Question about Maytag Washing Machines
New maytag washer. Will not fill. Have water in hoses. No obstruction at intake. Starts, senses, locks lid but no fill. Mod MVWB765FW0
  • 1294 Answers
SOURCE: water leaking out front of maytag washer
Remove the top cover of the machine. Check to see if the three tubes going into the dispenser drawer hv not come loose. Tighten well.
Posted on Sep 11, 2007
  • 51 Answers
SOURCE: Clogged screen on water intake.
it should just come out with a nice firm, but gentle pull. problem is u need to be careful because if its that clogged up, its probably weak and might break. U can always just buy new ones at sears, or home depot.
Posted on Mar 13, 2009
dh1200s
  • 335 Answers
SOURCE: maytag neptune washer stops after filling
Hello n8mtsn,
I would pull the 120VAC power cord to the washer for 10 seconds then power back up.
See if you can get into service mode. To enter Service Mode press and hold he Enviro Plus and Spin Only keys for three seconds or until the control beeps and the display reads “00”. If you can’t get into Service Mode I feel you have a Control Board issue/failure.
If you can get into Service Mode then go to page 15 of the SM and we want to try a Quick Service Cycle test. Follow the instructions to enter the Quick Service Cycle test and let us know the results. If the test will run it will take about 10 minutes.
Link to Service Manual for reference. Sears Parts Direct for reference.
Rich
Posted on May 30, 2009
  • 220 Answers
SOURCE: Maytag Bravo Washer flashes F50 code
Most likely a bad machine control,can also possibly be a motor per whirlpool but I have never had to change a motor,changed a lot of machine controls.
Posted on Sep 01, 2009
SOURCE: Maytag washer filled with water then stopped working.
You can check the lid switches (they are paired) the following way:
1) take off the front and top washer housing panels.
2) look for the wire bundle coming off the lid switch and find the plastic pull apart connector.
3) undo the connector.
4) take an Ohm meter and check the resistance when the lid is closed: a) orange and black wires should complete a circuit, orange and pink should also complete a cicruit, all other pairs shold be "open".
5) check the resistance when the lid is open: orange and white should make a circuit, but no other pairs.
6) replace the defective switch, or replace the complete unit.
7) check the 250V 1A fuse in the left front, replace it if it has blown.
Good luck.
Posted on Dec 15, 2009
Maytag Bravos Quiet Series 400: F01 Error code
maytag washer with error code F01 means a obstruction in a hose or tube, not a control panel issue like people say. How can I clear the small tube? see pics
Dec 08, 2016 | Maytag Washing Machines
My washer wont leave sensing mode maytag bravos x model # mvwx500xw1
Shift mode sensor Orange thing at bottom of washer stuck on spin not shifting for agitation common in Whirlpool & Maytag and few others
Jul 04, 2016 | Maytag Washing Machines
Kenmore 11025102310 washer isnt working. I press the start button, and the sensing button lights up for just a second and there is a couple of minutes of a grinding type of noise but then nothing.
SENSING Page 5
When the START/PAUSE/Unlock Lid is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer will use short, slow spins to estimate the load size. These sensing spins may take 2 to 3 minutes before water is added to the load and you may hear the hum of these spins. If the sensing light is on, then washer is working properly. You will hear the motor turn the basket in short pulses to thoroughly wet the load. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: Avoid opening the lid during sensing. The sensing process will start over when the washer is restarted. The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
If there's no water, then Page 13
Washer won't run or fill, washer stops working, or wash light remains on (indicating that the washer was unable to fill appropriately)
Check for proper water supply.
Both hoses must be attached and have water flowing to
inlet valve.
Both hot and cold water faucets must be turned on.
Check that inlet valve screens have not become clogged.
Check for any kinks in inlet hoses, which can restrict water flow.
Or you have an inlet valve that is not working
Apr 29, 2016 | Kenmore Washing Machines
I have a maytag centennial washer MVWC400XWO it is 3 years old. The washer has stopped after the initial wash cycle leaving the cloths wet in a tub full of water. The washer will not go to the spin/drain...
For saftey the lid lock and lid down switch must be activated before the machine can advance to the next cycle. This has been the sequence for all top loaders..
Check the switch for the lid it is likely defective.
Make sure that the power is removed.
Simple repair by a qualified technician.
Hope this helps?
Jun 14, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag Neptune MAH8700A tha detergent drawer is filling up with water and running out of the drawer onto the floor not going into the tub.
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 11, 2012 | Maytag Neptune MAH7500WH Front Load Washer
Maytag Centennial washer mvwc400xw0 washer won't fill
It could be the door lock, the water valve, screens on hoses and valve, or the drain pump
Nov 05, 2017 | Maytag MVWC400XW - CentennialR...
My Maytag top load, looks like PAV2300 but not sure, will not rinse. The water drizzles a bit during the cycle and I hear the timer but the machine does not rinse. I cannot force it into rinse. I have to...
Hi and welcome to FixYa. I am Kelly
There is a water level pressure switch inside the top panel that has 3 wires on it and a vacuum line. That pressure switch controls the water inlet valve functions via the timer.
If by chance the pressure sensing line is getting hydraulically locked with water due to some form of obstruction it can cause the symptom you describe.
This pressure switch also controls the start of the spin once the water level has dropped (prevents the wash tub from being a water brake and damaging the motor clutch)
If the water level pressure switch is working normally then the only thing left is the timer.
You can do your own testing of the water level presure switch with an external vacuum hose (3 feet in length) connected in place of the machine hose. (DO NOT drop the machine hose when you disconnect it!)
1. place timer on wash and start filling. LID CLOSED
a. Force air orally into the external line
1) Result fill stops agitation begins
2. place timer in spin LID CLOSED and force air into external line until the pressure switch clicks.
a. START SPIN CYCLE NOW and listen for water pump out
b. release pressure on external air line
1) result tub starts spinning
If it passes the above tests your looking at a timer problem causing your no rinse situation.
Thanks for using FixYa!
Kelly
Feb 18, 2010 | Maytag PAV2300 Top Load Washer
I have a Maytag front load Mod. # MFW9600SQ1. When
This is actually a fill error, it appears when the tub should be filling and is not being sensed. Make sure that both hot and cold water is turned on. Since you do see water coming into the tub this is an issue related to your pressure switch. It sounds odd but this can also be caused by a siphoning drain so check to make sure your washers drain hose has only a little over a foot into the drain otherwise this may cause it to siphon and throw up the same error. If the water is on and the drain hose checks fine then I would guess your gonna have to replace the pressure switch but right now my money is on the drain hose being shoved to far down in the drain pipe. Hope this helps.
Jan 30, 2010 | Maytag EPIC MFW9600S
Maytag FAV 6800 leaks while filling
I was finally able to fix our leak. Noticed that when closed the back of the lid bent down a little toward the middle.  That was enough obstruct the water shooting into the lid causing it to spray out of the top a little and leak out the back alot.  Took the lid off, bent it back, and now it works!
Jun 15, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
172 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
