Question about Cub Cadet Garden
I have a cub cadet 173cc ohm,how to start it - Cub Cadet Garden
  • 10865 Answers
SOURCE: will not try to start acts like spark plug isnt firing
Change the spark plug and the air filter. Also be sure the gas is new. If the gas has been in the mower all winter drain it out and put in fresh gas.
Posted on Apr 21, 2009
  • 246 Answers
SOURCE: i have a cub cadet model 3 1042 it starts but
Hello
After the Engine Stalls, Check the Plug for Fire. If No Fire then the Ign Module/Coil is BAd and Requires Replacing.
>>The Following is a Basic Instruction File I made for this. Any Input is Appreciated. I Usually Suggest you Check the Following in this Order for a Problem like yours. 1- Check the Gas Tank Cap and Ensure it is Venting the Tank. A Vacuum Builds in the Tank and the Gas Flow Stops or Slows (15 to 45 Minutes and if the Small Grainular Sand is in the Tank it can Take Several Days of Constant Running to Bring All the Sand Particales to the Tank Outlet Port) to a Point it Shuts Off the Engine. 2- Operate the Equipment Until it Quits (15min to 1hr). Then Immediately Check for Fire from the Plug. If the Plug is Firing, then 3- Check the Carburetor Solenoid. If the Carburetor Shut Off Solenoid has Current, then Remove the Carburetor Solenoid and Go to the Hardware Store. Purchase a Bolt of the Same Diameter and Threads. It Needs to be 3/4" Long. Put this Bolt in Place of the Solenoid. If this Corrects the Engine Problem, then Replace the Solenoid. ***NOTE: THIS IS FOR CHECKING THE SOLENOID ONLY I NEVER SUGGEST YOU OPERATE THE ENGINE WITH THE SOLENOID OUT OF THE CARBURETOR EXCEPT FOR TESTING PURPOSES*** Sometimes the Plunger is Moving, Just Not Far Enough to Allow the Gas to Enter the Jets. 4- Depending on the Model Mower, it can Also be the Pickup Tube in the Gas Tank. If No Fire, then Remove the Shut Off Wire from the Coil and Check for Fire. If Still No Fire, then the Ign Module or Coil is Bad. **Even if the Coil is New of Fairly New, it can Still be Bad.** On JD Mowers; Remove the Igniter/Module and the Coil and have the Local JD Dealer Test them.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
moretons
  • 155 Answers
SOURCE: valve lash setting cub cadet push mower 173cc
should be set at 0.004 thou
Posted on Jul 27, 2009
  • 28 Answers
SOURCE: i have a cub cadet push mower with a 173cc ohv
most likely a sheared flywheel key, pull the cover off the flywheel and remove the nut that holds the flywheel on. The key slot in the flywheel should line up with the key in the crankshaft if not pull the flywheel and install a new key, or take it to a small engine repair and they will do it for you. If the key is good, reassemble the flywheel nut etc and check for spark at the spark plug and see if the spark plug is wet with gas if you have spark and gas and the flywheel key not sheared and it still won't run, you may have an internal problem
Posted on Oct 03, 2009
woobie dog
  • 1273 Answers
Is it the pull rope that broke?
--W/D--
Posted on Jan 21, 2011
Cub cadet riding mower blade will not engage
be sure battery is fully charged, check the switch and clutch.
Jul 07, 2017 | Cub Cadet Garden
Cub cadet model LGTX1050 blows 20 amp when key is turned to start position.
You will have a short that is causing it to blow the fuse. Check and make sure the battery is correctly installed. Red + and Black -. Other than that you would need a ohm meter to track it down. It can be several things. Hope this will help ya
May 20, 2017 | Cub Cadet Garden
Cub cadet 173cc ohv engine is not self propeling
it is either the belt or cable. Remove the belt housing and see if the belt is in place and in one piece. move the propel lever back and forth with the motor off and see if the opposite end is moving like it should at that connection.
Jul 20, 2014 | Garden
How do i check it the battery is being charged up on a cub cadet 2140
pull the positive side of battery get a ohm meter start it read the voltage should be 13 volts
Jul 09, 2014 | Cub Cadet Street Sign- tractor lawn riding...
I have a Cub cadet LT 1024 which will not start. The solenoid clicks like it is trying and lights will come on but that is only reaction. Battery is brand new and hooked up properly.
solenoid clicks, only tess you the coil is working inside the solenoid. disconnect cable from battery to starter. with ohm meter check for continuty across main terminals of solenoid while holding key to start. if no continuity, solenoid is defective.
Apr 29, 2010 | Oregon Scientific Electric PTO Clutch for...
Will not try to start acts like spark plug isnt firing cub cadet cc500 173cc/6.75ftlbs push mower
Apr 21, 2009 | Garden
Garden Logo
35 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
