Question about Vertex Radio Communications
I bought a baofeng uv5r and want to link it to my work radio which is a vertex standard vx160u..I can transmit from the work radio to the baofeng but cant figure out how to transmit back to the vertex
  • Vertex Expert
  • 509 Answers
First of all, technically, you can't use this radio to talk to anyone other than ham radio- that being said, if you want to proceed at your own risk. Ok, is your work radio an analog radio? Is it narrowband FM? Is it digital MOTOTRBO? Last two will make if difficult. Digital is impossible. Next, find out the exact transmit and receive frequencies for your radio. They may not be both the same if you have a radio 'repeater' your input frequency could be 5MHz higher than your receive frequency. And last- you need to know if your system has a "PL" tone (CTCSS, or DCS) subaudible tone that will break the squelch. So there are several variables that you will need your plant supervisor to relay to you. Good luck. You can probably get much of this info on line from radio reference.
Posted on May 01, 2017
randy54156
  • 55 Answers
SOURCE: Vertex headset
Why not just get a differant radio capable for beacons. 406mhz is what they've changed to.
You used a part that was not compatable with your radio. The VX-150 has a differant size plug than the VXA-150
You'll need to take the radio to repair or bend the jack back to the size for the appropiate headphones.
Posted on Nov 11, 2008
  • 9 Answers
SOURCE: Hi - can you let me have a link
Here is the user manual Hope this helps www.tehnoturg.ee/kasutusjuhend/Yaesu_VX146_EN.pdf
Posted on Sep 10, 2009
Testimonial: "Perfect!"
  • 104 Answers
SOURCE: I just purchased two Baofeng BF 888s radios and had them programmed to our frequency here. They will both receive and transmit with each other but not transmit to the radios we already had. Any ideas?
Your radios could be programmed with subaudible tones (CTCSS) or digital code squelch (DCS) which the new radios do not have. They can be programmed for it, you need to find out what tone/code you are using.
It could also be that your existing radios are programmed for a "duplex" repeater channel, with different transmit and receive frequencies. The new radios might be on the "repeater output" frequency so they would not activate the repeater.
Both could be the case, missing tone and duplex frequencies.
I would check the programming of the new and old radios, especially for tone/code squelch.
Posted on Sep 14, 2012
richdean9572
  • 3 Answers
SOURCE: My baofeng uv-5r will not transmit any solutions?
Don't know what software you used but try looking up a program called Chirp on the internet and use it to progran the radio. The program gets updated a lot. It has worked well for a large group of us. Is the battery fully charged?
Posted on Oct 16, 2013
  • 102 Answers
SOURCE: My new baofeng uv5rv2+ won't transmit. How do I fix this? My other radio light up like they are get a singnal but you don't hear anyone talking
Download a free program called "Chirp" and with a program cable you can connect and program and also check the programs in the HT and by default these radios are not programed. You will need to know the frequencies and PL tones to enter into the programing software, These are a true pain in the neck and almost impossible to program from the keypad. buy the program cable from the dealer or off of Ebay and use CHIRP to do this.
Dennis
Posted on Apr 15, 2017
My baofeng radio will transmit but will not reseive
Check your settings for the RX frequency. Then check to see if the RX Tone is turn on and is set to the correct frequency. Just turning the rx tone off should allow you to hear any station coming in.
Aug 06, 2014 | Dual Uv-5r Baofeng Band Uhf/vhf Radio Usb...
I programmed my Baofeng UV-5R to a UHF repeater frequency and entered the proper CTCSS code. I also correctly entered the correct offset which allows me to connect to the repeater. Howerver, when I
Please. Your question got truncated in the title, and was not asked in the details. So I have you asking, "However, when I..." and that this is occurring on your UV5R. Please respond with details and I will try to help you. I own the UV5R+.
There is an excellent owner's manual for the BaoFeng at Miklor.com/uv5r/userguide.
Apr 02, 2014 | Baofeng UV-5R PlusEarphone...
Help me put frequency in baofeng uv-5r
CHIRP (Chinese Radio Programming) software is available free online. Also, search for "MIKLOR". They have great manuals for Baofeng UV5R manual online.
Mar 15, 2014 | Dual Uv-5r Baofeng Feq Uhf/vhf Radio Free...
Baofeng uv5r manual
Sounds like a "frequency step" issue. If you search for CHIRP, you can find great guides for programming the Chinese radios, including the Baofeng UV5r. Good luck!
Mar 15, 2014 | Radio Communications
Get Motorola CLS 1110 to work with my Baofeng UV5r
Dear sir,
pls diable Interference eliminator code on baofeng,, & try the same
Dec 14, 2013 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Baofeng uv-5r will not transmit
Sounds like you have the transmit lockout set. this radio is a bit of a pain to program, but is well worth the effort. your best bet is save your settings (backup) and do a full factory reset, and start over, making sure you did not lock out the transmit on any channel or VFO...
Oct 15, 2013 | Dual Uv-5r Baofeng Band Uhf/vhf Radio Usb...
Baofeng uv-5r will not reset
So glad you have resolved your query in a timely fashion.
Peter
Mar 09, 2013 | Dual Uv-5r Baofeng Band Uhf/vhf Radio Usb...
Radio Communications Logo
48 people viewed this question
Top Vertex Radio Communications Experts
enb54
Level 1 Expert
Steve
eradiostore
eradiostore
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
