Question about Speed Queen Dryers
Why my speed queen dryer stops in middle of cycle then after 15 to 20 minutes will starts again
  • 55 Answers
SOURCE: Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Posted on Jan 24, 2008
  • 63 Answers
SOURCE: Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Posted on Nov 12, 2008
SOURCE: Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Posted on Jan 26, 2009
SOURCE: Washer stops several times in the middle of cycle
i've had this problem for years. the product sucks. get a new washer
Posted on Mar 05, 2010
  • 8220 Answers
SOURCE: Kenmore 868738000 Elect Dryer Starts for 10 minutes then stop.
That is gong to be a bad motor. $72.
Tools needed:
Putty knife
adjustable wrench
locking pliers
Motor blower is reversed threads
Difficulty 1 to 10 = 3
Start by: removing filter and filter housing screws
then remove front panel screws LIFT UP on panel to remove it.
Remove belt remove tub. Get filter housing off
Clean up dryer. Lock down shaft and remove blower. Pop motor mount clips. Unplug motor. make hote of position f motor. Install new motor use nutdriver to snap down clips. I have the manual and some photos. In my sleep I can completely replace a motor in less than an hour and that includes oiling the rollers and idler and doing a through hoovering out the machine. This machine is worth replacing the motor and really a breeze to repair. Nothing has worked better for over 50 years. Go for it.
Posted on Apr 22, 2010
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
Dryer stops running shortly into cycle. When button is pushed to restart, dryer groans. Holding button may get the unit going again - but it makes noise running and stops again soon. Bad motor? Bad...
Sounds like start winding switch. I would replace whole motor assembly. Try on ebay for a used one that looks newer. Used motors will save you some serious money.
Jun 21, 2010 | Speed Queen AES28AWF Electric Dryer
I have a Speed Queen dryer that just stopped last night. There appears to be no power getting to the unit--dryer does not start, light does not come on, timer does not advance--yet the circuit breaker...
Is there power at the dryer receptacle? Is the dryer wired directly or does wire from electrical breaker go to a receptacle first? Have it checked with a meter. If unit is wired directly have it changed to a receptacle and cord. Make sure there is power at the connections on the dryer. If everything is okay, then it is a dryer problem
Nov 09, 2009 | Speed Queen AES68AWF Dryer
Nov 11, 2008 | Kenmore 63942 Dryer
Speed queen commerical dryer
try replacing the gas valve coils. they are cheap
Jul 25, 2008 | Speed Queen CGS68AWF Gas Dryer
Dryers Logo
93 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
