Question about Bosch Televison & Video
Bosch dishwasher SHE44C
Control buttons worn off can't read
  • 154 Answers
SOURCE: I have a Bosch she44c dishwasher that I used just
In some cases, the heat element lining wears out and the element shorts out to the chasis of the dishwahser, thus tripping your fuse.
In other cases, the dishwaser leaks water, and shorts out an electrical component.
It is best to get a repairer to check this out for you.
Regards
Ash
Posted on Nov 15, 2009
SOURCE: Bosch 24 in. SHE44C05UC pops breaker
We just had a potentially dangerous problem with the same model. Only we found the wiring beneath the front door were fried. How do yours look?
Posted on Mar 06, 2010
Macmarkus
  • 2605 Answers
SOURCE: How do you take the
Hello Steve,
Welcome to FixYa.
If you email me at macmarkus@live.ca my windows live account I will send you an official B/S/H/ ( Bosch ) service manual that should explain fully & completely how to not only take it appart, but how to repair it as well.
Let me know if you want to receive this info or not either here or via email.
To provide the info it must be through email as the adobe files are too large to post here.
I`ll watch for your reply.
Regards,
macmarkus :)
Posted on Sep 21, 2010
Macmarkus
  • 2605 Answers
SOURCE: Bosch she44c dishwasher. Dishwasher times
Hello, Welcome to Fixya.. On bosch dishwashers the "1" is actually an error code and not coincidentally the reason it runs forever ( likely doesn't dry or clean well either right ? ). Here`s the most likely reason why it has detected the error... Even if your home water supply appears hot, it's not hot enough and must be heated by the dishwasher to insure a proper clean and dry, hence most if not all manufacturer`s do this. When it comes to your Bosch dishwasher the problem likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). To repair your unit It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s and eventually display`s the error "1" telling you it can`t heat the water. ( I can send you documentation directly from B/S/H/ confirming and explaining this if you'd like to email me at macmarkus@live.ca. I should also add, some of your models have been included in a bosch voluntary recall...based on serial number as well as model ). **Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on their behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?...unless it is indeed a recall effected unit )** **Please disconnect the power before attempting any service to the dishwasher** Installing a new control will certainly remedy the problem as well. But when it is priced at about $170.00 I am more likely to offer someone an alternative to buying new, hence my first reaction to mention this repair tidbit. The control is available at most brick & mortar appliance parts stores or on-line at vendors such as "repairclinic.com", "appliancepartspros.com", "searspartsdirect.com" etc. part number is based on your specific model number so you`ll need to provide that. Hope this answer`s your question's, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness to you and leave a testimony if you're satisfied. Good luck. Regards, Macmarkus :)
Posted on Nov 04, 2010
  • 414 Answers
SOURCE: replaced the control board in Bosch Dish Washer SHE44C and the cycle times are reversed???
I think this board requires coding to your particular model?? your dishwasher has four selection button and a delay start, whereas the module has five selections and delay as it is used in several different modesl. The coding info should have been in the box with the part and may need to be carried out directly on the module with the fascia panel removed. If you post the part number of the module I will see if I can get you the coding information..
Posted on Mar 02, 2013
Bosch dishwasher SHE44C does not heat water or dry dishes
have an electrician check the heater element
Oct 25, 2017 | Bosch Dishwashers
I think I need to check the water pump/motor on my Bosch SHU43C dishwasher. It seems the water enters at the start of the wash cycle but then there is silence through the remainder of the cycles. Water...
Read this page, it may be helpful to you
http://www.repairclinic.com/0088_9_1.asp
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Aug 03, 2008 | Bosch Dishwashers
Bosch dishwasher runs continuously
I would call Bosch with you.re model and serial number, they have had a recall on your model for the control board and that sounds like it may be your problem, if it is under recall Bosch will send someone out at no charge to install a new board (800) 856-9226
Jan 24, 2014 | Bosch Dishwashers
Replaced the control board in Bosch Dish Washer SHE44C and the cycle times are reversed???
Mar 01, 2013 | Bosch Dishwashers
The control button labels are worn off. I would love to know what each button does.
The simplest thing would be to read the manual. This is available for download (free) from Fixya. Please click on the link below to open the manual:
http://www.fixya.com/support/p117443-bosch_shu9950_dishwasher/manual-388
You will need to scroll down slightly and there is a link just above the manual for downloading to your PC. You can then print the file and keep it with your dishwasher for future reference. If you are unable to open the file, you may also to download Adobe Reader:
http://get.adobe.com/reader/
Please rate this solution if you find it helpful. Thanks.
Nov 04, 2010 | Bosch SHU9950 Dishwasher
How do you take the control panel out of a Bosch dishwasher model# she44c. I have read other consumers and I have the problem that the solder joint may have come loose. The dishwasher stays on one after...
Hello Steve,
Welcome to FixYa.
Regards,
macmarkus :)
Sep 18, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Hello, My Bosch she44c dishwasher is not evacuating the water from the machine. I checked the line and i can hear the motor trying to pump. I've tried to make sure the impeller was clean, so at this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 09, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch SHE44c getting a E6 code????Just finished E1 code by re-soldering the board and the first wash after fixing that error, I get an E6 code and it did not drain. During the repair of E1 code, I cleaned...
Thanks, that perfectly nailed my problem. Bad / burnt solder joint on a SHX45P05UC/57 model. A little solder, and it may last a while. But next it fails that way I can order the motherboard without even opening it up.
Aug 11, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dec 31, 2009 | Bosch 24 in. SHE44C05UC Stainless Steel...
I have a Bosch she44c dishwasher that I used just this morning. This afternoon I went to turn it on and a fuse in the panel box tripped. Is there something in the dishwasher that could go bad that...
Regards
Ash
Nov 15, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Televison & Video Logo
27 people viewed this question
Top Bosch Televison & Video Experts
richie46
Paul Unsworth
Level 1 Expert
Are you a Bosch Televison and Video Expert? Answer questions, earn points and help others
