Question about Refrigerators
How do I remove the refrigerator from my 2015 KPTS. I think the water line to the ice maker froze and broke.
  • 878 Answers
SOURCE: water leaking onto floor
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. back.
Posted on Dec 22, 2006
Mine was slow-to-none in ice making for a couple of years. One day for the first time I used the built in water dispenser. The long copper line feeding water was full of air gaps. After I bled that out, it has been perfect ever since.
Posted on Sep 09, 2007
  • 3 Answers
SOURCE: water line to ice maker frozen
Check to make sure that the damper between the freezer and fridge is not broken or frozen open. Make sure that you shut off the water supply to the fridge until you get this fixed because the line could crack and then you could flood the house.
Posted on Jan 20, 2008
  • 1462 Answers
remove back panel inside freezer and there is a tray at the bottom with a drain hole in the middle. this is blocked with ice. melt off with a hairdryer and follow up with hot water till it flows waay freely
Posted on Oct 02, 2008
  • 700 Answers
SOURCE: the refrigerator icemaker does not make ice.
you have to hold in the ice type and the childlock button for about 6 seconds and that will take the filter light off. To reset the ice maker open the freezer door and then pull out the ice bin. on the bottom of the ice maker theres a button that you have to hold in to reset the ice maker. Good luck and thanks for using FixYa
Posted on Jan 21, 2009
Adora freezer on the bottom not making ice
It could be a couple of things. Check to see if the bar that controls turning the ice maker on and off is in the down position. Up is off. My ice makes water line froze in the refrigerator section; no ice and no clod water. Check to see if the cold water is working in the refrigerator section. If not, turn the refrigerator section temperature to 42, keep the door open until it drops to that temp, and wait 24 hours for the water line to thaw. The water and ice maker should start working.
Jul 12, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icemaker issues
If your ice maker still in guarantee or warranty period, then go to the seller and replace with a new one. If not then go to google and type in ice maker repairer in your area and you will find plenty of website of repairer.
Mar 15, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Water in door dispencer but no ice cubes in freezer
Remove the water line in the back of refrigerator going into the ice maker - its likely the line froze. Once thawed (about an hour) put the water line back on and cycle the ice maker - you should hear the water go into the ice maker.
Dec 17, 2013 | Refrigerators
Ice maker not making ice and water is not flowing
this could be several items so will go down the list in order... 1st you need to make sure you have a good clean filter or that it has been changed recently... sometimes removed and reinstalled will also help... 2nd do you have 120 volts ac current to the water valve when called for water example" someone pushing the water dispenser handle while you test... if you have 120 volts and no water coming you have a bad water valve... if the dispenser is working but the ice maker is not filling with water they do have dual water valves and one side can actually be bad... before shooting the water valve down though if your getting water to the dispenser but not to ice maker make sure the unit is actually calling for water... on most of these ice makers there is a gear motor on the front part of ice maker there will be a white cover over the front of unit remove it and turn gear motor makes sure it is not broke.. is there frozen water in ice maker if so may be the heater on ice maker is bad... if no water again before shooting down water valve make sure the fill tube coming into ice maker is not froze up...if it is froze up most likely you have a weak water valve and needs to be replaced due to not seating properly.... hope this helps hard to diagnose when not sure what all you have already tested or not...
Jan 01, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hi there, We are having problems with our ice maker on our GE Profile Model # SRD2054W, purchased October 1995. I know it's old, but it has been a good appliance until now. The ice maker fills but the...
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
Apr 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Remove the icemaker and check the incoming water line. It may be frozen.
This icemaker manual may be of some help to you.$FILE/4316835.pdf
Jan 17, 2010 | Refrigerators
PSW26P Dispenses no water, ice, or crushed ice.
Deforst you refrigerator the water line is frozen. However, my refrigerator line froze again and vegtable froze.
Aug 28, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker sprays water...
sounds like the inlet part on the ice maker is froze over or not lined up in the opening of it right or a possibilty that the ice maker is leaking out the water if that is the case the ice maker needs replaced
Jun 07, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Ice build-up in back of freezer
you probly got a water inlet spout froze over.. take out ice maker and look where water inters icemaker and see i that is froze
Aug 23, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
