Question about Kubota Garden
I have a Kubota k-025 it goes forward and backwards. Blade goes up and down but won't rotate in circles,also the boom or bucket won't work
  • 7 Answers
SOURCE: my roomba starts going backwards
I had the same kind of problem with my model 400 today...after starting it and having it go in a circle for 30 seconds or so it would finally run into something and then back up a few inches, turn, then go forward a few inches, then back up a few inches, turn, then go forward a few inches, etc., etc.. I tried cleaning off the four pairs of sensors under the bumper and blowing out various things underneath (by mouth since I didn't have any canned compressed air). It didn't really help. It then occurred to me that I had a leaf blower! I put the Roomba upside down on the grass, put the leaf blower on high, and blew at it from all directions and up close. More dust came out than I thought would. It has been running normally now for the last 45 minutes.
Posted on Sep 14, 2008
  • 433 Answers
SOURCE: Rotating Shaft of Hitachi HB 101 frozen and won't move blade.
It can't be repaired. If machine is under warranty try to get a new bread pan. If not, try calling manufacturer to see if you can buy a new one.
Posted on May 27, 2009
  • 61 Answers
SOURCE: Running backwards in circles.
If your Roomba's speaker isn't working, you need a new Roomba regardless. Give a call to customer support (877-855-8593) and they'll help you out.
Posted on Jun 16, 2009
  • 3 Answers
SOURCE: bmw z3 passenger seat goes forward backwards but
It can also be theseat motor since there is seperate motors for up/down & forward/backwards. You can test the switch to see if you are getting power to the connector on the motor by using a multimeter.
If there is power to the motor, I would remove the motor and give it a tap on the ground. Alot of the time the motor is fine, and the tap will free it up again. If it doesn't work you may be up for a new seat motor. Giving mine a tap solved the issue with mine.
Posted on Nov 05, 2009
  • 31 Answers
SOURCE: hydrolic problem on bobcat
it may be broken
Posted on Jul 14, 2010
I have a mini excavator bobcat 328 that does not want to lift. everything else works it rotates, bucket works, moves forward and backwards
Don't waste your money on unnecessary sources
and unwanted repairs. Get this manual online at www.reliable-store.com and get complete guide on whether to repair or not, service it, and how to repair etc
Mar 13, 2018 | Mini Cars & Trucks
I have a Kubota BX1500 blades won't engage but tractor still goes forward and reverse can you still help me out with the problem?
If you are in the USA you can access the Kubota factory website, go to the parts lookup with all your tractor details and have a knowledgeable person look at the blade drive area. It may show an electrically operated clutch to drive the blades or some other method. Armed with this knowledge look at your machine and work out whats wrong.
May 13, 2015 | Garden
How do hummingbirds fly backwards
A hummingbird can rotate each of its wings in a circle, allowing them to be the only bird which can fly forwards, backwards, up, down, sideways or sit in sheer space. To hover, hummingbirds move their wings forward and backward in a repeated figure eight, much like the arms of a swimmer treading water.
Hummingbird Facts at Hummingbirds Forever
Feb 18, 2015 | Citrix UPG PRES SVR PLATINUM ED FR/ ENT...
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
The car won't go forward or backward
Lift up all the wheels one by one, rotate each wheel and check which wheel resists to rotate. Disassemble the jammed wheel and carefully examine to see why is it so.
Grease the caliper pins, free up the pistons and reset the brake components.
Dec 03, 2012 | 2001 Toyota Echo
Ijust borrowed a b&d model 7334 from a lady and the blade runs backward.There are two arrows on the blade to show the backward direction.How do i get the blade to run forward?
if the spindle is turning in the right direction I would think that the blade is on backwards. the teeth should point towards the front of the tool. UNPLUG tool before maknig any adjustments. If the spindle is rotating backwards then it is an electrical issue.
Jan 24, 2012 | Saws
I have a 97' daewoo dsl601 skid steer that the boom and bucket won't move
You most likely have a defective hydraulic control valve, I would start the testing there.
Dec 07, 2011 | Daewoo Cars & Trucks
Hi, I have a Kubota T1760 ride on mower that has a problem with the transmission. The mower goes fine backwards but struggles forward. Sometimes it goes forward but lacks power. Most of the time it...
my kaboto had the same problem ,kaboto dealer quoted me $2500 to fixand so i attempted to fix it myself and did so for $6.50 and its working like a new one
Mar 10, 2011 | Garden
I have a bobcat 773T with the Kubota engine. It is a 2001 model. All of a sudden when I move the machine forward or backward it continues going forward or backward slowly and sometimes it will either turn...
the screeching sound could be a belt slipping. there should be a neutral adjusment on the valves that the sticks are attached to. its just a matter of finding true neutral.
Jan 16, 2011 | Toys
Garden Logo
32 people viewed this question
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
