Question about Boating
Speed not showing on my 561. Apparently needs secondary transducer, where can I get One?
Garmin 551s sonar stopped working, no bottom definition or ability to see fish GPS charts and speed all work It shows 3 step image repeats top of the screen / water surface has the transducer packed
Check you transducer cable route and connections. Look for kinks, punctures, & tears in cable. Visually check the transducer for damage. #2 check the units operation on a friends boat with the same set or research a local marine repair shop to check ops. Best of luck on the problem.
Jan 11, 2016 | Garmin Boating
Hummingbird 561 only will read 1 ft on the water
Is you transducer fully plugged in? Also the boat has to be in the water for it to work.
May 08, 2014 | Refrigerators
The unit loses the signal at higher speeds
The signal loss is due to the transducer not in the water. Suggest remounting the Xducer an inch or 2 lower to be in water when you plane out at full throttle.
Sep 04, 2013 | Humminbird 561 Fishfinder
I need a longer power cable for my humminbird 561, is it possible
don't splice them bad bad bad call hummingbird order you a set of power cables
Apr 11, 2013 | Humminbird 561 Fishfinder
How to install transducer
Transducers usually have a 6 degree tilt down looking from the boat .
Dec 22, 2012 | Humminbird 561 Fishfinder
My marine speed transducer needs to be replaced. I have a Beneteua 351 which is 16 years old. I have cleaned the transducer several times and then reinstalled. It will work for a couple of minutes and then...
Yes. You need to make sure you get the same transducer though. With you system being that old, you may have a transducer that is old where there is not a direct replacement. You need to make sure you get the correct transducer. You may need to get a "flapper" kit to update your housing to the new style.
Jun 15, 2010 | Raymarine St300/P371 Speed Nylon Thru Hull...
With alcx-27c with gps do i need a transducer with the speed on it? or will my gps give me the speed my boat is traveling
The unit will give you speed over ground directly form GPS. there is a difference between Speed Over Ground (SOG) and ocean speed. Ocean speed will only be available from a paddle wheel type transducer.
Aug 10, 2009 | Lowrance LCX-27C GPS Receiver
383c transducer gives nothing but noisy red feedback at medium or high speeds
If it works at low speeds fine but has problems at higher speeds, basically you need to lower the transducer down further as it is lifted by the boat at higher speeds, or is getting caught in the turbulence of surface water created at higher speed. Lower the transducer a half inch at a time and re-test.
Sep 19, 2008 | Humminbird XNT Transducers XNT 9 20 T ...
Installing an old used lowrance fish finder
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
Apr 26, 2008 | Lowrance LMS-332C GPS Receiver
St60 wind instrument
You might want to double check that all of the spade connectors that are used to plug the wind transducer into the ST60 wind display are firmly plugged onto the display's terminals.
Because of the blind connection, sometimes the terminal ends up lodged between the red insulator and the spade, rather than within the spade connector itself. This results in intermittent or missing readings from one part of the sensor or more.
Also make sure the display is in Master mode. You will need to get into its setup mode to confirm this. The other possible mode is repeater, which would be used if this were a secondary readout.
Dec 13, 2007 | Raymarine ST60 A22012-P GPS Receiver
Boating Logo
Top Boating Experts
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
