Question about Health & Beauty
My scooter is charged but won't move - Health & Beauty
Pace saver iii repairs
Make sure the battery is properly charged. A discharged battery will light up the lights but do nothing for the motor.
Jul 16, 2015 | PaceSaver Plus III Titan 3 Wheel Travel...
Mobility scooter
Check the freewheel lever is not engaged.
Jun 03, 2017 | Health & Beauty
Battery shows fully charged and the horn beeps but it won't move.
I have the same problem in mine.. But the beep is continous. Mine is a fortress 2000 AT. anybody knows what's the trouble on this one?
Jan 12, 2013 | Electric Mobility Health & Beauty
Won't move with charged batterys
Hi, any bleeping, flashing lights , double check the freewheel lever,
1. Any clicking from the rear .
Please keep me updated.
Regards
Jan 10, 2013 | Pride Celebrity X 3-Wheel Electric Scooter...
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Aug 09, 2012 | Electric Mobility Merits Electric...
Scooter won't take a charge
scooter battries must be charged on a regular basis.or else the on board charger wont charge them .Try useing a trickle charger to bring them back to life. if you dont have access to one bring them to a local service station they should charge them for a small fee.
Jun 26, 2012 | Pride Sonic 3 Wheel Portable Scooter
I have a Schwinn S500 electric scooter.When you turn the power switch on the scooter will not run. the power indicator by the throttle jumps from low to medium charge. I charged the battery for the 8 hrs...
Hi Ron, for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. Good luck and have a nice day.
Sep 28, 2011 | Transport Schwinn Rechargeable Portable ...
Battery fully charged everything works but will not move completley dead
Hi za900
You have several options to consider.
1. Controller is bad. This can only be checked by putting another controller on it. There is no test for controllers.
2. If the charger is bad your scooter will not run.
3. make sure your brake is in the lock position.
4. make sure your scooter is not plugged into the wall.
5. If your brake is bad the scooter won't run.
6. If your Throttle engager is bad the scooter won't run.
Have a tech evaluate for you, too many things could be the problem.
Any durable medical equipment company in your area can help you.
Good Luck
Tim
May 03, 2011 | Electric Mobility Health & Beauty
T he unit will not start.Is there a safety switch.i do not have the manual .
Hi dma11955
Not much info to go by, but I'll try.
1. Make sure your batteries are fully charged, load test them if you are not sure.
2. Make sure the charger is not plugged into the wall. The scooter won't work.
3. Make sure the moter brake lever is in the locked position. The scooter won't move in free wheel.
4. If you don't have and indication of power most likely you have a bad controller. Can't check a bad controller, just have to replace it, they are costly, so try everthing else first.
5.Sometimes a bad brake or charger will give the same symptoms.
Good Luck
mimobility
May 02, 2011 | Health & Beauty
My aunt recently bought a secondhand scooter shoprider us pat no 4798255 without a users manual and the scooter will not charge please could you help?
Kathryn Was the scooter working when she bought it? If the batteries were fully charged and now it won't charge then I would suspect the charger. If the scooter wasn't charged when she got it and won't charge then I would replace the batteries Hope this helps
Apr 25, 2011 | Health & Beauty
Health & Beauty Logo
41 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
