Question about Health & Beauty
HTT-10-CRP Controller needs to be replaced. Can I obtain same and DIY replacement?
What does CRP mean
C-reactive protein
C-reactive protein (CRP) is a substance produced by the liver that increases in the presence of inflammation in the body. An elevated C-reactive protein level is identified with blood tests and is considered a non-specific "marker" for disease.
Elevated C-reactive Protein - CRP - Symptoms, Causes & Treatments
https://www.drweil.com/health-wellness/body-mind.../elevated-c-reactive-protein-crp/
Or maybe something in the link
CRP + computer Google Search
Apr 03, 2017 | Computers & Internet
Can I get a new controller for an HTT10XL massage chair?
only the manufacturer could tell you the answer to this .
Aug 28, 2016 | Human Touch HTT-10 / HT-120 Robotic...
What do the initials C.P.R. mean as re. blood testing?
I think you mean CRP.. (C.P.R.) Is a rescue term meaning Cardiopulmonary resuscitation, But C-Reactive Protein (C.R.P.) Deals with blood testing This is sometimes called an acute phase protein. This means that the level of CRP increases when you have certain di sea ses which cause inflammation. CRP can be measured in a blood sample.
Mar 22, 2015 | Therasense Freestyle Test Strips
I need a remote control for my HTT-9 Human Touch Massage chair.
My htt-9c would beep and not work. E-mailed company and they said chair was out of production for a while and they would give me a discount on a new one(no replacement parts). I peeled the sticker off of the top of the remote and had to remove 4 tiny screws. Inside the remote there was 2 more tiny screws to remove. Went to radio shack and got a 25' phone cord for 11 dollars and plugged it in the remote and back of chair. Fixed the problem
Oct 23, 2011 | Interactive Health Refurbished Htt 10crp /...
Ihave a motorguide brute hyper 67 trolling motor can't get the 24 volts to work motor runs on 12 and 24 volts and all five speeds but don't have the thrust of 24 volts
This is most often caused by a faulty 24 Volt, section, (usually damaged output semiconductors, or the drive?) in the speed controller, fault, the only "Fix" is replacement. Simply obtain the entire speed controller and replace it "En Bloc" as it were. You will need to also obtain a service manual so you can disassemble it and obtain the parts numbers for the replacement parts.Otherwise take it to a professional and ask for a "Quote" as to prospective costings and go from there.
Oct 20, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Freezer does not turn off, -2 degrees on warmest setting, can this be reset?
Hi, well this isn't something that can be "Reset'. You see what has happened is that the Thermistor and or the Thermostat is most likely the problem, if so this will need to be replaced to effect repair.Also unfortunately it maybe the main controller board? There is simply no way to actually tell with just these symptoms and without actually examining the unit. To effect a repair as fast and as inexpensively as possible the very best thing you can do is to call in a professional, contact a local or head office from GE, ask them for a referral to an authorised service center, then make contact there and ask for a service call. Now when you are in face to face contact, at this time ONLY, ask for a "Quote" as to what's wrong and prospective costings, and proceed from there, once you know what's going on?
Really it isn't a DIY repair, however if you do wish to DIY, then you would need to obtain a service manual, use that and perform and work through the troubleshooting steps to locate and isolate the suspect parts and then using the service manual to get the parts numbers, and obtain the spares.
Oct 19, 2011 | GE GSH22JFT Side by Side Refrigerator
I own a Bosch 300 Next Series Washer and the door and drum both seemed to be locked. I need to know if there is anything we can try to get the door open?
Hi well whenever this occurs it is usually to do with the main controller board, simply it needs to be replaced. If you wish to DIY, then you will need to obtain a service manual, in order to perform the troubleshooting steps, just to ensure that the main board is actually the culprit, and also to enable the parts to be obtained, via the parts numbers in the manual.
However it may indeed be best if you contact the local or head office from Bosch, and ask for a referral to an authorised service center, then make contact there and ask for a service call, now when and only when you are face to face ask for a "Quote" ONLY. Then at the least you will be appraised of the problem and the potential costings. Then at the least you can make up your mind as to repair or replace?
Oct 10, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Model FDW80 error code AL-10 what does this mean?.
error code AL-10 == Failed heating element
You will need to have the element replaced, call a professional, or obtain a service manual and do a DIY?
May 12, 2011 | Hotpoint Dishwashers
My Cuckoo CRP-HDP1010F pressure cooker seems to have lost its seal and won't pressure cook any more. We've cooked a lot more than rice in it, and it's become fairly messy--we're forever wiping up liquid...
1. it is best to replace the top-corner rubber seal before a year have passed, as a prevention measure to retain moisture and pressure (contact their official line or site, to verify this is the right part for your model):
http://cuckoomallusa.com/index.php/shop/accessories/cover-pack/ccp-10.html
2. if however you have used it extensively, and cooked more than rice in it : the metallic cover itself may have deformed (difficult to be verified visually by looking at it) in which case the whole top replacement will be considerable that it would be more efficient to buy a new one .
from your inquiry that it won't pressure-cook any more and it is getting messy : I would deduct it would be the latter case above .
Mar 15, 2011 | Crock Pots & Slow Cookers
I have an HTT-10i-crp robotic massage chair pp although power is showing going to the chair -- it stopped working. Any ideas?
Have you checked to see if the main on/off switch on the back of the chair got pushed to the off position by accident? It's near the bottom of the back of the chair.
Jan 04, 2010 | Interactive Health Health & Beauty
Health & Beauty Logo
14 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
