Question about Maytag Dehumidifiers
I can't find the adapter to hook up hose.
M7dh452ba Maytag dehumidifier. I just popped out back adapter not attached for hose, only a very thin tube
SOURCE: LG Dehumidifier overflows when attachment tube/hose attached
  • After 1 year of wondering why the LG instruction manual said no more than shove the white hose connector piece into the rear of the unit until secure, and relying on 'hit or miss' that the drain hose would actually work, (rather than filling up the bucket), I have finally found the solution. Ironically, it came while I was on my knees getting serial number from behind the bucket before they would try to help me by phone. There I saw it! The black interior drain piece inside the unit (top right when you remove the bucket) that the white house connector must be secured over. (Nothing in the manual ever told me to look for this.) As for securing the unit in the back--under the big vertical flap (which must point up and remain outside the unit), there is a smaller flap or triangular piece. They say that should be inside the unit, which it doesn't seem to go, because it is parallel to the large vertical flap), but if you push hard enough it does click onto the unit, while allowing the large while flap to remain outside (with the arrow pointing up), making the entire piece secure. Check once more to see if the white hose connector piece is secured over the interior drain piece (a black plastic elbow piece, on the top inside right where you remove the bucket, as I've said), and you'll be good to go! LG should be ashamed of their manual writing on this and the time I wasted getting my two units to work. However, at least these units are not fatally flawed as I was beginning to think.
Posted on Aug 16, 2008
SOURCE: water will not go down drain tube
Sounds like you have a clog. Either try plunging the drain in the stationary tub or replace the line from the humidifer.. Just a thought
Posted on Jun 10, 2009
  • 4736 Answers
SOURCE: /my dehumidifier has a hose
The hose attachment is used in place of the water collection bucket, to drain the water directly into a floor drain or a sump pump holding tank. A garden hose is connected to the "hose attachment" and run to the floor drain or sump pump holding tank. However, it will not drain UP, only DOWN.
Hope this helped.
Posted on Mar 20, 2011
  • 2006 Answers
SOURCE: I have a Maytag dehumidifier
Unless it can be 100% gravity feed (1 inch drop per foot) you might need this:
Part: WPL8212501
Fits Maytag M7DH45B2A 496719-1.jpg (Click images to Enlarge)
Description:
Pump-drain
No. in Pack:
Additional info:
Dehumidifier pump assembly conveniently attaches the pump kit to you dehumidifier. connect a run hose to a nearby sink, pump, or floor drain. this pump will push water through a hose to up to 18 vertical feet for drainage through a window.
Stock Status: In Stock
Price:
This part is also known as:
8212501
If you can gravity feed it and can get a hose around the output pipe then any flexible hose will work that is slightly larger than the output pipe.
Posted on Jun 02, 2011
SOURCE: Hooked up garden hose for continuous mode but it
I had the same problem with the LAD 704 DUL.....I tilted the unit back slightly with a wedge under the front side and the water is now draining through the hose into my drain....
Posted on Jul 03, 2011
I have a Maytag dehumidifier M7DH45B2A, and want to connect a drain hose, as opposed to using the bucket as we always have. What kind of hose, and do I just remove the bucket and hook up to the same...
Part: WPL8212501
Description:
Pump-drain
No. in Pack:
Additional info:
Price:
8212501
Jun 02, 2011 | Maytag M7DH45B2A Dehumidifier
I have a lg lhd45elt8 dehumidifier i bought used i want to hook up the hose connection i see on the back a plastic chip that needs to be removed and the hose pipe is just inserted? then connect a drain...
I own this dehumidifier. To connect it to a garden hose for drainage you first need the special connector pipe/adapter that comes with the unit. It's white plastic and about a foot long, It may be stored in the top of the bucket drawer, where it ships from the factory. Your hose connects to the threaded fitting on one end. The other end is inserted into the hole in the back of the unit. You slide it straight in until it mates with a drain connection inside the unit. You can see this black pipe connection if you pull the bucket drawer all the way out and look in the very top right hand corner of the opening of the unit. Once the white tube is fully and correctly inserted you'll find two plastic tabs on the tube near the hose connection. The larger tab points straight up and blocks the tube from being inserted too far. The smaller tab points down and hooks into the slot in the bottom of the round opening to keep it from getting knocked loose. Your dehumidifier should now drain through the hose instead of into the bucket. Of course, be sure your hose is routed across a floor to a drain or sump pump located lower than the unit, since the water flows by gravity.
Apr 27, 2011 | LG LHD45EL Dehumidifier
I would like to SEE a picture of how to hook up a hose from the DH to a drain.( no manual & cant find one for this DH 304) TO lift the bucket off & drain has become to heavy for me. Thanks,...
My DH 304 is a hand-me-down so I don't have a manual but it did come with a hose attachment which is plastic tube with a threaded end to which you attach a hose. The other end of the tube goes through a hole in the back of the unit and then through a foam screen inside the unit to slip over the drain plug. Aligning the tube and the drain plug can be tricky; it is helpful to remove the bucket to see if you're getting the tube onto the drain plug. Once you have the tube attached to the drain plug, align the tube in the hole in the rear of the unit so that the tab on the tube is inserted into the slot at the hole in the back of the unit.
Aug 26, 2010 | Goldstar DH304 Dehumidifier
I connected the hose adapter so that I can drain directly into the sink. But it still drains into the bucket. Did I miss a step?
I had the same problem. The plastic tube that routes the water out the back doesn't fit tightly. It took a couple of weeks but the bucket would fill and the darn thing would shut off.
My first attempt was to put a hose clamp over the adapter. The clamp was simple enough but then the bucket wouldn't go back in. Using a small saw, I carefully cut a notch in the bucket. WARNING: Make sure that whatever you cut doesn't reach low enough that when the bucket fills, the little float thingy shuts off the unit before it starts to leak. Anyway, that still leaked. The problem is that that plastic tube is stiff and slippery and doesn't seal well.
What finally worked for me was to take the adapter off, go to the hardware store and buy some clear plastic tubing. I found some that fit very tightly over the tube inside and, with the hose clamp, sealed well.
Problem solved.
Jul 03, 2010 | Maytag M7DH45B2A Dehumidifier
I've lost the manual. Can I hook a hose directly
yes you can, but you may have to drill it out to let the water out
Apr 10, 2010 | Maytag M7DH65B2A Dehumidifier
Our unit is hooked up to a hose drain had has been
proably trash in your diverter (the thing that allows water to run to tank, or hose) try a pipe cleaner or blow with air, is it electronically controlled? or is there a valve?
Apr 03, 2010 | Dehumidifiers
I have the hose hooked up to the back but it keeps filling the tank and shuts off when it's full ,how do you just use the hose to drain
I believe you have to put a plug to drain that drains into the tank ,then it can only drain out the hose.
Jul 14, 2009 | Maytag M7DH65B2A Dehumidifier
Codensation Removal
Try making sure the tube that came with the dehumidifier has no blockage. Some Dehumidifiers have the hose screw into the side of the bucket and drain from there. Most newer ones have a plastic tube that comes with them that attaches where the condensate water drains. Good luck - Tech101
Jun 20, 2008 | Maytag Dehumidifiers
Missing hose adapter
It might be a problem since these units were made by Fedders for Maytag which is now owned by Whirlpool :inhale: but I found part number FD9520-010 "drain hose". If not, a length of dishwasher drain hose with a male garden hose fitting on one end would work fine
Aug 15, 2007 | Maytag M7DH45B2A Dehumidifier
Dehumidifiers Logo
Top Maytag Dehumidifiers Experts
Bill Long
Steve
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
