Question about Coffee Makers & Espresso Machines
My nuovo simonelli MDX on demand grinder won't stop grinding
5 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: Nuovo Simonelli VIP 2 group
Hold down the stop button and the continuous run button. lights will blink indicating program mode. Push one of the buttons that you are trying to program, when the desired quantity is reached press stop button. When all buttons are programed hit stop button again.
Posted on Feb 26, 2009
SOURCE: Cuisinart DBM-8 Grinder Automatic Burr Mill stopped grinding
perhaps remove the hopper (top) and inspect to see if a buildup of very fine compacted grounds as accumulated. knock the stuff loose.
Posted on Mar 28, 2009
  • 1089 Answers
SOURCE: grinder completely unresponsibe.
Hi
If you have tried opening the adjustment to a larger # and it still doesn't work. Well if the motor won't turn, I only hope the machine is less than a year old because the likely problem is the motor is bad. Sorry
Posted on Oct 25, 2009
z34aga
  • 137 Answers
SOURCE: how do i adjust gran
Grinding setting is one simple operation but requires bit patience:
  1. Turn on your grinder and continue setting to fine while burrs are spinning, you stop when you hear metal to metal touch sound(burrs maximally closed finest grinding)
  2. From that point go back quarter of revolution and mark the spot where you stopped with marker to body of grinder and setting plate with one line
  3. Grind little amount of coffee only to fill one sector of dosser than test it at your machine (if it leaks too fast and with yellow color of cream you should go to more fine>><< if it does not leak from the filter holder or it leaks very slow you go to in opposite way.
  4. You test grinding few times bit after each reset of plate grind little amount and take that in one other pot (that will provide to have pure new granulation)
  5. After setting measure the grounded coffee that comes out from dosser it should be about 7 grams, better measurement you can get if you measure 10 doses in one place because you don't get never same amount from 6 sectors of dosser.
PS: the pump pressure of coffee machine should be from 8 to 10 bar and steam pressure should be from 1.1 to 1.5 bar> depends on type of coffees you use.
Posted on Feb 12, 2011
I have a Nuova Simonelli Aurelia, suddenly the machine lost power? any help
Check the breaker. It might be too much for the circuit with other appliances. If the breaker is OK, pull the plug on the wall and then count to 10 and plug back in.
Jan 29, 2016 | Nuova Simonelli Aurelia Volumetric 2 Group...
Machine won't turn off after grinding beans. have to unplug it and wait 20 seconds before repluging it to stop.
Just replace the relay which drives the grinder.
Thats all
You are good to go
Thanks
Please rate my work
Sep 10, 2011 | Bunn -o-Matic G2 (2 lb. Commercial Coffee...
I can hear the grinder on nuova simonelli try to gring, but it seems like soemthing is stuck. how can i fix this?
Remove the bean hopper and vac out all beans, then remove black cover, then 3 phillips screws, and top part of burrs should come off. Clean our chamber then reassemble. DO NOT TURN ON. Make sure middle nut in chamber spins freely, use fingers to turn, if not adjust setting to coarser, until it moves freely, then turn on grinder. All you have to do now is set your grind.
Jan 03, 2011 | Nuova Simonelli MDX Electric Grinder
How do i adjust gran throw on a simonelli grinder
Aug 30, 2010 | Nuova Simonelli MCD Electric Grinder
What is the proper number setting for the grinder
There isn't one, because your grind depends on the bean you are using, the temperature and so on. The best thing you can do is clear the burr chamber of beans, then turn grinder clockwise until you can no longer turn the brass fitting in the middle, then turn counter-clockwise to about 4 numbers that will give you a nice starting point to setting your grind.
Feb 18, 2010 | Nuova Simonelli MDX Electric Grinder
Nuova MDX espresso grinder wiring help
Fixed it Myself
Red wire --> Cap1
White wire --> Cap2
Blue wire --> PWR Switch
Brown wire ---> Thermal Protection Switch
Nov 15, 2009 | Nuova Simonelli MDX Electric Grinder
Assembly
Are you talking about the handle?
Fit the spring in the indentation in the handle cup (just below the rim).
Then firmly push the filter inside the spring(you may need to give it a slap with the palm of your hand).
Apr 04, 2009 | Nuova Simonelli Program VIP Coffee Maker,...
Jan 07, 2009 | Nuova Simonelli Program VIP Coffee Maker,...
Coffee Makers & Espresso Machines Logo
41 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
