Want to hook up speakers and they don't work.
I don't know how to hook up the speakers
hooking up speakers is easy you if your terminals are red and black you just match them up black on speaker means hook to black on the receiver doing a wrong hookup can reverse the phase of the speaker cause a distortion and eventual damage to speaker and coil.if you are rtunning just a stereo that allows two speakers select speaker you want for left side and put that on left of the stereo and hook it up as left and same for the right and if you have a home theater you hook it all up the same but you hook up the center put it in center front of the room as far back to wall as you can but dnt cover it up it should be lower than the front left and right or the main left and right speakers.then if the5re is surround you put those like say you have a square room you put them in the corners on the back wall.if you have rear speakers you put them on the back wall.make sure all speakers excepty rthe center are level and equal distance apart
Mar 20, 2013 | Audio Players & Recorders
How to wire to 2channel amp
It is easy, You hook it up to two regular speakers ,End not subs, On less yopu want to fry it, If you don,t no how to hook it up poperly, Get some one that has done it before to do it for you ,Onless you have money to burn to buy enouther one when you fry this one, Because you don,t no how to hook it up (Properly) Get wireing instructions for it, It is to hard to explain how to hook it up ,Too some one that has never done it before,
Dec 01, 2012 | Lightning Audio S4.12.VC2 Car Subwoofer
Sound not comming out of rear speakers
Thanks for choosing FixYa. More then likely, you have a wiring issue. I would advise you to check your speakers first though. If they both went out at the same time, probably a wiring issue. If the speakers don't work, then change them. You can hook your speakers straight to a power source to see if they are working or not.
Jun 12, 2012 | 1995 Oldsmobile 88
Where to hook up speakers on monitor and desktop
The color codes [if even present] probably don't match
the PC should have its outputs marked with both color AND an icon::looking for 'line out'; headphone; speaker
Feb 19, 2012 | Gateway Computers & Internet
My rear passenger speaker wires don't work, I have connected 3 different speakers to them none of them work but those 3 speakers work when they are hooked up to different connections.
have you tried connecting directly to the radio? I would suspect a broken wire or a bad fader control or switch depending on the model.
Jan 31, 2012 | 1998 Ford Expedition
Hooked up a cd player to my 2005moms grand am but volume don't work? Why?
Check to make sure it is not manually muted, if that doesn't work make sure your speaker wires are connected properly in the back of the radio and speakers work also. If it is run through an amplifier, make sure the amp works and the speaker wires are connected properly too! Don't forget to check gain on the amp too!
Jan 16, 2012 | JVC Car Audio & Video
The sound isnt working on my radio the radio works but no sound and ive redone the wires and still wont work what do i do
Check the basics first, you do have the volume up. You don't have the mute function on. If you checked these and still have a problem, then I need to know something else. Did you use a wiring harness to hook up the radio. If you didn't, you need to undo all the work you did, purchase the harness, and put it in that way. You probably don't have the right wires hooked up which could fry your entire electrical system. However, if you did use a harness, then you might need to look at the speakers. Hope this helps.
Aug 21, 2011 | Car Audio & Video
I hooked up the boston speakers 4 plus wolfer and when I play music on You Tube, the rear speakers don't play. They work in the sound "test." They also work when I set the speakers...
the sound on utube is only stereophonic, hence you will get only stereo putput. If you play anything recorded as quadraphonic or above all your speakers will give sound output.
Jun 22, 2011 | Boston Acoustics MicroMedia Computer...
Hook up lower level input to the audio source 230 subwoofer but can't get any sound for the speaker that is hook up through the speaker level input or output.
The speaker level connectors on the sub are for use when you DON'T have an AV receiver-style subwoofer output. They only pass-through from YOUR amp to other speakers. You should NOT use both Line level and Speaker Level input to the sub.
What is your electronics? Have you looked at the manuals?
May 02, 2011 | AudioSource System 230 / 235 System
13 people viewed this question
