Question about John Deere Garden
I have a john deere x320 it has no spark but when i unplug black wires off coil it fires right up works fine what could be wrong and can i just leave them off and run it
    An user who is expert in 3 categories / brands.
  • John Deere Master
  • 924 Answers
There is a bad safety switch somewhere. but no it wont hurt anything.
Posted on Apr 30, 2017
I have a john deere 737 mower and it started running on one cylinder. I bought a coil for it and put it on and had the same problem. so I looked into it a little more. I am not getting any spark at all if...
You have the wiring hooked up wrong. The way you have it is grounding out the coil that isn't working. I have ran into this problem at our shop only once. Only after contacting tech support was I able to get it right. Unfortunately I cant for the sake of me remember how I did it. I do remember that when I got it right, it didn't look like it would work. I am frustrated at my self for not being able to remember.
Oct 30, 2013 | John Deere Garden
JOHN DEERE LX172 has no spark replaced coil still no spark why?
take the wire that goes to the coil off and try it if you have spark with the wire off the problem is with a safety switch or wiring
May 18, 2012 | John Deere Garden
John deere 116 briggs & straton wont get spark. new coil, still nothing. will try to bypass seat safety switch.
there is a black wire a that goes to the ignition on the side of the engine next to the manifold unplug that and see if you get spark with that off if you do follow that wire back to the safety switches
Apr 06, 2012 | John Deere Garden
John Deere 318 with an issue
black smoke is over fuelling and not spark related
check / clean carby especially the float, needle and seat area
Nov 23, 2017 | John Deere Garden
My x320 will not fire. I changed gas , plugs and filters. Charged battery and checked all fuel delivery devices. I have spark , gas , and air but it will not fire
Is the Sparkplug cable getting fire? To check it pull the cap off of the plug. carefully pull the cap back to expose the snap ring. hold the wire part with insolated pliers (it will bite if hot) close enough to the head (metal part) to get about a 1/8 in gap between sparkplug snap and the head While in a poor light area or dark. have someone turn key. you should get a bluish spark. if not check for a burnt inline fuse. fuse is good then replace sparkplug wire, voltage regulator and coil. best to do all 3 because if one is bad the working parts were over working while the failing part was weakening. Good luck!
Nov 07, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
John deere x320 will not syart. if one coil ground is disconnected it will start right up. if started this wsy the pto will not engaage.
The wiring harness under the engine shroud that feeds both coils has a diode on each of the wires that connects coils.The diodes keep each coil from grounding each other out so when one diode goes bad it will only run on the cylinder with the strongest coil.Order new harness from Deere,cost less than $30.
Jul 02, 2009 | John Deere 3010,3020 Tractor Basic...
I need a john deere X360 44" front blade
you can buy it on ebay right now!
here's the link:
May 10, 2009 | Garden
JD mower-only one coil firing
I just switched the coils around. The other cylinder went dead, so I knew I had a bad coil. Replaced the coil and mower runs great.
Apr 01, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
57 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
