Question about Motorola Mobility RAZR V3xx Cellular Phone
I can only hear my calls if my phone is on speaker phone?
Can't hear anything on regular speakers
Cell phone speaker for ear doesn't work but speaker phone does.
Make sure all the volume is up. If you sill don't hear anything, speaker or wires might be faulty. Needs servicing.
Jan 29, 2012 | LG Cell Phones
Only had the phone since 10/2009. Ear piece went out. Need to use speaker to hear call. Can't hear anything but other end can hear me.
hi
hi there must be fault in your speaker of your phone. kindly change the speaker of your phone. this will enable to fix your problem.. contact your mobile service men to change the speaker of your phone.
thank you.
Dec 20, 2010 | LG VX5500 Cell Phone
My phone model is SGH-B520. I am not able to hear anything while making calls or attending incoming?
Hi, what makes you not to hear anything when making calls is because the earpiece is faulty.
The earpiece is a small speaker at the top of the phone where you put on the ear in other for you to hear anything when calling. You need to replaced it with another.
When you replaced the speaker, you will now be able to hear when people call you.
Take care.
Jun 08, 2010 | Cell Phones
When I make a phone call I cannot hear anything.
check and replace the earpiece speaker
if not try to rework the UEM
Oct 15, 2009 | Motorola Mobility i776 Cell Phone
My blitz's speaker phone wont work. and the open/close, on/off, and ringtones, wont work... help! ive gone thru all sound settings and everything is "on" i can hear my calls thru the regular handset...
Try these couple of things:
The speakerphone feature lets you hear audio through the speaker and
talk without holding the phone.
  1. To activate the speakerphone while in answering or calling modes,
    press the Navigation Key to the right.
  2. The phone returns to normal (Speakerphone Off) after ending a call
    or when the phone is turned off and back on.
To adjust the ringer, key tone, voice call and speaker phone volume levels:
1. Press left soft key [MENU] (7) (1) (2).
2. Select the type of volume you wish to adjust.
3. Select the desired volume level.
4. To confirm, press OK.
Let me know if this works for you or if I can help you with anything else.
JimmyC
Jun 13, 2009 | UTStarcom Blitz Cell Phone
I can not hear anything from my caller
i think what you speak will be heard by the persons who call you ...
you cant hear there voice because there is some loose contact in the speaker(ear piece) or it is dead or broken ...
if you are good at opening the handset then open it and refit the ear piece speaker correctly or if there is a problem in the speaker then it can be solved by replacing it ...
if you no idea of opening then just visit the technician he will do it but he may take some service charge for that ..
but the ear piece speaker is not at all costly it is very cheaply available ...
check the call volume while on call once before you do the above ...
i am sure you will be able to play the music ... dont just get confused because there will be 2 speakers in the handset one is the ear piece speaker which is used to hear the calls and one more is the loud speaker from which the music,etc will be heard ...
thank you
regards
-Dileep
Nov 08, 2008 | Nokia 5200 Cellular Phone
Cant hear who i have rang
it is problem in Speaker, u have to change speaker for ur mobile phone after changing ur mobile speaker will work.
Feb 19, 2008 | Nokia 6230i Cellular Phone
I cant hear anything when i make a call
speakers have gone best getting a new phone it would cost more to replace speakers
Jan 13, 2008 | Motorola Mobility RAZR V3
Calling problems
There is no problem with your phone's main speaker from where you can hear your ringer, tones and media files, including calls put on loudspeaker. The problem is the ear piece speaker of your phone.
Apr 06, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3xx Cellular Phone Logo
157 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
