SOURCE: high-pitched sound when using surround sound
THANK YOU Guest (4/10/08)!!!
That was exactly what I needed! We have had our system for 4.5 years and suddenly, the FM feedback on everything, but DVD and Radio! Your fix helped. Once I set all my presets (at least the current one) to a clear station, the feedback stopped. Hallelujah!! We can enjoy this piece of junk once again! ;)
Amanda - San Antonio, TX
SOURCE: how to use usb flash drive
When I try to save documents to my Ativa 2.0G flash drive, it rejects it saying "file permission error." There is over 1.5 g space left on the drive. How do I get it to accept documents for saving?
I had the same problem, check your wires on the back of the tv and make sure your, red, yellow and white wires are in the correct holes. What kind of tv do you have, as I have an Ilo, and it has like 15 different plugs in the back, you may have to get you book out and make sure you have it in the correct hole on the back of the tv... I hope this helps....
SOURCE: MB P21G V3.1 Cannot use USB port (with USB flash drive)
You, probably have what is quite a common problem. Your system cannot recognize the USB, because, either your USB requires a USB 2.0 input or vice versa. Most moedern MB's have either both kinds or they work with regular USB. It might take you some time, or if you the manual, it will take you no time to be up and running. Personally I like the PCCHIPS. They make a good product, they have the currency exchange on their side and here in the US, they provide us with a good and reliable product. Let me know how you make out. This is the way I get graded...
My name is Constantin
SOURCE: Bose Sounddock - Speakers have a loud hiss at low song volume
Here is how I fixed the hissing noise in my Soundock;
--Pull the bottom plate off (It is attached by 4 screws)
--There is a green motherboard with 2 ribbonwires. .
--One of the ribbonwires (the one the mounts the ribbon vertically) had loosened up.
--Use a tweezers to pop it back into place and that noise will disappear.
This is a design flaw, as the action of inserting/removing your ipod, coupled with the action of setting your sound dock down will work this ribbon loose.
