Question about BIT Garden
Selva 50hp outboard boat engine is miss firing
Started engine 50 selva four stroke up this year and was getting a miss firer called out a mobile marine Macanic out we drain all the fuel tank and drained carberetors and put new spark plugs in and still the same he suggested we take carberetors off and clean them which he did bit better he then said give it a run on the water took it out runs fine at 2500 revs the go faster and it just splutter and don't want to go any faster it runs fine at 25000 revs any help out there please?
SOURCE: Lawn mower engine runs rough and puts out white smoke
Pull the carburetor and clean it for staters.Be sure to change oil any little bit of moisture in the crankcase will let it smoke white by seeping by the valves and piston rings.Also put a little small amount of dry gas in the gas tank to rid all of the water that may have been left in the tank. I some of this will help you.
Posted on Mar 19, 2009
  • 86 Answers
SOURCE: Briggs & Stratton engine on Murray lawn mower
I always replace the air filter if its a paper element, and even if its a foam element I replace it rather than clean it. That said, engine stumbling is rarely and air flow problem - but it could be, so having a new filter assures no air restrictions.
I would drop the carbuerator bowl. On the bottom of the carb, near where the fuel line comes into the engine, should be a nut. Removing this nut allows the bowl to drop off the carb. Some engines the bowl screws off, you will have to look at the bowl. Often the bowl has sediment or sludge buildup inside. Cleaning the bottom of the bowl can prevent that sludge/sediment from plugging the intake tube. Even on newer mower models this is a common problem, the gas line tubing interior breaks down and the inside of the tubing can start degrading - ending up in the bowl as sludge.
After cleaning the bowl, I would add one ounce of fuel line cleaner to a full tank of fuel and run the entire tank of fuel. This will clean any deposits or "varnish" from the interior carb parts. Doing this and the first step will assure your carb is clean and functioning.
If that doesn't help, then I would look at the spacing between the magneto and coil assembly. If you want to do that I'd like you to write down all the model numbers and serial numbers on the engine nameplate, that way I can give you specific directions.
Hope this helps,
Posted on Mar 29, 2009
  • 195 Answers
SOURCE: Have a Briggs & Stratton lawn mower engine, 4.5
Is Blade new or causeing vibration .Chge blade,
Please rate Thank you jj505
Posted on Mar 30, 2009
SOURCE: 1996 Mercury 150 Nitro EFI
Dont have the manual in front of me...recollect that there's two types of warnings. The pulsating warning is oil (starts with 30 minutes of oil left) or the fuel filter (or sperator, something like that) may have water in it. Running outboard with cover off, is a little black box that would have a red light lit if that's the case. If oil full & no red light, may be oil injection system...would also check to make sure lines aren't pinched, etc. Mine has been specific to oil the two times its gone off.
The full non-pulsating is engine overheat. Not sure beyond that.
Not much, but hopefully gets you going.
Posted on Jun 23, 2009
  • 155 Answers
SOURCE: Mower stutters when i turn up to full throttle.
Hi if it is older than 2 years it will need a new diaphram and gasket under carby you will also need to clean out the fuel bowl in the top of the tank this should fix your problem.
Posted on Jul 25, 2009
50hp Mercury outboard electrical schematic
Hey David,
Yo should find all the info you need here..this will be very very helpful...' Mercury Outboard Manuals by Seloc 1965 2014
Jun 07, 2017 | Mercury Boating
1998 1150412UD Mercury Outboard - is it 2 or 4 stroke
If it has an oil compartment, it has to be a two stroke. There is a rough and ready way to check. A four stroke engine has a compression stroke on every four strokes, whereas a two stroke has compression stroke on EVERY upward stroke of the piston. Remove the spark plugs, and turn the engine until you see the piston. Put your finger over the plug hole and turn the engine one revolution. Do you get compression? Keep turning, do you get suction and then compression again. If so it is a two stroke.
you can also follow the pipes from the oil tank and see where they go to? Yours should have a pipe from the pump to the carburetor inlet manifold.
On a new boat though, my advice for you is to take the boat and engine to a marine engineer for a service. The cost is minimal and you will get everything set up for the season, especially the carbs. You can ask lots of questions. The cost is about $150 and is well worth the piece of mind that you are not going to break down.
The critical bit you have missed from your post is the HP. If you Google
Mercury HP Serials
and you will end up at a site with engine details. Then google the same, but manual instead of serials. If you know the year of the boat, add that before 'Mercury'.
Use Evinrude XD50 two stroke oil. It is expensive but the best in clean running, non fouling and lack of acrid fumes. One $48 jug will last a season and a bit if you go out twice a week as I do. My boat goes to the marina on Wednesday :>)
May 29, 2017 | Mercury Boating
need the year of manufacture as some 2 stroke units have oil injection that automatically mixes the oil in the correct ratio for engine rpms otherwise it is 50:1 ( 50 parts fuel to 1 part oil)
oil requirements --certified tc-w3 2 stroke outboard oil ---not ordinary engine oil
google --type in mercury outboard oil to fuel ratio
May 07, 2017 | Mercury Boating
Do I use reg gas or a gas mix?
Matt, If engine is two stroke and not oil injected then yes you must mix 2 stroke oil and fuel. 4 stroke engine have a crank case which is filled to proper level with 4 stroke engine oil. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Decide Between Two or Four Stroke Outboard Boat Engine
4 Stroke Outboard Motor vs 2 Stroke Outboards
2 stroke outboard Vrs 4 stroke outboard
Apr 15, 2016 | Boating
How to winterize 175 mariner outboard motor
Take a look at these instruction videos.
How to Winterize an Outboard boat, step by step guide in ...
9k=? 11:25 Oct 30, 2012 - Uploaded by Warren Hardy A detailed step by step guide to winterizing your outboard boat motor for ... most 2-stroke outboards ...
Winterizing Your Boat: Step 2 The Engine & Lower Unit ...
9k=? 10:01 Oct 6, 2009 - Uploaded by West Marine How to Prepare Your Boat for Winter - Step 2 in the five step process on How to Winterize Your Boat: The ...
How to Winterize a Four Stroke Outboard Motor - YouTube
9k=? 2:44 Nov 7, 2012 - Uploaded by Four stroke outboard motors are by far the most popular on the market. But there's a lot of confusion about ...
How to winterize your outboard For smaller outboards, the simplest way to flush your outboard is by using a large ... water or purchase a set of "ear muffs" (available at your local marine dealer).
How to Winterize an Outboard Motor - Adventure ... the winter and prolong its. Learn how to properly winterize an outboard motor. ... Buy lubricant, oil, and fuel conditioner at a marine store. Time: about 2 hours.
Jan 09, 2016 | Boating
How to replace impeller on Selva 3.5 outboard's%20manu
Sep 07, 2014 | Boating
Selva 850 65hp 2 stroke mix
most 2 strokes for that mater take 50 to 1
Aug 21, 2014 | Motorcycles
Jul 08, 2013 | Boating
Garden Logo
Top BIT Garden Experts
Bill Boyd
David Hoover
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a BIT Garden Expert? Answer questions, earn points and help others
