Question about Irons
My eurosteam iron is continuously leaking steam through the screw cap even after replacing the O ring.
snakehead
  • 1074 Answers
SOURCE: I cannot get the iron to put forth steam when I am ironing. It isn't even a year old.
take down the iron and clean it the spring is dead probaly you can stretcth it to gain a little tension.good luck.
Posted on Apr 18, 2007
  • 43 Answers
SOURCE: My iron doesn't steam up anymore
Time for a new iron. I last one went to the iron graveyard and I then spent $150.00 on the top of the range Phillips with the gold plate. Has cut my ironing down to a 1/4 of the time. Well worth it
Posted on Feb 02, 2008
SOURCE: Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Posted on Sep 03, 2008
  • 43 Answers
SOURCE: swan steam iron steam coming out of front and leaking water
the temperature is not set correctly for the fabric.
Posted on Sep 18, 2009
SOURCE: my shark steam iron is leaking when ironing
It is quite possible that this is a defect in the shark G1490F... I had the same problem and it was a crack in the water holding tank caused by tightening the two front screws (hidden) that hold the tank to the base... It seemed fine at first but after a full heating it developed a crack where it had been weakened when it was assembled... I suggest returning it or if warranty is up , throw it away and get something else..
Posted on May 26, 2010
The screw cap on the water tank is leaking steam
You can do a couple of fixes here. One would be to take the iron with you to a hardware store (not a big box store} and find a replacement for your cap. The other would be to pick up some plumbers thread tape. Wrap that around the threads of the cap you have and reinsert it. That will take care of the gaps.
Sep 03, 2015 | Irons
How can I repair a constant steam on a EuroSteam Evolution Steam Iron
what is wrong with it? does it not come out?
Jan 28, 2015 | Irons
Steam comes out the filler cap on the water base on my Rowenta DG5030
WIre brush the caps screw threads and replace the O Ring ASAP.
DOn't use the iron until you get a new O ring and they need to be the orange/red rubber ones they are able to withstand the hot steam black o rings at home depot won't last.
Jul 24, 2014 | Rowenta Pressure Iron and Steamer DG5030
I am having issues with my steam generator iron. I used it today and after heating up steam was pouring out from the screw on cap. Put on new green rubber ring and I can iron with steam until I sit on base...
I think lime and calcification are the culprit. Use some "CLR" at Home depot, can decalcify the build up on your irons pressure cap.
I have the Rowenta Steam Station. Love it!
Cheers,
Embroidery Services
San Diego, CA
Oct 25, 2017 | Rowenta DG5030 Iron
Steam escaping?
do the following step:
1) distilled water and softened produce leak , change the water
2)put water until the LEVEL
3)give time enough thermostat for heating. if you use before to HEat enough produce leak.
4)switch dial off to test the water stop leaking,when the steam setting is NOT working.
5) shake back and forth for a few time, to turn on back it is auto-off function.Can be leak when is auto-off mode
God bless you
Jul 14, 2012 | Irons
Rowenta Powerglide 2 INOX vertical steam, no steam, just water leakage
replace the o-ring gasket on the tank fill cap. It is a simple neoprene "O" ring you can buy at your local hardware or NAPA aauto parts store for less than $3.00.
st. louis mo Ralf
Sep 09, 2008 | Rowenta Steam Generator DG050 Iron
Rowenta steam generator
Maybe the cap is coated with mineral deposits. Do you use ONLY DISTILLED WATER in the iron? If not, minerals from the water could be the cause. Try pouring some CLR or a similar product over the cap and see if that frees it up . If it does, pour some CLR into the iron's tank, and set it to the highest temperature setting. Run the iron over an old towel to help clean the steam vents. Then fill the tank with DISTILLED WATER and do the same proceedure two more times using DISTILLED WATER ONLY to flush out any remining CLR.
Aug 27, 2008 | Rowenta Steam Generator DG050 Iron
Irons Logo
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
