Question about John Deere Garden
John deere 240 garden tractor will not go in 6th gear all other gears work
  • John Deere Master
  • 7,515 Answers
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure.
Best Manuals
Posted on May 15, 2017
  • 5 Answers
SOURCE: I need a drive belt diagram for a 1642 Scotts John
Try this site:
Posted on Nov 23, 2009
  • 52 Answers
SOURCE: John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Posted on Apr 18, 2010
Testimonial: "Thanks for the ideas. I will try your suggestions. Tractor used for snow blowing during the winter and gas did not stay in it long. Good ideas!"
  • 3 Answers
SOURCE: john deere 445 tractor v twin 22 hp engine, john
Where did you get it fixed for $300. Dealer wants 6 hours labor and $400 in parts. Total cost will be $1,000.
Posted on Jun 05, 2010
  • 156 Answers
SOURCE: tractor won't go in low gear or reverse
I had the same problem and replaced the shifter which I found at
This fixed all the speeds and now it runs great.
Hope this helps
Posted on Jun 08, 2010
Daniel S
  • 4323 Answers
SOURCE: John Deere Model 445 garden
Please check for the anti back fire solenoid in the front of the carb. Check whether the wiring to it is fine and if it is getting +12 V. If yes then you maybe required to replace the solenod.
However, if this doesn't resolve the issue then you would need to adjust manually so that decompresser works normally. Inspect the flywheel key as well, it may have sheared.
Check the carb filter and the make sure there is no sign of water in/around the carbeurater. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Posted on Aug 05, 2010
How to access gear box on john deere 2040s tractor.
unless you have lots of mechanical skill you can not do it it requires splitting the tractor in half with stands and rollers .
Aug 01, 2016 | John Deere Garden
How many gear boxes are there on a john deere f725?
The only gear box is the one on the deck. The drive for the wheels are hydraulic pumps and motors.
Jun 28, 2016 | John Deere Garden
How do i set timing gears for a john deere 2020
I'd suggest going to John Deere's website and look up an owner's manual and repair manual . If you have Adobe Reader you can copy it in a PDF format.
May 12, 2014 | John Deere 420,1020,2010,2020,2510,2520...
My john deer won't go in to gear. It starts and
the drive and the mower deck use different belts
Apr 12, 2012 | John Deere Garden
Sabre lawn tractor 1438 gear manual
John Deere Sabre 1438, 1542, 1642, 1646 Lawn Tractor Service Technical Manual TM-GX10238 * - Download Documents / eBooks
hello arthur, john deere does not post manuals on line,this is all i could find or see your local dealer,hope this helps..
Feb 18, 2012 | John Deere Garden
My john deer tractor does not move. it only makes this clicking sound
Are you sure you are "in gear"? I have beat mine to death ... but it still runs. The gears are pretty tough, but they are not invincible. It is possible you have a stripped gear. If necessary, get replacement parts at your hardware store.
Aug 16, 2011 | John Deere Gilmour Traveling Sprinkler -...
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
