John Deere 2950 Tractor Technical Manual TM4407 Reliable store is Your Only Source for Repair Service and Shop Manual Downloads Our Repair Manual Owner Manu
Could be the charge lube in the rear differential. It supplies oil to main Hydraulic pump up front on engine. The charge pump drive can strip and not turn pump. To remove pump drive remove third link plate on rear frame, remove plug behind plate, pull out hex shaft, about 5 foot long and inspect.
Lower load sense shaft seals are leaking.Remove bolts,small housing,washers,shaft then seals.You do need a special driver to get seals back in.Check load shaft for wear and when it goes back together make sure shaft goes bye the load sensor arm halfway through trans without to much force or you could damage load sense to rockshaft.This is a German made tractor.3150/2950
