The XPC has power, the LG Flatron monitor also has power but remains in power saving mode during boot up. I have tried pressing various keys on the keyboard, moving the mouse, and also the ctrl-alt-delete combination, but to no avail. The monitor still remains in power saving mode. I wonder if it actually receives power from the XPC. I know that it has power from the mainline. I also wonder if the keyboard and mouse are getting power from the XPC.
Tony Toledo Muntinlupa City, Philippines
Comments:
Nov 22, 2007
- thanks for the reply, Master tvsandstuff! i thought my message to fixya did not get through, so i continued troubleshooting, and successfully solved the problem last night. what i did was the same pareho as your advice. and so i expressed my thanks to you by giving you a 4-diamond FixYa! rating.
Sounds like an issue with a memory card or pci card not properly in place. Try opening up the sytem, then make sure each card is properly inputted in it's slot. This may cause the the monitor to show power saving mode especially if the memory is not properly placed.
Thanks
Cameras Sharp sharp ar-5316-paint the No. 2 Li* + box I would like to send
Machinery until you...
(More)
Machinery until you return to Dsna coude reset sharp ar-5316
My T1360 wont boot up but the lights turn on and nothing is on the screen i have tried the ram and...
(More)
My T1360 wont boot up but the lights turn on and nothing is on the screen i have tried the ram and its good and it only happens when its on sleep or hibernate mode
I have a gateway gm5478 model pc with a 22inch lcd gateway fpd2275w monitor(purchased 12/07) for...
(More)
I have a gateway gm5478 model pc with a 22inch lcd gateway fpd2275w monitor(purchased 12/07) for family use and the monitor started giving me the no signal display about 3-4 months ago and has increased in frequency to the point now that I once it happens I can't get it to recognize the computer. Did all the usual fixes reset and powered everything down,disconnected and then reconnected after a couple of minutes.
