Tv won't switch on. no red light - Televison & Video
3 Suggested Answers
  • 1039 Answers
SOURCE: tv wom't switch on
Replace capacitors on power board.
Posted on Sep 02, 2009
bugoy31
  • 1238 Answers
SOURCE: my tv showing an amber light instead of red standby light and now it won't switch on
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Jun 21, 2012
I have a Panasonic HDTV 1080p and it won't turn
You have a 5 year old projection TV with power supply trouble
Jul 13, 2013 | Televison & Video
TV Won't turn on, Has flashing red light.
Flashes of standby light is fault indication. Count it and confirm the number of flashes occurs at one time switch ON. If you wish to get more details about these blinking codes to Toshiba sets, check this link. Pull up older posts there.
Mar 02, 2013 | Toshiba TP50F60/61 TV
Philips 42PFL7603D/10 won't turn on flashes red 4 times slowly then red 6 times quickly
This is an indication of error codes for defects inside the TV. In order to ensure this is not caused by some erratic signal to system IC, switch off TV manually, Switch off power and remove plug and wait for 48 hours and retry. If it does not work even then, the TV might need service.
Aug 26, 2012 | Televison & Video
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
TV HAS RED LIGHT SHOWING WILL NOT SWITCH ON
Hi, The red light shows there is power connected to the set. The fact that it won't power up is due to a problem with the power supply circuit in the set. or a problem with the switch circuit or the mains power transformer. Regards John Ps don't know why they're giving me these questions, I answer questions on auto's
Feb 12, 2012 | Wharfedale Televison & Video
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Tv wom't switch on
Aug 29, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
