Question about Husqvarna Garden
Husqvarna rider mower dies when taking foot off of clutch? What is wrong?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Husqvarna Master
  • 941 Answers
Check the safety switches. there is one bad.
Posted on Apr 30, 2017
  • 153 Answers
SOURCE: Dies when clutch disengaged
It sounds like the seat switch is disconnected or failed. Check it out. If it thinks there is no **** on the seat it will cause your symptoms.
Posted on May 26, 2009
  • 203 Answers
SOURCE: I have a Husqvarna Pro Rider 15 ride on mower,cuutting deck broke
You may find this helpful. A complete manual you can download and use for this and other repairs.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqom88hoen2003_1140142-26rideen.pdf
Posted on Dec 23, 2009
  • 394 Answers
SOURCE: The mower will stall when I lift my foot off the brake.
If you have a gear transmission,you have some safety switches. One under the seat. One on the clutch -brake pedal. These switches work together to prevent accidental injury. One may have disconnected or a wire frayed. If one switch has failed it will shut the mower off.
Posted on Apr 23, 2010
  • 9 Answers
SOURCE: 2007 Husqvarna Riding mower blade will not engage
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Posted on Apr 25, 2010
Testimonial: "Thank you! That doesn't sound like an inexpensive solution. We appreciate your help, though."
  • 146 Answers
SOURCE: Husqvarna YTH 2042 lawn tractor
If it really 'lugs', meaning the engine gradually chugs slower and slower as if it's struggling, then it could be a belt problem, but I'm going to guess it just quits, which suggests a problem with the seat safety switch. Look under the seat, take out the safety switch, and tape it in the pushed-in position. See if the tractor runs now. If so, the switch is the culprit - either it failed, or the mounting is wonky so it doesn't activate when you're in the seat.
Posted on Jun 05, 2010
Mower starts, dies when you release clutch.stumped. is it time to replace mower or is this relatively cheap fix
My Husqvarna 48-Inch Mower Will Not Stay Running ' Home ...
homeguides.sfgate.com > ... > Other Real Estate Terms & Definitions
Among its offerings is an extensive list of riding tractors and mowers. ... Mowerissues can prevent you from performing your lawn-maintenance program. ... If yourHusqvarna 48-inch mower dies without spinning down, check the drive belt ... If yourHusqvarna mower runs until you release the clutch, chances are you have an ...
Aug 01, 2015 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Lawn mower starts but when I take foot off clutch it dies
Faulty seat switch, or wires off or lose on the seat switch.
May 02, 2012 | Husqvarna Garden
My sears craftsman riding mower will crank just fine, but as soon as I try to either put it in gear and release the clutch to go forward or backward, it shuts off. It also shuts off when I attempt to...
Many folks have found that a defective relay in this mower to be the cause of the "stall when i take my foot off the clutch" issue. The relay is connected to the safety switches which turn the mower off when no one is in the seat, etc.
Aug 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Electric clutch warner
Sounds like your rider safety switch is disconnected. When you enable the blades the rider presence switch (under the seat) must be made else the mower will quit.
Aug 20, 2009 | Garden
Engine dies when clutch brake released on husqvarna gth2548
First check the seat switch,make sure it is plugged in tightly, these plugs have a safety tab built into them that will cut the engine off if you unhook it,sometimes the plug latch pulls out slightly and this will cut the engine, There are two other switches in the system one on the foot clutch and on on the mower clutch, if you follow the white wire from you ignition switch it will lead you to both of them,check those connections also.
Jun 22, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a snapper rider (hydro), when it's started and u take foot off clutch/brake, it dies, push in clutch again and it catches...could it be the safety switch under the seat? Please help!!!
This does sounds like your safety switch is bad. But you do need to make sure that your clutch it engaging properly also the adjustment could have been changed by vibration also
Apr 13, 2009 | Garden
Garden Logo
49 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
