Question about Fisher Paykel EcoSmart GWL15
Smart Drive 601 would't stop draining
The drain pump of smart drive 601 wasching maschine recently got blocked by some bra wire. I took the pump out, removed the wire and reinstalled the pump. Since then the maschine doesn't stop pumping and wouldn't proceed or stop the program unless I unplug it from the wall. Plugged back in the maschine continous pumping and wouln't respond to any pressed button on the control desk.
Fischer and Paykel's hotline was completely useless as people are obviously unwilling to help.
Anyone out there who can help?
Cheers Florian
    Brigadier General:
  • 4,090 Answers
Florian i think you have a leaking seal at the pump. This will allow air to leak in and the pump is no longer able to sense when the wter is no longer there as it ****** air. the pump relies on a vacuum sensor that causes it to shut off and then resume the next cycle
Posted on Aug 02, 2009
    President:
  • 2,923 Answers
With the machine plugged in and turned on, what to do is to press and hold down the start button, then press and hold down the power button (hold down for 5 seconds) the washer may beep up to 3 times during this process.
Next remove fingers from buttons, then turn off machine with the power button, then turn on again and only press the start button this will now reprogram the computer let it run untill end of cycle and this should fix prob.
If this would not resolve the problem, you need to contact an expert to check the control board to see if the control board is malfunctioning or not.
Hope this helps and have a great day!
Posted on Jul 25, 2009
Drain pump will not drain tub,but if i place drain hose on ground,tub drains with full hose.is the pump belt drive,or transmission shaft driven.thanks bob
check underneath but normally the pump is a stand alone unit at the bottom of the tub
it gets its power from the program board when it is progressed from wash to spin
problems that stop it from working mostly come from items stuck in the pump impeller preventing the motor from spinning
look for coins , hair pins , bra wires etc that get lodged in the pump housing
Oct 18, 2016 | Maytag Washing Machines
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Jun 21, 2017 | Fisher and Paykel (IWL12)
My smart drive 5 fresh wont spin
You should be getting an Error code 37 pump faulty.
37.
(00100101) Pump Blocked Error (No change in the water level)
While draining, the water level reading from the pressure sensor has not changed for over 3 minutes. There are three likely reasons for this fault. One is that the drain hose or the pressure switch hose has been squashed or kinked and the pump out rate has been dramatically reduced. The second possibility is that the pump is partially or fully blocked. The third is that the pump is not operating due to Motor Control Module, wiring or pump failure. This fault could also appear if the machine is pumping to an unusually high head of drain hose or into an extended length of drain hose. The fourth possibility is a diverter valve fault or blockage, water level is not altering as the diverter is stuck in the recirculation mode, giving the module the appearance the pump is not lowering the water level.
Primary Source:
Action:1)
Pump System.
Check that the drain hose has not been kinked.
2) Check the length of the drain hose and try to reduce the length if
excessively long. A 39.36in / 1 metre extension hose of the same diameter fitted to the existing drain hose is the maximum allowable length.
3) Check for open circuit windings in the pump. (Note: Pumps are
fitted with a thermal cut-out, which will reset on cooling.)
4) If the basket is empty of water, remove the pump from the pump
housing and check that it is not blocked. Also check the drain hose is not blocked.
5) If the basket contains water, then service the pump from the top of
the machine by removing the top deck and inner basket. Bail out the water, remove the pump cap and hood and clear the restriction.
Secondary Source: Wiring.
Action:
Tertiary Source:
Action:
1) Check the pump harness is connected correctly to the pump. 2) Check continuity of the pump harness.
Motor Control Module module.
Activate the pump by operating the machine in spin mode. Check the pump is rotating. If it is not operating, and Primary and Secondary checks have been performed, then replace the Motor Control Module.
Jun 10, 2013 | Fisher and Paykel Washing Machines
My 6.5 smart drive gets to rinse cycle then stops with it beeping until i press a button the led lights that stay on are 3,6, and 8 what does this mean. It's less than 2 yrs old. any ideas on this
That is Error 37 pump blocked.
37.(00100101) Pump Blocked Error (No change in the water level)
Primary Source:
Action:1)
Pump System.
Action:
Tertiary Source:
Action:
Jan 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
I have an toploader smart drive (about 12 years old now). I added some clothes to the machine last minute throught the cycle and now its just stopped. Dashboard lights come on but it wont drain or...
Water will not drain from machine
1. Kinked or clogged drain hose---clean hose
2. Pump does not run----readjust & tighten pump, drive mechanism
3. Suds lock---remove suds add cold water
4. Faulty transfer value---replace
5. Defective timer---replace
6. Loose belt----adjust belt
Sep 21, 2011 | Fisher and Paykel WA37T26G Top Load Washer
My smart drive model LW015-K top load washer won't drain the water, I think the draining mechanism is blocked but Im not sure. I forwarded to spin cycle to force drain but it just makes a buzzing sound...
sounds like blocked or the pump is shorting out, do not keep using it otherwise the pump can short your board out, get a repairman unless your a handyman
Sep 02, 2017 | Washing Machines
Smart Drive 601 does not drain
with the machine plugged in and turned on but not powered up this is what to do
next remove fingers from buttons, then turn off machine with the power button, then turn on again and only press the start button this will now reprogram the computer
Jun 11, 2009 | Washing Machines
Fisher&Paykel Smart Drive 051 keeps beeping/not draining
Hi, I have the same problem and for my wahsing machine it is block pump, so I turn the machine on and advance it to spin and turn the pump fan to help clear the block, the pump locate at the buttom of the basket of the machine...
Mar 31, 2009 | Fisher Washing Machines
Water wont empty
We had the same problem with ours. I took out the steel tub and found there was a lot of lint blocking the pump (at the bottom of the plastic tub). There is a screw holding the pump cover. Once you remove this you can check it properly for blockages.
May 25, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
57 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
