Question about Coffee Makers & Espresso Machines
Dregedoor and descaling alarm lights both on and flashing quickly
A red light on the dash comes on and starts flashing quickly when I lock the vehicle using the remote key. Is it normal?
Well a flashing red light usually means the alarm system has been activated. Flashing quickly could mean it is faulty and the alarm is not set.
Dec 19, 2015 | 2001 Mitsubishi Pajero Pininfarina
While performing the descaling the brew group gets stuck
Have you check if the knob on the top of the machine to distribute hot water is fully closed. If on the edge, you may not get hot water flowing but the light may be on.
Look on page 12 of the manual. It explain the the meaning of the led flashing or stayed on from the control panel
Good luck
Aug 30, 2014 | Saeco Odea Giro Plus Coffee Maker
Water temp and descaling lights flashing
you need to descale the machine as per instruction
Oct 15, 2012 | Solis Palazzo Espresso Machine
Can you you tell me why there is a flashing red light on the coffee machine
Descaling light:
• on and fl ashing: signals the need to perform a descaling cycle
Machine ready light:
• permanently on: signals that the machine is ready for use.
• on and fl ashing: signals that the machine is warming up.
Alarm light:
• permanently on : signals the machine is out of coffee, the water tank is
empty, the drip tray is full or the dregdrawer is full (in this case, also empty
the coffee grounds drawer in order to prevent failures).
• on and fl ashing slowly: signals that the brew group is not inserted, the
dregdrawer is not inserted the coffee bean hopper lid is not on, the service
door is open or the steam/hot water knob is not correctly turned to the
desired position.
• on and quickly fl ashing: signals the need to prime the water circuit.
Jan 13, 2011 | Saeco Odea Go
Both the top alarm light for empty grounds in drawer and the bottom light which signals need to perform descaling are flashing when I press the brew coffee button, the middle lights for water level and...
When you press the coffee button , and the top and bottom lights are flashing, that means the grinder is either jammed or out of order. If the machine is less than 2 years old, the service center will replaced it under warranty.
Sep 14, 2010 | Saeco Odea Go
I have descaled it twice and the red light is still there
You have to press the hot water button for 10
seconds to disable the descaling
alarm.
The steam button on the left.
Feb 02, 2010 | Saeco Odea Go
Seaco Giro Quick Flashing Red Alarm
Bypass the door interlock with a magnet (the red light will go out when you have the magnet correctly placed above the group). Brew a cup and watch to see how the water is getting into the hopper. Once you know how it is getting into the hopper it should be relatively easy to determine how to fix it.
Apr 21, 2009 | Saeco Odea Giro Plus Coffee Maker
Red alarm flashing
The flashing indicator light means something needs to be refilled or emptied.
Oct 15, 2008 | Saeco Odea Giro Espresso Maker -...
Saeco Odea Giro descaling problem
Ok first check if the machine is in greenlight state when you press and hold the water button, as it will not work when the red exclamation mark blinking.
also check if the button work at all flipping back and forth to hot water and steam.
I have never had this problem that it dident work.
But remember this, you dont have to do the descaling again as that has nothing to do with the reset.
You can even reset the descaling alarm with out having done the descaling.
If that for some reason wouldent work I would think its the CPU card is not working.
Jul 14, 2008 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
35 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
