Question about Microwave Ovens
The buzzer on my BAOSCH HMV9305 microwave has gotten very soft. How might I make it louder?
Installing new filter in Bosch over the range microwave
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 08, 2016 | Bosch HMV9305 Microwave Oven
No power. fuse looks ok...
Hello, you need to take int microwave in to have repaired, you can get severly shocked if you touched the wrong thing inside the microwave.
Dec 03, 2015 | Bosch HMV9305 Microwave Oven
Microwave starts running as soon as door is shut and gets very hot.
You probably have a shorted cook relay (see video), or possibly a bad door switch (see help file).
Dec 26, 2012 | Bosch HMV9305 Microwave Oven
Hmv9305/01 microwave @ 13months old the magnetron blew, authorized bosch repairman, replaced using bosch magnetron. warranty for 90 days jan of 2011 same problem, why does this happen? should i ditch...
With all due respect, what are you doing to it?
If you use it with nothing in the cavity, that will kill the magnetron otherwise it will last for years and years.
Very unusual and Bosch is a well respected name.
If there is a probem with the oven, Bosch will replace it so take it up with Bosch.
Apr 01, 2011 | Bosch HMV9305 Microwave Oven
Fan runs, light is on, turntable turns, but doesn't heat. Problem is intermittent (Maybe once/week or even less) but very frustrating.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Dec 05, 2010 | Bosch HMV9305 Microwave Oven
Microwave works except not heating food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
djh
May 08, 2010 | Bosch HMV9305 Microwave Oven
Microwave vent turned on by itself and won't turn off
The HMV9305 has an automatic vent turn-on feature. It senses heat, possibly from the oven or range beneath, and turns on the exhaust fan until temps return to normal. Sometimes this may take 4-5 minutes, which can seem like an eternity of listening to the blower run, but it is a safety feature designed to prevent damage to the microwave from excessive heat generated by the cooktop or oven beneath it.
Jan 24, 2010 | Bosch HMV9305 Microwave Oven
The microwave
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jul 30, 2008 | Bosch HMV9305 Microwave Oven
Door constrained by adjacent cabinent
You need the "Some Other Solution". Do Not mess with the MW Door Hinges! They have been set by the factory to safety requirement to prevent MW Radiation Leakage. Altering Door Hinge could place you and your Family in harm.
Jan 30, 2008 | Bosch HMV9305 Microwave Oven
Vent fan runs intermittently, starts on and off regularily
I don't have the manual but there should be a temperature setting for the fan to come on.
Jun 23, 2007 | Bosch HMV9305 Microwave Oven
Microwave Ovens Logo
26 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
