into thinking the lever is in free-wheel when in fact it's in drive mode...
press the little switch in after spraying with WD40 or any contact cleaner...repeat this to make sure the little switch is releasing fully.
Regards
Rob
www.gewizrepairs.co.uk
Jan 02, 2015 | Pride Go Go Elite Traveller Plus HD 4...
The right side is disengaging. It goes around in circles to the right.
Go to Pride Mobility Products Corp Basic Troubleshooting Instructions This page can assist you. There is also a lever to disengage the wheels that allow the chair to be rolled when not powered. Look at your manual to find the location.
Nov 02, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Where is the freewheel lever located on the jazzy 1113?
Original Jazzy Select has push-down levers on each side behind powered wheels. These manually disengage the brakes on each motor individually. They are about 6 inches long and push down an inch or so. I don;t know about other more current models, The 2 smaller wires to each motor disengage the brake when given power (24 volt, I think). The 2 larger wires run the motor.
Jun 17, 2012 | Pride Jazzy 1113 ATS Indoor Power...
I do volunteer work for a non-profit organization in Milwaukee that recycles donated power wheelchairs, scooters and other medical equipment. I have been tasked with finding and printing battery...
Hello mmcpowers,
For the Pride Jazzy wheel chairs you can locate what you need at the Jazzy website at the following link http://www.thescooterstore.com/products/product_manuals.aspx
When on the site you will locate the chair you need and the wire diagrams are in the owners manuals. As a common problem is just a plug coming un-wired they tell you where they are and the wire configuration. If you tell me some of the other chairs you are dealing with I will try and locate the website for them as well.
Thank you for choosing FIxYa.com
Jan 10, 2011 | Pride Jazzy 1103 Ultra Standard Power...
I haVe two golden companion scooters that worked Perfectly. One day they just quit running. I know that when the light blinks a certain number of times in the manual it tells you what's wrong. Both of mine...
Hi. 5 flashes on some scooters is the fault code for brake coil open circuit. This usually means that the free-wheel lever is in the wrong position.
Someone might have moved the levers so that they could push the scooters, and forgot to put the levers back to the correct position.
This fault code can also mean that the solenoid coil is faulty, but 9 times out of 10, it is the lever in the wrong position.
Good luck. Neil.
Jun 12, 2010 | Golden Technologies Golden CompanioN II -...
Have jazzy select series need to know flashing code #9 purchased new batteries
Jul 09, 2009 | Pride Mobility Products Jazzy Select
How to push the jazzy wheel chair when power fails''
There are two levers located on the base of the chair on the left and right sides. Depending on the model, they will be located on top of the base on the front section of the chair base, or on the rear or on the lower sides. Most rotate 90 degrees to disengage the gears so you can manually push the chair. Others are moved up and down, or in and out. Return them to the locked position when done.
Jul 01, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Health & Beauty Logo
Top Select Health & Beauty Experts
wcdoc1953
wcdoc1953
Scooter Doctor
Scooter Doctor
Colin Taylor
Are you a Select Health and Beauty Expert? Answer questions, earn points and help others
