Question about Garden
Is there a way to test the ignition condensor on an 18 hp onan engine in a 318 John deere lawn tractor.
  • 850 Answers
Not worthtesting just replace it if its suspect as they are only cheap to buy & easy to fit
Posted on Jul 25, 2009
My John Deere 420 onan stops for no reason after running for ten minutes Restarts immediatly.
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure.
John Deere 316 318 and 420 Lawn and Garden Tractors Service Manual
Jul 07, 2015 | John Deere Garden
Where do i find the regulator on a john deere 318?
WHAT TYPE OF MOTOR MODLE AND HORSE POWER DOES IT HAVE USESALLY BHIND THE DASH OR NEAR THE BOTTOM OF ENGINE
Sep 01, 2014 | Garden
Deere 318 with Onan B43G won't start w/ starter engaged, but if the engine "catches" when I turn off igniton, it runs fine. I can only get it to start by pulsing the starter on and off--only starts when...
318's are known to have flywheel problems and poor engagement of the starter due to incorrect alignment of the starter to the ring gear.To check either of these things you need to take the motor out of the tractor to look at the ring gear,starter drive and starter aliggnment.Before you go through this pain replace the ignition switch or have it tested.p.s deere only supplies a replacement flywheel but a ring gear can be ordered through a case dealer if you get it for a stinner with the onan engine.
Nov 14, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
John deere 318 wiring diagram I replaced an bg 316 onan with an bg 318 onan new the starter only has one bolt for wires the old one has a bolt and a plug on where does the purple wire go on this new...
Purple wire goes to the solenoid on starter.If you installed starter with single wire post all you have to do is mount a solenoid to the frame just in front of starter,existing batt/starter cable goes to one solenoid post,purchase a short red cable and install on other solenoid post and run it to the starter,plug purple wire into new solenoid and the way you go.
Sep 28, 2009 | John Deere Garden
I have a older mmodel 318 riding mower with an onan motor. wruns very well but when it is hot outside it will shut down withinabout a minute the power will reinitiate and the tractor can be restarted ....
possibly a carb or coil problem. does it have point type ignition? if so try replacing the condensor.if nothing else changes try replacing the fuel filter. then nothing,a float sticking in the carb or a bad coil.
Jul 12, 2009 | John Deere 420,1020,2010,2020,2510,2520...
JOHN DEERE 318 LAWN TRACTOR WONT START
ok, since you have the points, I assume you have the B43g Onan
engine. Was it running before the new parts were installed?
Check your point gap and make sure it is .016, plugs ahould be gapped at .025 Make sure your plug wires are good too. Should be somewhere between 0 and 10,000 ohms per foot, when measured with an ohmmeter. Once everything is rechecked for gap distance, make sure there is no spark by pulling plug out, leaving wire on and ground the outside of plug to the chassis of the tractor.
Crank over and look for the spark. Coils are about $100, so you want to eliminate everything else first.
Diagnosing a points ignition for no spark is really simple. Do you have 12V at the coil? Do you get a spark when you connect and disconnect the negative terminal of the coil to ground? If not you have a bad coil.
May 18, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
436 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
