SOURCE: Activision Call of Duty 2
The msi.chm refers to the windows installer help documentation.Probably by any chance, the dvd is scratched making the that particular set of installation files unreadable. Try copying the disk contents to your hard drive prior to installation.Then make the installation from hard drive. There is no other solution because the Error itself is not clear.
SOURCE: hi i have call of duty 4 and played it many times
Installation is not the problem. It's the thing that it is OLD game already as people are on Call of Duty 5. Anyway, you might want to download this patch and see if it does the job: http://www.gameupdates.org/details.php?id=2548
SOURCE: When playing zelda in the wii sometimes i can save
If you save in a temple and quit, it will always take you back to the beginning of the temple. Even so, you keep your progress through the temple like rooms visited, chests opened, and keys found.
SOURCE: i can't playing the game
Hi
Please install the driver for you Nvidia fx5700 and try again your problem is fix
Cheer
SOURCE: Hi, The game, Nancy Drew: Danger
The first thing you should try, is to update both JAVA and Flash. If it uses those, that is likely the issue.
Here are the links:
http://www.java.com/en/download/inc/windows_upgrade_xpi.jsp
http://get.adobe.com/flashplayer/
Be sure to uncheck the boxes that install toolbars. Also, it wouldn't hurt to make sure that Windows is up to date. Click the Start button, click All Programs, and then click Windows Update.
